Question about Dewalt 18 Volt Compact Drill Kit
Drill turns but jsut spins when trying to srew
18v dewalt when trying to use the keeyless chuck the shaft is way exposed it dosnt look right how do i get it back to normal so the srew gun will work the black part with the numbers on it is about 1 inch away from the yellow part of the gun there is a shaft showing inbetween hope u can help
    Champion:
  • 313 Answers
Problem could be a broken clutch housing assy. you can purchase the part in assy.
Posted on May 24, 2008
  • mr aicnelav May 31, 2008
    remove nose assy first with the # check out the copper bushing.should be flash to the aluminum housing.
Ryobi 18v drill stuck chuck
easy to fix
with the drill not running
grab the bottom part of the spinning part of the drill nearest the drill's motor.
then
grab the spinning shaft bit nearest the drill bit
pull them apart slightly
when the two parts are pushed together thay lock the chuck
I own a ryobi hammer drill that does the same thing
Mar 13, 2015 | Ryobi 18v Cordless Drill - P206 18 Volt V
How to remove keyless chuck
open the chuck right up and look for a Phillips headed screw at the bottom. This is a left handed screw which means that you will have to turn it in the direction as if you are doing it up to undo it. On the shaft there may be a flat section on the drive shaft that you can use a spanner on to hold the shaft and use a pair of multigrips undo the chuck normally. If there is no place you can hold the shaft you may have to take the front of the drill off to get to the shaft so you can hold it there.
Jun 19, 2013 | Dewalt 18v Battery Hammer Drill Dcd950...
How do you get the chuck off a dewalt 18v dcd970?
The chuck on your drill was made to be taken off with a special jig and holder that cost $175+. Depending on how tight and how much lok-tite the factory used some chucks can be removed without the jig. You need a hex shaft at least four inches long and 3/8" to 1/2" wide. Lock the hex-shaft tightly in the chuck, then put the shaft in a vice with the drill straight up and down. Using very firm and steady pressure, turn the drill using the handle for leverage until the chuck breaks free. Don't bounce the pressure or use an impact wrench as this is very ******* the transmission. When you put the new chuck on, use a few drops of lok-tite and put it on as tight as you can without breaking the case. Let the lok-tite set up for at least one day.
Jan 30, 2012 | Dewalt Drills
Problem with the Dewalt 3/8"VSR
My solution when the other mentioned ideas didn't work was this: I removed the 7 Torx #20 screws ( a common screw driver will work as well) and removed the housing half to expose the shaft. The chuck shaft bearings and gear lifts out as one assembly. Directly behind the chuck there is a half inch section of shaft exposed. I mounted a vise grip on the shaft (won't hurt it) and clamped the affair in a bench vise. With a 5/16" allen wrench mounted in the chuck and using a mallet I spun the chuck off with a solid smack counter clockwise . Very simple and easy .
Aug 29, 2011 | Dewalt 3/8"VSR 6AMP CORDED KY DEWALT DRILL...
The chuck on my Dewalt 18v hammer drill will not stay tight. it loosens whether I am in forward or reverse
the chuck on my dewalt 18 volts hammer drill will not stay tight it loosenss whether i am in forward or reverse
Oct 14, 2010 | Dewalt DC920KA Heavy Duty Xrp 18V Cordless...
The chuck of the drill spins but stops when touched!!
you could have the torque setting set to the minimum setting, in which case, what you described will happen.
check the torque setting and adjust it.
are you able to turn a screw?
Jun 30, 2010 | Dewalt DC989VA XRP 3 - speed 1/2" 18v...
Jammed chuck
Use a pipe wrench to turn the chuck open. J.
May 31, 2010 | Dewalt 18 Volt Compact Drill Kit
I have a DCD940KX 18v Dewalt drill driver with the one click drill chuck. It does not keep drill bits or screwdriver bits from spinning. They spin with the slightest bit of pressure on them. My questions...
this is not a common problem with dewalt. I have been using them in my construction business for years and only heard of this once or twice. I would go to their web site and get the number for their customer service. They stand behind their products and im sure they will help in every way they can to repair the drill
Nov 26, 2009 | Dewalt DC920KA Heavy Duty Xrp 18V Cordless...
My DC759 drill has no bearing clip
http://www.ereplacementparts.com/dewalt-dc759-type-18v-cordless-drill-parts-c-1009_1162_2837.html
Here is the parts diagram. I hate to say it but I always have problems getting the chuck out of the clutch/transmission without breaking something. I havent figured out how to keep the spindle from moving while I try to turn the chuck. Sorry if this doesnt help much.
Nov 26, 2009 | Dewalt 18 Volt Compact Drill Kit
How do i remove the chuck from dewalt dc925 cordless drill, dosnt have a screw inside the chuck, read somewhere that i need a special tool but no instruction or picture of the tool. please help., thank you
The dc925 and the current model dcd950 along with several other models of Dewalt 's line of cordless hammer drills DO NOT have a screw inside removal requires a CHUCK REMOVAL FIXTURE part #
233804-40 also you can't use a generic replacement chuck. As of 2/2/2010 the prices on the Dewaltservicenet web site are $72.74 for
the tool and $69.70 for the chuck, part # 330075-90.
Oct 17, 2009 | Dewalt Heavy Duty Xrp 1/2" 18V Cordless...
Dewalt 18 Volt Compact Drill Kit Logo
89 people viewed this question
Top Dewalt Drills Experts
Jim Thurston
Are you a Dewalt Drill Expert? Answer questions, earn points and help others
