Back to:
Tags:
Hampton Bay Dual Mount Ceiling Fan
Remote to fan won't work (by 4 users)
posted by Alan Guapo on Apr 15, 2008
I bought my house several years ago and there is no instruction book for my Hamptom Bay fan. The light comes on at the switch, but everything else operates from the remote. I have a new battery in it and the light comes on in the remote when I try to change the fan speed or dim the lights, but nothing happens.
The only model # I can find is on the remote. Model: FAN-HD FCC ID: L3HMAY97FANHD
Do you have any solutions or is there a instruction manual I can get for this. It is a good fan and I hate to replace it. Thanks.
Remote can't communicate with Ceiling Fan/Light combination
I have the same problem.
This Problem has been added to the Share Your Expertise Page under "My Work Queue".
3 Other Users Have The Same Problem
Comment by beans2, posted on Aug 29, 2008
New place, no manual.  It's 11pm... the light is on bright, the fan is on high and I can't turn either off.  I replaced the battery and still no go. What do I do????
Is there an autoswitch anywhere on this stupid fan?
Comment by drabbit1972, posted on Jul 24, 2008
remote works for my fan but not my lights
Comment by jampor, posted on Jun 09, 2008
went to reverse direction of blades for summer months. fan will not turn back on. you can operate the light only i use a remote to tur fan on reverse direction and speed.
Best Solution
posted on May 06, 2008
FixYa! (100)
Guest
Rank:Apprentice Apprentice
Rating: 0%, 0 votes
you should be able to buy a remote and or receiver on ebay. I'm having the same problem it's the receiver.
Was this solution helpful? Show your Appreciation by rating it:
Thank You!
Was the solution helpful?
Show your appreciation by commenting on Remote to fan won't work:
I don't want to Accept this solution
Solution #2
posted on Apr 22, 2008
Not Rated (0)
lobostar
Rating: 0%, 0 votes
Alan,
Your problem is either the remote control transmitter and/or the receiver (located in or above the fan in the canopy). matching the dip switch settings is the most important step.
To do this you must first find the dip switch settings on the receiver.
there are two types of receivers, 1 an Optional remote (when the fan has pull chains and the forward and reverse switch is located on the fan or 2 an integrated remote the fan has no pull chains (remote only).
if it is an optional remote the fix is easy and cheap. for $30-$40 you can buy a remote control transmitter w/receiver at any Home depot or Lowe's.
if it is an integrated remote you will have to go to the manufacturer of the fan to purchase these parts.
again matching the dip switch setting is the most important thing to do.
Thank You!
Solution #3
posted on Apr 20, 2008
Not Rated (0)
Guest
Rating: 0%, 0 votes
Al,
If you take the back battery cover off there is a label on the inside with instructions for setting the dip switches to match your fan remote.  Hopefully that's all you need.
I'm actually trying to find a second remote, the place I bought has a light/fan that only works with the remote at the  top of the stairs and I'd like a remote for upstairs and one for downstairs.  Anyone know where I can buy a second FAN-HD remote?
Thank You!
Can you Help with these Electric Fans problems?
Electric Fans
This is the best fan ever, you can't purchase one like it...
Hampton Bay (261025) Dual Mount Ceiling Fan
We had a power surge and the remote stopped working on the...
I have an electrician trying to install my fan. He has...
think its same model but remote # is all i know its...
Have hampton bay E106510 3-speed with light. Light quit...
Loading problems.
Repair Service
Find Electric Fan Repairman Near You:
Browse the Repair Directory
Repairman, Get Listed FREE
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
