Can't see the SD card image or can't open SD card. Under Device manager SD Card on Disk Drives has a yellow unknown device. I Can't find the driver for the card. Inspiron 9300 XP2.
    Genius:
  • 1,027 Answers
Posted on Apr 15, 2008
My computrer has no audio
Have you checked the sound drivers?
Goto device manager (Start->Control Panel->System->Device Manager)
Then look under sound, if you see yellow exclamation marks / unknown device, you may need to reinstall sound card driver
Nov 01, 2013 | HP (400745-001) Sound Card
SD CARD reader error: Insert removable disk into drive F:/
One of two I was say is the issue.
  • When you improperly ejected the card you messed up the MFT (master file table) on the card. You will want to format the card.
  • You could have hosed the drivers. In Device manager look under the driver details there should be some files listed. You will probably need to delete these and replace them. Since they may be system files you would need to replace them in a live boot environment such as a linux live boot cd (ubuntu.com) would be the easiest. Get the drivers it has listed copy them to a thumb drive. Boot the computer to the live CD, delete the driver files and replace with the new ones.
Dec 18, 2012 | Electronics - Others
SD card not recognized
What happens when you tried to plug-in SD card to the computer?
Have you made any recent changes to the computer prior to the issue?
To make the SDHC be recognized by the computer, we need to ensure that the card reader works in Windows 7 first. Please check if the card reader is recognized properly by the computer and you have installed the driver for it.
Meanwhile, you can plug some other storage cards to the card reader and see how it works.
I would suggest you to refer the link below
A Secure Digital (SD) card may not be recognized on a Windows 7 based computer.
http://support.microsoft.com/kb/981642
Uninstall all the Generic USB drivers and reinstall.
1. Open Device Manager.
2. In "Disk Drives" dropdown, uninstall the "Generic SD/MMC USB device" drive.
3. Restart computer.
4. Insert SDHC card.
Hope this helps.
Nov 25, 2012 | SanDisk Electronics - Others
My va10 is not reading an sd card i have inserted into the slot
Open computer window and check the drives to see if any show your card. If so double click to open, if not, check device manager to make sure the drivers are installed for your portable devices. On the start menu, right click computer and click manage, in the left pane under computer click device manager and look for portable devices in the main window. Check there is no yellow or red icon next to it, if there is you will need to install a new driver.
Mar 11, 2012 | Sony VAIO VGN-AR605E 17" Laptop
Whenever I insert the micro sd adapter into the card reader on my computer, my computer locks up in 'my computer'. It doesn't seem to be reading the card, and will not let me open that file. ...
click start control panel administration tools computer management device manager scroll through all of your devices if you see a yellow question or exclamation mark ? ! or a red X you will need to update the drivers for this device right click select update driver/reinstall driver
if you can see your usb device but its not working sroll to Ports(Com&Ltd) right click to update driver
if you computer came with a motherboard disk the drivers could be on it
hope it helps
Aug 11, 2011 | Kingston Computers & Internet
I cant open my sd/mmc card reader and writer.
Some SD and MMC have a security feature in them. If so you will need the disk that came along with it. After you install it then that's the time you can fully utilize your SD/MMC. SD means Secure Data / MMC means Multi Media Card.
If your card reader is not appearing in the My Computer then check if it is detected in the Windows device manager. Go to START > CONTROL PANEL > DEVICE MANAGER. Usually it is under the category of Disk Adapters or Human Interface Device. If it's not present then unplug and plug the device back in. Or try a different USB port to see if that will work. If it doesn't then most likely the reader is defective. But if it is detected and still not able to read the SD/MMC and the SD is being read by a different computer then the issue could be that the SD is not compatible with the reader.
Jun 08, 2011 | Computers & Internet
I can't see the pictures from a polaroid sd card on my computer
Have you got the drivers installed for The Card-Reader.
check in the device manager :- my computer/control Panel/System/device manager. And look if you have any yellow exclamation marks ( yellow boxes ) if yes, you have to re-install the device driver. Or go to My Computer. You should Have C:/ ( hard-drive ) D;/ And Or E:/ Cd/Dvd Rom. And if you Have G;/ F:/ H:/ Or I:/ et,c. this is where your SD Card Is. Right click and open to locate your files from SD Card.
Hope this helps you out.
Thankyou for using Fixyas Free Forums.
Jun 29, 2010 | SanDisk 2GB microSD Memory Card
Sd card is detected but cant open
I find that the easiest place to find files on a HDD or SD card that i connect but the drive comes up is by going right click on computer and going to the manage option.
I then go down to disk management and look for the storage that I have added.
Then right click on "change drive letter and path" and add give the storage a drive letter
For some reason the computer sometimes does not complete this part which leaves the drive unreadable
It is always a good thing to do to go to device drivers to check that you can see the drivers for the device being installed. This can be achieved by removing and replacing the storage device while device manager is open
May 26, 2010 | SanDisk 2GB microSD Memory Card
SD card reader problem, Toshiba Satellite P25
Have a look into the device manager, right click my computer, select manage, then on the left side of the management window click on device manager, plug in the sd, do you see any ? or ! or yellow marks or unknown devices that a driver would be missing from or malfunctioning?
Jan 21, 2009 | Toshiba Satellite A105 Notebook
To view pictures from my sd card
Mike @ compurepair.
Nov 26, 2008 | Acer Aspire 7720 Notebook
Computers & Internet Logo
101 people viewed this question
David Payne
David Payne
