Question about Konica Minolta bizhub 250 All-In-One Laser Printer
Konica Bizhub 250 diagonal stripe (loss of color or tone)
My copies have a diagonal stripe (loss of color or tone) that appears like a series of bars, whether copied in color or black and white but my machine still appears to have at least half life on all meters.
  • Anonymous May 15, 2008
    black stripes through the sheet
  • 167 Answers
Sounds like it needs service.
The life expectancy meters are just general measurements. They only indicate when it is time for a Service Tech to come by a review the parts. If you are having that type of imaging problems you need a Tech to look at it.
Posted on May 29, 2008
My cannon mp258 cannot print, message show that ink to slow,and the ink indicator appear the Colored ink is almost empty .and also i try to photo copy black and white document but i cannot photo copy even...
Yes. You cannot use the printer even in black and white, until the color cartridge is replaced. They are designed to check the levels of the both black and color cartridges.
Oct 18, 2017 | Computers & Internet
I have a Samsung DVD-VR357. I get no color on vhs tapes. I only get black and white.Picture is good. DVD color is ok. When I copy VHS to DVD, the DVD copy is in black and white also. DVD copies from...
Are you trying to copy a comercial VHS tape to DVD?
If you are then macrovision copy protection system on either the tape or in the machine is the reason for the loss of colour.
There's not a lot you can do about it. If you want to copy commercial material you will need to transfer it to a computer and get a program to do it. But unless it's unavailable it is cheaper to buy the DVD version I have found and you will get better picture and sound too!
If it does it with a none comercial tape (ie something recorded of the TV). Then it could be a head fault or something else. In which case try cleaning all the heads guides etc first.
Jun 20, 2009 | Samsung DVD-VR357
A bar code stripe on the right side of the copy.
i'm not sure if you're talking about a solid black band or a bunch of little stripes running down page. does it happen when you run an internal report or only on copies? if its a black solid band, check and make sure the bluish colored tab on top of the drum is all the way to the left side. if its a group of fine lines, depending on whether it happens on internal reports or not, it could be the drum is going bad or you may have a bad scanner. write back with a little more info if this suggestion doesn't work.
good luck,
razors
Mar 18, 2009 | Brother IntelliFAX 5750e Laser Fax
White stripes on pages copied from ARM 205
If you changed your developer? Or did you change the Toner Cartridge?
White stripe? Check the charge on the drum, it might have a piece of dust on it.
take the charge out, (dont take it apart) hold it up to some light, you might see some dust particles hanging in the grid. If so, rub very lightly with finger, do not use a cloth to clean. Blow it with a can of air.
Clean the transfer charge as well
Usually replace those as it is such a pain to clean on the smaller machines.
if you need any further help let me know
Thanks
Nov 05, 2008 | Sharp AR-M205 Copier
Horizontal black and white lines are coming on copy
you don't mention whether the document you are copying also appears on the paper.If it does you could have 1 of 2 problems-
The drum cleaning system could be at fault or-
the fuser roller has picked up some **** easy test...... run copies and when the 1st copy edge appears switch OFF. This is a crash stop.Now examine the sheets in there.Is the stripe on the copy before the fuser (Heat) roller? If yes you could have a drum cleaning problem, usually fixed by changing the drum module.If no and the stripe appears after the heat roll, the problem is with the fuser system,dirty rolls etc. There are a number of other problems with stripes, but you have to start somewhere! If the document does NOT appear on the copy, forget all above, could be scan or ROS problem
Jul 20, 2008 | Sharp AR-5320 Black and White Copier
Installing washing machine motor P/N 35-5022, need wiring schematic to hook up to machine internals
Is there a white or black connector that clips on the motor switch? it should be an easy unplug and plug the new motor in.
I dont of any Manufacturer that uses single wire connectors any more.
Are you sure you got the correct motor?
Apr 22, 2008 | Maytag Legacy Series Top Load Washer
Error 9-363
NOTE: The problem occurs because of the trickle development system in the machine, making extended lengths of black and white copies / prints does not allow the black developer housing to purge itself of excess waste Toner (Dry Ink) and Developer. There are two solutions for the problem:
  • Make 1,000 copies / prints of a black and white job, then make 150 copies / prints of full color. Continue making 1,000 copies / prints of the black and white job, then 150 full color, and so on, until the entire black and white job is complete.
  • Make extended jobs in groups of 100 by making 100 copies / prints of the black and white job, then allowing the machine to cycle down (return to 'Ready') and making the next 100 copies / prints. Continue in this pattern until the entire black and white job is complete.
NOTE: The above solutions are based on jobs using 8.5 x 11 inch paper, single sided, with no more than 28% coverage.
Feb 18, 2008 | Xerox DocuColor 12 Printer
MFC-9840 prints vertical stripe ~2" from right edge on all color printouts
The first thing i would try to do is clean the corona wire on the drum unit. It might also be a faulty magenta cartridge.
Dec 07, 2007 | Brother MFC-9420CN All-In-One Laser...
or
  1. Power OFF the machine.
  2. Wait 30 seconds.
  3. Power ON the machine.
Dec 04, 2007 | Xerox DocuColor 12 Printer
Konica Minolta bizhub 250 All-In-One Laser Printer Logo
252 people viewed this question
Top Konica Minolta Office Equipment & Supplies Experts
Norman  J Weimar Jr
Norman J Weimar Jr
Adorjani Laszlo
Ben
Ben
Are you a Konica Minolta Office Equipment and Supply Expert? Answer questions, earn points and help others
