Question about Logitech Extreme 3D Pro Joystick
Etreme 3d pro
I cant get it to work, Iv'e got a Pent, 4 1.8GHz with 2.0 GBs of Ram and it keeps showing me '\LWEM29ee.rra'. and I don't know what to do.
  • Torch68 Apr 18, 2008
    Thanks it works great now .
    Now if I could just learn to Fly....
    Torch68
    President:
  • 2,712 Answers
First download the latest driver from http://logitech.com.
Next do a clean boot as outlined here:
http://logitech-en-amr.custhelp.com/cgi-bin/logitech_en_amr.cfg/php/enduser/
std_adp.php?p_faqid=228
Next do a clean install of the gaming software as outlined here:
std_adp.php?p_faqid=622
Should work now..
Posted on Apr 17, 2008
I want to add memory up to 4GB. I have 2 x 1 GBs modules. can I add 2 x 2 GB's and remove the 2 x1 GBs? Also willing to move to Windows 7 64bit in order to move above the 4GB limit. Could I then mix the...
The memory specification for your workstation is here:
http://www.crucial.com/store/listparts.aspx?model=Precision%20Workstation%20T3400
You can remove the 1GB modules and replace with 2*2GB modules to give 4GB and you are correct in that you will need to use a 64-bit operating system to fully utilise 4GB or more.
Hope this helps,
Please rate my answer,
Chris
Mar 09, 2011 | Dell Precision T3400 375W 32bit Computer...
We have just purchased 18 wheels of steel bigbcity rigs. The cd installs but we cannot bring up any of the three games nor does it show an icon. The package states it is a pc dvd-rom. We are running...
Is Big City Rigs: Bus Driver by ValuSoft you are refering?
OS: Windows® XP/Vista
Minimum Requirements:
•Pentium® 1.7 GHz or similar processor
•512 MB RAM
•DirectX® Compatible Video Card
•128 MB Video RAM
•DirectX® 9.0c
•2 GB Hard Drive Space
•Mouse
Recommended Requirements:
•Pentium® IV 2 GHz or similar processor
•512 MB RAM
•3D Video Card with at least 256 MB Video RAM
•DirectX® 9.0c
•Mouse
Do your PC hardware specification (Recommened requirement) fit the above requirement needed to run the program?
If so, "Right click the setup and install the program as "Administrator"
Update your Direct X 9, to the latest version.
Hope it helps.
Jul 02, 2010 | Computers & Internet
My samsung v25 is too slow for my likings cant do nought on it it takes ages and cant download as it takes ages how can i solve all this
Best bet would be to add ram. Open the back panel and read 2 numbers. The PC___ and the amount of ram in MB. you can go about buying more ram that way though you must have the same PC number like " PC 2700 " but you can usually get 2 GBs in a machine if its pc 2700 or above.
Apr 20, 2010 | Samsung V25 XVC 2800 Notebook
I have recently upgraded the memory on my sons scenic p300 but cant get the system to boot ...... any ideas
Did you use PC2100 (266MHz), PC2700 (333MHz), or PC3200 (400MHz) RAM? Also, the RAM has to be "Unbuffered" RAM. Unbuffered means that the memory is accessed directly from the Memory Controller and not being cached. Explaining all of that will take a long time, so I won't try to attempt that. Just know that the RAM you use has to be unbuffered. Also, Your computer can only handle a maximum of 4 GBs of RAM. Do you have another computer available that you can try your new RAM in? If so, then I would try putting it in another computer to see if it works there. If it does, then perhaps the BIOS of your motherboard needs to be updated. You can go to Fujitsu to check if there are any available BIOS updates. Be very careful when Flashing (updating) your BIOS. If not done correctly, or if it is interrupted after the Flash begins, then you could end up with a paper-weight. Oh, just in case you don't know this: RAM is highly sensitive to static electricity, and electro-static shock (the poke you get when you touch certain things). If your RAM gets a static shock\charge then it will likely be junk afterwards!
Apr 03, 2010 | Fujitsu Siemens SCENIC P300 PC Desktop
Big city rigs
first check if your computer answers the following requirements:
Windows® XP/Vista
  • Pentium® 1.7 GHz or similar processor
  • 512 MB RAM
  • DirectX® Compatible Video Card
  • 128 MB Video RAM
  • DirectX® 9.0c
  • 2 GB Hard Drive Space
  • Mouse
  • Pentium® IV 2 GHz or similar processor
  • 512 MB RAM
  • 3D Video Card with at least 256 MB Video RAM
  • DirectX® 9.0c
  • Mouse
if you do, please tell me exactly what happens when you try to install the game
Jan 25, 2010 | ValuSoft 18 Wheels of Steel: American Long...
RAM is installed, but lap top does not read it
The 6735s requires DDR2 SODIMM chips clocked at 800 MHz and they must be installed two at a time (so a 2 Gb chip won't work - you need 2 1 Gb chips. Installing 2 + 1 Gbs will give you 2 Gbs only, (1+1), that is if the PC even boots at all; and so on).
Also, not all operative systems will read the full amount of RAM installed.
Oct 24, 2009 | HP Compaq 6735s Notebook
Asrock P4V8+ freezes after ram checking
Try going into the BIOS and selecting safe or minimal settings/options save and reboot. If this works go back to BIOS and make changes one at a time until it may not work again, then you will know which option is causing the system hang ups. My guess is also your motherboard is SATA 1 capable (1.5
gbs) not SATA 2, in which you could purchase a separate controlller card for your HDD. Good luck.
Jul 02, 2009 | Intel D865GBF Motherboard
I have an Elitegroup KT600-A motherboard (System model KT600 8236) manufatcturer VIA Technologies, Inc. with total physical memormy 640K. Processor is x86 Family 6 Model 4 Stepping 2 Authentic AMD ~998...
Hello, according to your boards manual page 38 you will have to use unbuffered memory (non-ecc) and depending on which OS your are gonna use, it might address up to 3 GBs of (SDRAM) my personal preferrence is 3x1 GBs with XP Pro 32 bits. The CPU you mentioned should work just fine, and with the added memory your rig should provide you better performance, hope this little bit of info helps.
May 09, 2009 | Intel Desktop Board D845GLVA...
Intel motherboard crash
try to check if your memory (RAM) is compatible with your board. run dxdiag to see your computer specification
Mar 15, 2008 | Intel Motherboard
Logitech Extreme 3D Pro Joystick Logo
435 people viewed this question
Top Logitech Video Game Consoles & Games Experts
Zhenya Ogorodnikov
Alun Cox
Are you a Logitech Video Game Console and Game Expert? Answer questions, earn points and help others
