FixYa.com
Tags:
Quantaray Tech-10 70-300mm f/4.0-5.6 for Canon EOS
I get an error 99 message (turn power switch to off... (by 4 users)
posted by CO585 on Apr 15, 2008
I have a Canon XTI and a Quantaray 70-300mm lens. When ever I try to use the lens, I get an error 99 message (turn power switch to off then on again or re-install battery). I spoke with a camera guy at my local Hunt Photo, who suggested cleaning the contacts on the lens with a pencil eraser. I tried it. It did not work. HELP!!!
This Problem has been added to the Share Your Expertise Page under "My Work Queue".
3 Other Users Have The Same Problem
Comment by wdwerries, posted on Sep 06, 2008
I get Error99 with Quantaray 70-300 on Rebel Xti. Seems to be image dependent. An obsessive engineer, I wanted to learn the limits of the camera. All worked well until I shot a palm frond in a clear sky - 1st error 99. Error consistent with that shot, but not seen in others. Tried all FAQ fixes, but none worked.
Went to ballgame in indoor stadium. 1st ~20 shots with lens were ok. Then sporadic Error99 for low-light extreme closeups. Slowly built to sporadic good shots under most conditions. FAQ fixes had no effect. Randomly changing metering mode worked for several more shots - almost like the processor built a metering profile, and then exceeded some limit.
At home under direct light (and full 24hrs later), photo'ed small piece of gray shale, and small piece of granite - beige with black flecks. Alternated shots in random order. Camera would NOT shoot the granite (Error99), and would always shoot the shale perfectly.
Canon lens has never given ANY error.
Canon has a problem they are not owning up to (or are trying to squelch 3rd party lenses). Any way to get Quantaray directly involved? Its in their business interest.
Comment by devis0306, posted on Jul 12, 2008
hi i have the same prob on my canon xti/400 d, using a 70-300 f 4.6, which i have had for 2 years. however this prob is only recent and didnt have a problem in the first year.
Comment by bryfoutz, posted on May 08, 2008
I am having the same problem, but my camera is the XSI. They told me to use rubbing alcohol, and it didn't fix the problem either. I called Canon and they said that lens isn't supported by Canon.
Solution #1
posted on Jul 07, 2008
Not Rated (0)
Guest
Guest
Rank:Apprentice Apprentice
Rating: 0%, 0 votes
I have a similar problem.  The contacts seem temperamental for the XSI on this lens.  But strangely, I've found as long as you aren't focusing in on a bright image, it works just fine.  The only thing I can figure is with a 300mm magnification is that it doesn't want to burn out the chip so it's a built-in protection of some sorts.  Try cleaning both the contacts on the lens and the camera body gently. Does the problem happen as soon as you turn on the camera, or mid shot?
Was this solution helpful? Show your Appreciation by rating it:
Can you Help with these Camera Lenses problems?
Camera Lenses
tamron adaptall
I have recently bought a tamron... Answer This...
Camera Lenses
Tamron SP 17mm F/3.5
I recently purchase what was... Answer This...
Camera Lenses
my chinese s3 mobile is showing...
My name is amal. I am having a... Answer This...
Camera Lenses
lens malfunctoin
The image in the viewfinder... Answer This...
Quantaray Tech-10 70-300mm f/4.0-5.6 for...
Quantary Tech-10 75-300mm use...
While indoors, I can focus and... Answer This...
Repair Service
Find Camera Lense Repairman Near You:
FixYa does not evaluate or guarantee the accuracy of any information provided through its proposed solutions, posts, or Expert Assistance Sessions. By entering this site you declare you read and agreed to its Terms. You may NOT copy or distribute the content that appears on this site without written permission from FixYa Inc.
© 2005-2008, FixYa, Inc. or its affiliates
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
