Question about Pioneer Televison & Video
Pioneer Elite Pro-810HD Plasma monitor: the picture appears momentarily and the screen goes black. The cable signal is there and fine, as the sound comes through on the sound system. I have power cycled all components and replugged all connections. What might this problem be?
Riziel
  • 116 Answers
SOURCE: monitor goes black
Sorry to have to tell you this, but this is common in LCD monitors. The reason that it is going black when it boots is for one of two reasons. You either have a bad power supply that powers your LCD or your LCD's backlight is blown. These can be repaired or you can purchase a new one. But if it goes black 9 times out of 10 is because the backlight is bad. These can be repaired!
Posted on Nov 26, 2007
JAN_yuanjia
  • 470 Answers
SOURCE: Help with Pioneer Elite Pro-1130HD 50 inch
just wait it, because it is processing the display data
Posted on Nov 16, 2008
Gurudristi
  • 98 Answers
SOURCE: How to connect BLU-RAY DVD player to Pioneer Plasma TV via HDMI
The best possible solution to your problem is :
Connect your blu ray player directly to the HDMI input of you Plasma and watch HD video....
and connect the 5.1/7.1 sound thru the optical or the coaxial link directly to your AVR 3805.
You will not loose anything on the Blu-Ray.
The sound is best processsed by the AVR3805, while the video, which is the real upgrade (BluRay) in terms of resolution of picture would be processed by your plasma.
Connect and Enjoy
Posted on Feb 27, 2009
  • 152 Answers
SOURCE: Gateway Monitor keeps going black
Alicia, Your monitor digital board is OK. The problem is with the power supply/ Inverter board(s) in back of the LCD/LPD Panel that you look at. You will need to question Gateway to see if they have a swapout program where you send them $30-$60 and your old monitor, and they will send you a refurbished (new cold cathode fluorescent tubes w/inverter board installed ) complete monitor. I'll tell you one thing though. Alicia, Don't feel bad abt this monitor of your's failing. You have joined the club with over 2000 others whose CCF tubes and INVERTER boards have with time now fail to light-up their LCD panels. Yes, there are some companys that do repair of these monitors. Try surfing under CCF tubes or FPD repair, or LCD repair. Yes Alicia, you are dealing with a technology similar to the new type of screw-in light bulbs, only the tubes are thinner and laid flat horizontally across the rear of your LCD panel with a reflecting mirror in back of them. Good luck girl in getting it repaired. I'm louie12fix on fixya or lmistyrel @aol .com North of Chicago 40 miles
SOURCE: Bose 3-2-1 - trouble connecting to Samsung 26" LCD monitor
Sounds like you might be out of luck with the older 3-2-1 system. I am in the same boat, and am thinking I will only be able to utilize the "audio out" on the back of my Samsung LCD, and run that to the "aux in" on the Bose 3-2-1. This of course will not allow me to utilize the 3-2-1's DVD player, but by using a seperate DVD player, such as a Blu-Ray hooked to the LDC TV, the video will make it to the screen, and then the audio should make it through the Bose 3-2-1 speakers. Probably not the "best" solution, but one that I am going to attempt.
Posted on Oct 14, 2009
My picture only shows black and white on my pioneer elite once i unpluhgged it fron the cable box. the box isn't broken and the color on the tv works on the menu if i disconnect the cable
Check the color level for that input. While monitoring the cable box go to the video part of the setup menu. Make sure the chroma or color is up to its normal setting.
Some TV sets have independent video settings for each input. This way each input can be separately set up.
There is a possibility something went defective thus causing the chroma processing to not work, but this rare. The menus showing in color are from a different built in circuit than the one that decoded and processes the program video.
Oct 02, 2014 | Pioneer Elite PRO-1140HD 50 in. Plasma...
No image from computer to tv with vga connection
Ensure your TV is turned to computer/VGA input. On your computer use the Windows key + P continuous until it appears on the TV.
Mar 08, 2014 | Pioneer Elite PRO-1140HD 50 in. Plasma...
Hdmi picture sound pioneer elite pro r04u
disconect video cable from the box and if you see color video bars on the screen the problems is the box.if you dont see anything you problem is in the display
Nov 10, 2013 | Pioneer Televison & Video
White screen
It sounds that the digital processor section to video at the main board is faulty. Contact any service technician.
Jul 01, 2013 | Pioneer Elite PRO-151FD 60 in. Plasma TV
Pioneer Elite. Loud popping sound and picture disappeared
Power supply board is dead.The board where the power a/c cord plug into it.Replace the power supply board.Tries websites like Shopjimmy.com,Ebay.com to buy a refurbish power supply board for the replacement.
May 30, 2010 | Pioneer Elite PRO-1140HD 50 in. Plasma...
No picture on Pioneer Elite Kuro 60" inch plasma
my pioneer pdp 505hd tur on ok but the picture no working and no sound ,can you help me please
Aug 22, 2009 | Pioneer Elite PRO-1140HD 50 in. Plasma...
Nov 16, 2008 | Pioneer Elite PRO-1140HD 50 in. Plasma...
Projectile motion
Dear Sir,
I have NEC 42vR5 HW Plasma monitor, this plasma goes off with in 1 Minute, pls. give solution
thanks
pramod
Feb 24, 2008 | NEC - 42" Commercial Plasma Screen ****(no...
Televison & Video Logo
87 people viewed this question
Top Pioneer Televison & Video Experts
Jaime Hernandez
Are you a Pioneer Televison and Video Expert? Answer questions, earn points and help others
