I was cleaning my projector in72 with compressed air and the little squirrel cage (plastic) blew apart I think the air spun it to fast does anyone know where I could purchase one of these about a 3/4 of an inch cage thanks
  • imopar Apr 15, 2008
    it is a infocus in72
  • 19,396 Answers
Which is make and model?
Posted on Apr 14, 2008
Rattling noise from under glove box when fan for A/C or heat is turned on is it the blower motor or the fan?
Your blower motor and squirrel cage (fan).
more then likely it is your plastic squirrel cage fan under the dash.
they are made of plastic and over time the lock nut or screw comes a bit loose and the plastic collet on the fan wears out allowing a lot of play between the motor drive shaft and the fan .
Or you may have had something fall through your defrost vents on the dash and down into the squirrel cage housing
Apr 29, 2014 | 2009 Mitsubishi Outlander
Mouse /debris in in squirrel cage
Usually! There may be other problems too - rodents LOVE to chew up wires! The squirrel cage is on the passenger side, and it is a labor intensive job. depending on your finances, it may be faster - and easier - to let a shop have the headaches!!
Jan 25, 2014 | Infiniti Cars & Trucks
Why does my ac freeze up
Hello, air conditioners will freeze either due to low airflow.....such as dirty filter, dirty evaporator coil, weak or not running blower motor. Also, a low refrigerant charge can cause the unit to freeze up.
Jul 09, 2012 | Danby Heating & Cooling
Take a long time for blower motor to get up to speed
The first thing I would do is to clean motor and squirrel cage. It would be best if you would remove it and take it somewhere that you had a air compressor to blow out motor ports and fins on squirrel cage. Most of the time you can remove by disconnecting modular plugs and removing two or more screws on rail that squirrel cage slids on.
If you can get it out you can use a fine wire brush to loosen dirt and dust from fins on cage then use air to blow out as much as you can.
Your motor may be getting worn so check the bearing by grasping cage and see how much it will slide side to side and if it moves more then about1/8 inch then you are going to need to replace it before much longer. Also make sure that the rim of squirrel cage is not rubbing on blower housing and if it is then loosen motor mounting screws and adjust ,then retighten screws.
I hope this helps you. Thanks
Jan 04, 2011 | Ruud UBHC Air Conditioner
Heater works fine when its turned on but stops blowing heat after 3 mins.
mine just did the exact thing. I took it apart and blew it out with an air chuck and it works like new again. a couple of weeks ago i used a vaccum and it work a couple of days and then did it again. The squirrel cage and heat elements were filled with dust. It was not easy taking apart but now i know to only take the bottom off. thanks
Nov 18, 2010 | ACE Dimplex (r) Compact Electric Fireplace...
Model#CPRB09XC7 Portable A/C. The exaust fan squirrel cage completly blew up.The moter fine#LS-53T1-4P(WK4-30T1-K08A) is OK.
You can buy a new squirrel cage just take the pieces with you and the model and ser# . I deal with Bakers but there are all wholesalers of A/C parts.
Aug 09, 2010 | Heating & Cooling
In Focus IN72
The capacitor that is blown wouldnot be a 150V but a 450V. Dannol, I think you should really double check that as you most probably could be wrong or it most probably is a typo error.
The correct capacitor is a 104K450 NIS T83. 100nf (0.1uf), 10% tolerance and 450V rad polyester type.
Jul 23, 2008 | InFocus IN72 Multimedia Projector
Mod ASU24C1
If the blower is made of plastic it does not have a set screw. You most likely need a new squirrel cage. They are formed to the shaft and have a compression ring that holds them in place.
May 28, 2008 | Fujitsu 24C1 Air Conditioner
IN72 psychedelic traces
have the same problem took mine apart for cleaning and inspected the bulb looks like bubbles in the bulb that will hold disorted images on the screen so im going to replace bulb
Feb 04, 2008 | InFocus IN72 Multimedia Projector
Televison & Video Logo
Top Televison & Video Experts
