Question about Xirlink Promax Webcam
The usb cable are de-attached from the bord of my webcam
I have 5 small cords in the USB cable that was attached to my webcam (SPCA561A) form inside, now how can I weld every small cord to its place on the board correctly to avoid electric shorts on the board??
The colors are: Black, Red, Blue, White and Green
And on the board there’s 4 point to weld with these names (in order from left to right): D-, D+, 5V, GND
Many, many thanks
  • Omar Entabi
    Omar Entabi Apr 15, 2008
    Help me Please
    Genius:
  • 1,027 Answers
+Data
Green
-data
White
VCC
Red
GND
Black
BLACK BLUE BROWN are used as Ground
Posted on Apr 15, 2008
G 500 logitech freezes intemittently
I think i found the solution to the Logitech G500 mouse freezing problem: the 5-pin USB cable uses an embroidered thread of fine wire for the first pin on the left (black cable at the internal connector inside the mouse). These fine threads tend to break over time due to movement of the cord, it usually brakes by the point were the cord exits the mouse casing. what i did was actually very simple: I Opened the mouse (there's 5 screws you have to remove: 2 over the optical sensor, one underneath the sticker on the center, one on the right, and one at the bottom of the mouse), then remove the scroll wheel (and basically remove every screw you see on the inside of the mouse), there's also a pin holding the scroll wheel in place, remove that too. Now remove the circuit board and detach the USB 5-pin connector. Inspect the cable (you might have to remove some of the protective cover), if you find that the embroidered wire is broken, as i did, then proceed to twist the fine threads of wire on both ends, and then twist both ends of the broken cable togheter. Obviously the resulting cable is a bit shorter than the others 4... not a problem! simply align all cables and twist the excess wire forming a circle, and just tuck it in at the bottom casing of the mouse when you put it back together. This solution might not be the most clean and professional (perfect solution would be to replace the cord), but it only took me 15 minutes, and my G500 mouse is working perfectly since; hope it helps!
Dec 23, 2011 | Logitech G500 Mouse (910001259)
I bought my lexmark at a yard sell but it didn't come with the cords and I like to know what kind of cords I need to get it working it's a all-in-one. Thank you
Hello, Since the specific model of the printer is listed, you will need to search for the parts you need HERE, In general terms, you should have the main power cord which plugs into the wall and most likeky a USB printer cable to attach to the computer. A USB printer cable can be purchased at any Computer store, the main power cable, would most likely have to be purchased direct form Lexmark....
I hope this and been of assistance, Regards.....
Jan 16, 2011 | Office Equipment & Supplies
Error Oxc18a0206 Fallo de sistema de tinta. No se
  1. Without turning off the product, disconnect the USB cable from the rear of the product.
    NOTE: The USB cable connects to the port on the back of the product. The port is labeled with the USB icon (c01424575.gif ). Figure 2: Example USB connection (your product might not look exactly the same as this example)c01651067.gif
  2. Remove the cartridges from the product.
  3. Wait for the 'Insert Cartridges ' message to display on the control panel.
  4. Disconnect the power cord from the back of the product.
  5. Wait 60 seconds.
  6. Reconnect the power cord. If the product does not automatically turn on, press the Power button (c01602202.gif ).
  7. Reinsert the cartridges, and then close any open doors on the product.
  8. If you receive a prompt to print a calibration page, do so.
  9. Reconnect the USB cable to the rear of the product, and then try printing again.
Solution two: Service the product If you have completed all the steps listed above and are still experiencing a problem, service the product.
Jan 12, 2011 | HP Photosmart C6180 All-In-One InkJet...
Cannot fit my micro sandisk 1gb into laptop. how do i copy photos from memory card to computer?
sandisk reader is cheap at Best Buy 10~ 15 dollars Or cable form camera to Pc small usb cord This is a Sandisk form a camera correct ?
Jun 16, 2010 | SanDisk 2GB microSD Memory Card
I need a software for ezonics webcam
http://www.usb-drivers.com/drivers/75/75663.htm
That should fix ya!
-Captain Jake
Feb 13, 2009 | Ezonics EZVideo Chat Kit Webcam
The keyboard does!t work
remove the connections and reinsert them also uninstall and then connect and reinstall keyboard.
Jan 12, 2009 | Adesso Gift Idea Under $50: Win-Touch...
Why I can not use USB data cable?
Aparently the 2630 does not transfer information through the USB cord, you have to use blue-tooth.
Dec 15, 2008 | Nokia 2630 Cell Phone (Unlocked) - Black
Web cam driver
Kindly help me to get the CD for EZ-306 SPCA561A, free download.
May 29, 2008 | Ezonics EZCam Webcam
I lost usb cord
I have only seen 3 different types of USB mini cables. 2 have a wider flare on the bottom and the third is actually USB micro which as a little bit smaller and has more than 5 contacts inside on the top and bottom. The 2 that are similar that I own are HP and SONY made for their specific cameras, but neither works 100% in the other brand. I though they were standardized but I find that one has 5 contacts in it and one has 4. Look on Ebay, very cheap and youll get your correct cable.
Feb 10, 2008 | Polaroid i733LP Digital Camera
Xirlink Promax Webcam Logo
189 people viewed this question
Top Xirlink Computers & Internet Experts
micky dee
Mohamed Ismail
Mohamed Ismail
David
David
Are you a Xirlink Computer and Internet Expert? Answer questions, earn points and help others
