Question about iLO 3200 32 in. LCD Television
Help I have just recently purchased an ilo 32in lcd tv. I tried to hook cable up to it but the part just spins and i can not connect the cable wire to it.. I think it might be broken?!? Is there a way to fix this?? Or does someone know what is wrong?
  • TecnoChick Apr 21, 2008
    No its not an rca .. Its the one with threads that hooks up cable or an antenna. Alot of people recommended that i buy a new tuner board.. which is the part that i believe is broken.. i rather have an expierenced person sodder it back togeather because a new tuner boad is priceie..
  • 121 Answers
Is the connector a RCA (smooth outside with 1/8 inch hole) or 75 ohm type with threads? Also the 75 ohm type needs the correct allignment and length of wire...needs to be straight and no more than 1/8 inch beyond the threads.
Posted on Apr 21, 2008
Ilo-26HD televison problems
most of the new TV's use a SCAT plug to allow connection of a PC or laptop. I doubt that this TV has that sophistication. The ISB will not do it and neither will S VIDEO.
As for the cable you could try a male to male plug to mnake a coaxial connection. These TV's were made to a price for walmart and you got what you paid for which was a cheap TV. There was no warranty offered by Walmart for these either
Please rate my help++++Thanks for using FIXYA
Nov 20, 2009 | iLO 2600 Television
if you want to use a single remote, try buying a learning remote
Aug 13, 2009 | iLO 3200 32 in. LCD Television
If the jack on the set spins I hope you didn't try to use pliers to tighten the cable, if you didn't, return it to the retailer. Maybe you should return it, it's up to you, if you broke it and want to tell them that.
Apr 15, 2008 | iLO 3200 32 in. LCD Television
32 ilo lcd
most boxes have component out or HDMI connection use either one and cable box or satelite came with instruccion on how to connect it ..
Mar 30, 2008 | iLO LCT32HA36 Television
Problemw with digital TV signal using an arieal
I recently purchased an ilo 32 inch tv and am having problems because when I first purchased it I had it connected to a cable box now I no longer have the cable box just the cable and am unable to hook it up because the connecter does not hook up to a regular cable cord is there a special connection that hooks it up directly to the cable cord? I read in the manual something about a F-type connector where can I get one?
Mar 28, 2008 | Televison & Video
I have an ilo 32hd
Unfortunately the ILO TVs aren't a good investment. If you just purchased the television, I would return it as soon as possible and purchase a more reliable and well known brand. ILO support services is almost non-existant and there are several comments on other blogs regarding the Ilo brand. I have two ILO 26" HD, which I purchased in Aug '06 and am now beginning to experience problems.
Dec 29, 2007 | iLO 2600 Television
32in ILO LCD Hd TV
There is a capacitor that is out. It is a 470uf 25v. When you open the back and look at the power board there are three group together. It should be right there. You will be able to tell if the capactor top is bubbled replace it. It should be completely flat.
Nov 20, 2007 | iLO 3200 32 in. LCD Television
Ilo 27 inch hdmi/dvi hd tv monitor
Hi, I'm afraid that not only a cable is needed but an analog (vga) to digital (dvi) converter/scaler as well. The iLo LCD Display V27DMBX-U12 can hook up to a PC using the DVI-I connection only. As you said, your computer has the standard 1D15 pin VGA connector. Another possibility is if your video card has a composite video output (normally a color yellow RCA female) or an S-Video output which will both connect direct to your iLo LCD Display V27DMBX-U12. For the RCA connection all you need is an ordinary RCA to RCA shielded wire cable and for the S-Video, an S to S Video cable will work. There is of course the question about the quality or the resolution. Good luck and hope that this be of some help to you. Pls post again how things turn up. Kind regards.
Jul 31, 2007 | iLO V27DMBX Television
Ilo 42" tv - v-chip code?
Try these codes 8202 or 8205. Hope this help.
Jul 17, 2007 | iLO 3200 32 in. LCD Television
ILO 32 inch TV
The TV should have two ANT coax jacks in the back, one for air and one for the cable line. The one on the right side should be the one you want. It could be that you've plugged it into the left one, which will not work for line cable.
Apr 27, 2007 | iLO 3200 32 in. LCD Television
iLO 3200 32 in. LCD Television Logo
66 people viewed this question
Top iLO Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Jaime Hernandez
Jason Morris
Are you an iLO Televison and Video Expert? Answer questions, earn points and help others
