Question about Dell ADA745 Computer Speakers
My subwoofer smells smoky and there's a humming sound..
Well i've just decided to listen to some music as always. I turned the switch on and all I hear is a humming sound.. Like close interference but a lot louder and it switches between the speakers and the subwoofer. Also, it doesn't smell right.. Smoky/Burning kind of smell..
My speakers are like the ones above but 2.1 and they're used when connected to my laptop.
Any suggestions as to what this could be guys? And whether it'd be able to be fixed?
Thanks for your help and feedback.x
  • Anonymous Aug 28, 2008
    When I turn the power switch on, I get this very loud humming. But I get sound from all the speakers except the one with the power switch and it does have a smoke smell.
  • Dell Master
  • 1,183 Answers
Well,
It best to call the manufacturer to get the speaker system replaced. As you see it smell bad , could be a burnt fuse at the back of the sub.
Posted on Apr 15, 2008
Slight smoky smell and freezer food/ice taste smoky
sounds like your motor is is burning out or someing inside the fridge is burn
Nov 19, 2013 | Kenmore Refrigerators
Humming sound cumin from my creative inspire 4.1 woofer
Make sure that you've fully pushed in the jack to the sound card.....maybe you've not connected the jack into the correct socket on your soundcard as there are usually 3 identical sockets...but only 1 is the correct one. Sometimes colour-coded green. Try it in each one in turn. If you have headphones, try plugging them in as you will hear sound in them when you've got the correct socket!
Apr 27, 2012 | Creative Labs Audio Players & Recorders
Hello Audio Gurus..This is my 1st time on here.. I always loved music and I have decided to raise the bar a little in terms of sound considering that I enjoy listening to music more then 2 hrs a day.. I...
No, the CV speakers are very efficient speakers. That means they create a lot of volume for the amount of power. I will start by saying you will be relatively happy but not blown away.
The HK is an alright HT receiver (very new and feature loaded). It makes a rather weak stereo receiver for it is made for a home theater environment. If you only have a pair of speakers (optimal for music listening) then you have paid for a bunch of other channels that will remain dormant. You would be best off to get a very high-power stereo receiver or integrated amp instead of your HK.
CV speakers are built to blast, but they sounds pretty good at the same time.
Feel free to ask me any audio related question, I've worked in the industry for a good part of my life.
Thanks!
Jan 05, 2010 | Cerwin Vega LS-15 Speaker
It is a klh powered subwoofer, which buzzes when plugged in, even though the power switch is set to "off"
Sounds like the grounds are screwed up. Try using a grounded wire for the subwoofer input. If that doesn't work, it sounds like something is internally screwed up, like the power supply doesn't fully power down. I guess besides buying a new amp, just connect it to a power strip where the switch is accesable and shut the sub off with the power supply.
Oct 10, 2009 | Audio Players & Recorders
Came home after a storm and smelled electric burning and heard a hum from the subwoofer. now i wonder what the problem is and is it worth getting fixed.
I had almost the same problem. I was Playing music and my speakers kept on shorting out, i smelled burning wires and i look in back of my subwoofers and there melted. i just simply replaced the wires exept with a thicker 14 Gauge wire. But i dont know if your subwoofer is damaged or not. but i would try changing the wires.
Oct 05, 2009 | Boston Acoustics PV500 Subwoofer
Sa-wx700 with no sound
If you are a rock music lover, chances are the speaker has burn out. try to turn on and place your ear near the speaker and listen for humming
sound. if no sound at all, then its the speaker
Jun 26, 2009 | Sony SA-WX700 Subwoofer
Yamaha sourround sound reciever HTR 5920- not working
Can you remove connection between the receiver and TV and then try ? If it still turns hums and turns off, then try disconnecting all the speakers and power it on. If it still turns off, then you have a bad receiver...Let me know..
Mar 20, 2009 | Yamaha 5.1-Ch. Surround Sound Home Theater...
Speakers humming. No reception.
The audio amplifier in the unit has failed, and that's what you smell. Turn it off and quit using it immediately - it presents a fire hazard. It might be possible to replace the bad parts. Depending on what it cost, you might want to take it somewhere for a repair estimate, but be prepared to learn it might not be fixable. Often the burned parts damage the circuit board as well.
Usually this happens in small stereo systems because of running them at high volumes for a long time. If you want to listen to loud music, you would be better off putting the money into a higher-power system.
Dec 08, 2008 | Audio Players & Recorders
Subwoofer heard when only B speakers selected
This is really weird. Normally, the subwoofer must be turned off when you turn on B speakers. But, hold on.. I have recently tried to do the same thing as you do, and the result is the same as yours. The problem is that you have to turn off A speakers completely when you activate Bs. If you have an A/B Speakers switch, first push the A to turn them off, after that press "B" to listen to music downstairs. I hope it works.
Apr 19, 2007 | Denon AVR-1603 Receiver
Dell ADA745 Computer Speakers Logo
507 people viewed this question
Top Dell Audio Players & Recorders Experts
jairo sanchez
Greg Cann
Greg Cann
Are you a Dell Audio Player and Recorder Expert? Answer questions, earn points and help others
