Question about Brother IntelliFAX 560 Plain Paper Fax
Brother fax 560
Unable to receive fax. keeps saying memory full. How do I clear this?
  • 1 more comment
  • cklove May 08, 2008
    Tells me memory is full.....how do you erase the memory?
  • UhelpMehelpU Apr 03, 2009
    Fax Displays "MEMORY FULL"
    I read the comment, and checked the picture of the FAX 560 from Brother, but I did not find any menu keys on the fax... any ideas? I only have function/set key instead.
    Sorry just to rephrase my question a bit better: The fax I have matches with the fax in the picture posted on the upper left of this webpage.
    But I do not have the menu key, only function/set, and mode keys
    Novelist:
  • 158 Answers
Try this: Press MENU, select FAX, then scroll down to REMAINING JOBS. If any jobs are displayed , you can choose to print them. To print from the fax memory, first exit out of the MENU functions totally. Then, press MENU,2,5,4. Next, press START. After all faxes in memory have printed, press STOP/EXIT button. Check REMAINING JOBS again, if it is clear, fax memory should be clear, Also.If the fax machine has a PRINTER function, press the JOB CANCEL button to clear the print Queue.
Posted on Aug 09, 2008
Brother 8360p has faxes in memory but will not print them. All the faxes ar going into the memory now. It has paper and toner, check by making a copy. the menu 2 5 4 fax command doesn't do anything,...
I have seen a few Brother faxes do this. I fixed them by turning off the power, holding down the clear/stop button and keep holding it down while you turn the power back on. Keep holding it for a few seconds then release. This will clear what ever is in the memory that is locking up the memory print. Note: you will lose any received faxes in memory by using this procedure.
This may help you restore your fax to a operation condition.
Good Luck and Thank You for using Fixya.
Aug 19, 2010 | Brother FAX-8360P Plain Paper Laser
Hello, I have a Brother Fax 560 (Plain Paper Fax). I am having difficulty receiving faxes. It is not transmitting on the receiving end. What is the problem?
Hi Despite the increase in texting, email, Facebook and Twitter, we still hang on to our fax machines. They are perfect for sending copies of original documents despite document jams, buying ink or special paper, maintaining a phone line--we love 'em. Basic problems like paper misfeeds can be troubleshooted through the use of some basic steps.
Check the Message
  • Check the messages on the display of your Brother fax machinemag-glass_10x10.gif. The messages will be pretty self-explanatory such as "Insert Doc, Again" or "Please Supply Paper." "Insert Doc. Again" means that that the documents weren't placed on the feeder correctly; just follow the instructions and try again. A message like "Please Supply Paper" will simply mean you need to replenish the paper. "Memory Overflow" is probably the most cryptic. It just means that the memory capacity was exceeded and it has stopped recording. Press "Enter" to register the documents in memory and to complete the operation.
  • Misfeeds
  • Clearing an original's misfeed by pushing down on the release lever to open the front panel. Remove the failed original and close the panel. To clear recording paper that's gotten jammed in the paperfeed, open the turn guide and remove the paper. To clear paper from the transport unit, which is in the top, open the cover, remove the drum and toner. Lift the guide and remove the paper by pulling upwards. Paper can get stuck in what is called the Fixing Unit. Open the top cover. Again, remove the drum and toner. Open the Fixing Unit cover and remove the paper by pulling it back.
  • Aug 02, 2010 | Brother IntelliFAX 560 Plain Paper Fax
    Our intelifax says memory is full and I do not know how to clear it so we can receive faxes
    This page has instructions for entering the Maintenance Mode, and for clearing memory. Note that you should only need to use the "91" clear method. The "01" method is for when the machine's memory is thoroughly messed up, or if you're selling the machine and want it to go out the door a blank slate.
    Feb 17, 2010 | Brother IntelliFax-2820 Laser Fax
    FAX 560 Brothers displays message "Memory Full"
    Do you have faxes in memory? You may need to either erase faxes in memory or print them out.
    Printing a Fax in Memory
    If you have Fax Storage ON for remote retrieval, you can still print a fax in the
    memory when you are at your machine:
    1 Press Function/Set, 8, 4.
    2 Press Start.
    3 Press Stop.
    (See Turning On Fax Storage, page R-2.)
    Apr 04, 2009 | Brother IntelliFAX 560 Plain Paper Fax
    My brother fax 560 will send but will not receive
    you will have to go into the machine set up where it say send and receive scroll up to where it says easy receive and press set. good luck brother tech
    Jan 14, 2009 | Brother IntelliFAX 560 Plain Paper Fax
    Brother fax 560
    Unplug the power cord for 10 seconds.
    Nov 13, 2008 | Brother IntelliFAX 560 Plain Paper Fax
    unable to send fax through power line carrier communication. only some part of the document received
    Apr 28, 2008 | Brother IntelliFAX 560 Plain Paper Fax
    Memory full
    If your brother Intelli Fax 775 says..Memory full, erase message...this is what you do. Press "menu 84" then press the fax start button. Your fax will print every fax in memory and it will clear itself. To turn off the memory so this does not happen again..Press Menu then 82, then a up or down button, so it reads "off". Then the stop/exit button, and your done.
    Jan 28, 2008 | Brother IntelliFAX 775 Plain Paper Thermal...
    Received fax's are not printing. Unit prints confermations and is working as a printer but recieved fax's just park in memory and will not print.
    TYPICALLY A FAX MACHINE WILL RECEIVE MESSAGE IN MEMORY WHEN NO PAPER OR TONER/INK FINISHED INDICATION IS THERE, REPLENISH THESE SUPPLIES WITH GENUINE ONES AND FAX WILL START PRINTING. IF PROBLEM IS NOT SOLVED , PLEASE TRY TO CLEAR THE SETTING FOR MEMORY RECEIVING, IF STILL NOT SOLVED TRY BRINGING THE MACHINBE TO FACTROY SET SETTING BY CLEARING THE MEMORY. HAPPY FAXING OMNIPRESENT
    Jul 28, 2006 | Samsung SF-560 Plain Paper Laser Fax
    Brother IntelliFAX 560 Plain Paper Fax Logo
    370 people viewed this question
    James Cagle
    James Cagle
    Samyfam
    Samyfam
    Victorman
    Victorman
