Wireless card not connecting ti internet
The computer is indicatind that the Wireless Desktop Card is working but can not connect to the internet,. No recommended wireless IP addesses are found, Please help
  • Anonymous Feb 12, 2009
    My wireless G card is the same and is currently having a simular issue where it is saying there is a connection, but it wont access any websites, its being sent packets but not receiving any, ive restarted the modem called my provider, they're telling me the card is dead, any solutions, ideas?
    Scholar:
  • 176 Answers
Check if your wireless router is configured properly. try to reset the router to the default sitting
Posted on Apr 15, 2008
The router has #3 link/act lighted up (LAN) and when i connect to internet with router it says limited connectivity, but internet works fine with modem?
I assume you are getting this on your wireless connection.
Sometime you get this message because the computer's wireless card didn't get a issued with an IP address from the wireless router when you opened the browser. This can occur when you power up both the computer and the router at the same time, but the router had not finished booting up in time to issue an IP address to the computer.
You can right click on the wireless icon on the Task Bar and then click Repair, this will force the wireless router to issue a new IP address to the wireless card. When the wireless card gets an IP address then you can access the Internet.
Dec 01, 2009 | D-Link DSL-G604T Wireless Router
Toshiba wireless sees desktop but desktop cannot see laptop. using belkin wireless
this is not likely a problem with your router, here's a couple of tips (this typically works in xp...hate vista and haven't got ahold of 7 yet)
open command prompt, find your ip info (ipconfig /all) try pinging both computers' ip address (ping 192.168.x.x), then ping the router...if you're using local ip addresses it should be 192.168.0.1 or similar...its likely that one ping the other but not vice versa
MAKE SURE the first three numbers are the same, i had a problem when i missed a 192.168.1.1 vs a 192.168.0.1
If you have not created a home network, i'd recommend it...you don't have to make a network disc like it tells you to but make sure they're setup for the same network (i.e. XPHOME, JOHN'S NETWORK)
if they both still are not communicating after a few minutes, try to connect a hard line between them, set one up as the router and dns...your ip config should look similar to this:
DESKTOP LAPTOP
IP 192.168.0.2 192.168.0.3
SUBNET 255.255.255.0 255.255.255.0
GATEWAY 192.168.0.2 192.168.0.2
DNS 192.168.0.2 192.168.0.2
you wont be able to have internet access but I do this to check network integrity, try pinging again, it should work both ways now, set up the network again and then change your gateway and dns back to your router.
I hope this helps, sorry if thats confusing
Nov 28, 2009 | Belkin 802.11g Wireless Desktop Network...
How do I change my I.P. addess...I'm having compatibility problems with my wireless router and cant get on line
1.
Control Panel
Network Connections
Wireless Connection
Properties
Make sure Internet Protocol TCP/IP is set to "Obtain an IP address automatically"
2.
Start/Run
CMD<enter>
ipconfig /release<enter>
ipconfig /renew<enter>
Nov 27, 2009 | Compaq Presario 700 470024-192 Notebook
Can i use a wireless router if i have dial up connection to the internet?
yesinstall a wireless card in your pc and connect to the router and run the network setup wizard on your pc and choose the option that your computer is connected to the internet and all other computers connect to the net through your pc. then you should be able to use the internet connection while you are connected.
Major note though. The wireless router should NOT be using 192.168.0.1 as its IP address if it is it wont workchange the LAN ip address of the router to 192.168.1.1 instead
Oct 27, 2009 | Belkin 802.11g Wireless Desktop Network...
Internet setup
few things you can try:
1. check to make sure you're getting an IP address.
2. try reloading the wireless card driver.
3. is you wireless static or dynamic? If dynamic, try configuring it with static setting.
4. If this don't work, try the wireless card on a different slot.
5. if don't work, try on a different PC to see if wireless card is working or not.
It's possible you have a bad wireless card.
good luck!!
Mar 31, 2009 | Dell Dimension 8400 PC Desktop
I am trying to connectmy basement computer to my upstairs office
Your wireless router issues IP address to your computers.
Your wireless card on your downstairs computer needs to be configured to communicate with the router, ie WEP or WAP encryption - if your have enabled it, SSID etc.
To configure the TCP/IP settings on your downstairs computer -
Click on Start - Control Panel - then Network Connections - then right click on your Wireless Network connection - click on Properties.
Then in "This connection uses the following items, scroll down to Internet Protocol (TCP/IP) and click on Properties. Under the General Tab make sure Obtain an IP address automatically and Obtain DNS server address automatically are selected. Click OK.
If you do not see TCP/IP in the Wireless Network Connection then click on the install button and then install the TCP/IP driver.
IF TCP/IP is OK then before you do the following, turn off or disconnect the power to your wireless router, wait for 1 minute before connecting the power again. Wait till the LED lights indicate that it is on line again and the wireless is on then :-
Click on Start - Control Panel - then Network Connections - then right click on your Wireless Network connection - click on View Available Wireless Networks
Do you see your wireless network (ie. your wireless router)?
If so click on your wireless router and then click Connect.
You can also click on Repair to try to reconnect to your wireless router.
Let me know if it works.
Mar 04, 2009 | Dell TrueMobile 2300 Wireless Broadband...
Shared internet connection help!!!
are you using window xp for both pc?
Aug 25, 2008 | Computers & Internet
Guidance setting up a shared connection :)
1- set up router trough desktop
2-run program for wireless, after it gives you the IP ( which it already has, set user name and password for protection)
3-set up the laptop as a "Shared folder" along with the printer if there is one.
Aug 24, 2008 | Computers & Internet
Laptop can see the desktop where access point is connected and yet not connect on internet
The way this should be connected is..
Modem connects to DWL-2000ap (wan port)
Peterscomp connects to DWL-2000ap via ethernet
Laptop connects to DWL-2000ap via wireless.
May 15, 2008 | D-Link AirPlus Xtreme G DWL-2000AP...
My router doesnt seem to be Broadcasting the wireless connecition!
it may be that the router is not assigning ip addreses properly, and is duplicating the ip address on all pc's. or you have done the windows diagnose and repair or detect problems. Go to the properties of each wireless card in control panel>network connections and on the TCP/IP line click propertes again and ensure obtain ip address automatically is checked. Also go into the routers settings and ensure DHCP is enabled to give all pc's an automatic ip address. Restart all pc's and your router (not Reset) and you should get renewed ip addresses and be able to connect.
Sep 13, 2007 | SMC Barricade g SMC2804WBRP-G Wireless...
Computers & Internet Logo
373 people viewed this question
David Payne
David Payne
