Question about Brother PPF-1820C Plain Paper Inkjet Fax
Want to change it to black and white printing only.
I would like to make my brother fax machine use only black ink so I dont have to buy colour ink cartridges.
  • elevenlotus1 Apr 14, 2008
    Fax Machine is a Brother PPF 1820C
    Master:
  • 555 Answers
A manual for your fax is available here, and will show you how to set your fax to monochrome mode.
Posted on Apr 14, 2008
We use our fax-1840C machine for black/white only, never for colour. we have installed both b/w and all 3 colour cartridges, but quite soon the fax says the (unused)colour cartridges are empty or dry and...
try by buying a new cartridges like the one you use before and clean first the print head to remove the smodges. see also you manual for compatibilites and instructions. ill find another solutions if this wont help you.
CHARCOIS
Oct 09, 2008 | Brother Office Equipment & Supplies
Can i print black prints without refilling the color ink cartridges? my color cartridges are empty but the black is full. The printer wont let me print black and white files.
Not certain on that model of Brother but on mine I was able to get it to print by changing the settings in "Print Setup" If you change these so that it can only print in black and whiye, it won't look for the colour cartridge, like mine didn't
Jan 24, 2010 | Brother MFC-5440CN All-In-One InkJet...
I changed the ink cartridge the black one but it still says cartridge empty I unplugged it and it still sais the same thing
My MFC-420CN acts up occationally. Remove the new cartridge, hold it as you would to install it, Rotate it to the right about 45°. Snap it with the back of a finger (dislodges any air bubbles in ink feed). Reinstall cartridge (ensure it is fully seated. This works for both Brother cartridges and the eforcity cartridges I've been using for the past couple of years. HTH
Lou
Oct 17, 2009 | Brother MFC-685cw InkJet Printer
Color has gone a little crazy. Printing in green etc. How to fix?
Hi..
Take the ink cartridge out and clean it with little alcohol and cotton, and make sure the cartridge is reseated properly.
Let me know.
Thanks
Smith
Aug 20, 2009 | Brother Office Equipment & Supplies
How to use black only cartridge on a brother LC-1000BK printer/fax/scanner machine
i haven't got a brother but most systems are the same if you got to print setup on the document on the bottom of the box that comes up there is printer click on that then on the next box you will see properties click that and you will be given the choice of colour or black and white hope this helps regards Jim
Apr 26, 2009 | Office Equipment & Supplies
I don't use the color printing yet the color cartridges are empty
It's all a scam. I have the same problem and I called Brother and they told me that the machine uses color ink to clean itself. It costs more to replace these color cartridges then to buy a new one, which is what I'm going to do. Buy a black and white from a different company. It's all a scam to get you to spend money on their color ink that you don't use.
Mar 25, 2009 | Brother IntelliFax 1860C Plain Paper...
I Need to Print
Sadly in a word, 'No'.
Here is the exact answer from Brother:
Your Brother machine is designed to stop ALL printing operations
(printing from the pc, printing received faxes and printing copies or reports) when any of the ink cartridges are empty. This is to ensure the life of the print head and maintain premium print quality. If the unit were to continue printing, print jobs and cleaning cycles would suction air from the dry cartridge and damage the printhead. Even if you print in black only or change the print settings to MONO or GRAYSCALE to avoid printing in color, the programmed cleaning cycles would still suction the dry cartridge, because they are programmed to clean ALL the ink nozzles.
The only way to continue printing is to replace the empty ink cartridge or cartridges.
While memory is available, black and white faxes will continue to be received into memory. If a color fax is being received, the Brother machines HANDSHAKE will request the fax be sent as black and white fax.
All faxes received into memory will automatically print once the ink cartridge is replaced.
NOTE: Brother strongly recommends that customers do not use generic ink or refill their Brother ink cartridges. Using non-Brother supplies may affect the hardware performance, print quality and machine reliability since the ink formulation in genuine Brother ink cartridges prevent smearing and clogging of the print head. The Brother limited warranty does not apply to any problem that was caused by the use of unauthorized third party ink and/or cartridges.
Nov 26, 2008 | Brother Multi-Function Center MFC-240C...
I cannot print but i have only the black cartridge but i dont have the yellow cyan ang midget
Most modern printers use some colour when printing Black and therefore will not print if ANY ink cartridge is showing as empty.
Unless your printer has a setting for using Black ink only (this is not the same as printing a black and white document), then you will need to purchase and install the colour cartridges before printing can take place. The good thing about this is that very little colour ink is used when printing black and white documents - so they should last a long time.
Good luck.
May 09, 2008 | Brother Multi-Function Center MFC-240C...
Fax does not want to print
No the machine uses some of the colour ink when printing faxes, mostly cyan.
Apr 23, 2007 | Brother IntelliFAX 1940CN Plain Paper...
Brother PPF-1820C Plain Paper Inkjet Fax Logo
63 people viewed this question
James Cagle
James Cagle
Samyfam
Samyfam
Jim Keysor
