Question about Dishwashers
No water in the wash cycle - Dishwashers
  • 19,396 Answers
Check that the pump is working
Posted on Apr 14, 2008
LG Turbodrum DD 8.5kg WT-R852 washing machine, will not completely fill with water to water, to initiate the wash cycle, wash process stops there.
THE WASHER IS OBVIOUSLY HAVING A PROBLEM DETECTING THE WATER LEVEL? IT DETECTS AS FULL WHEN ITS NOT AND THEN GOES INTO DRAIN CYCLE? THE FILLS AGAIN? I would suspect the water pressure switch but if it was detecting a full cycle it would sent it into wash cycle? the water inlet valve only allows the amount of water it is told to send in and does not control the amount or drain cycle. Im not sure here but Im thinking maybe the water level switch may be flawed, the one that has low-medium and high? all these can be checked with a multimeter
Mar 01, 2015 | LG Washing Machines
Cold water won't stop before rinse cycle
if it fails to stop running only at the rinse part of the cycle it is probably in the timer as the solenoid valve has to cut the water off when the washer fills for the wash cycle too. fills for wash cycle and cuts off water, washes and drains, refills for rinse cycle and water just keeps running? does this every time you run it? that's in the timer. bad solenoid (water inlet valve) would keep running even on wash fill up. hope this helps.
Feb 25, 2014 | LG WM2688H Front Load Washer
Please describe a typical washing cycle to me on the RTW4440XQ Roper 3.1 Cu. Ft. Top-Load Washer, please.
The typical cycle is;
fills to selected water level
agitates wash cycle
drains wash water
spins wash cycle
fills to selected water level on rinse cycle
agitates on rinse cycle
drains rinse water
spins final time
end of cycle
Aug 08, 2011 | Roper Washing Machines
My Maytag Neptune will not go into the spin cycle, instead the letters "nf " come on the display. What can I do to prevent this and to have the cycle completed?
NF = No Fill the control board receives signaling for the washer during the water fill cycle. With most cycles the depth of water is around 3.5 inches in the wash basket. I know a Bulky Wash cycle selection will fill the wash tub to a high fill which is about 7.5 inches of water in the wash basket.
Is the washer filling the machine with any water? Do you hear water entering the machine? If you are doing a cold water fill and there is no or very little water in the wash basket with the NF error code. Try a Warm or Hot fill and see if the machine will fill and start the wash cycle.
Assuming you are doing cold water wash loads. You could have a water line block at the inlet screen or a failed cold water inlet valve which will not open. Try the above and let me know the results..........Rich
Sep 13, 2010 | Maytag Neptune FAV6800AW Top Load Washer
We just installed a new kenmore dishwasher yesterday. Model 13242 It has been running for almost2 hours and is still on the washing cycle--no water in it however--is this normal? I'm in a bit of a panic as...
THAT IS NOT NORMAL!!!!!!! A normal wash and dry cycle will take approx. 2 hours in length including drying cycle.
You should see that water has been present in the machine within the first 2 minutes of the start of the wash cycle, you should also be able to hear the water entering the wash tub.
The fill valve or water supply seems to be the issue, if the water doesn't enter the tub then the controller won't proceed witht the wash cycle. Double check your water supply tube / hose to make sure there is water present at the connection to the dishwasher.
Aug 08, 2010 | Kenmore Dishwashers
It fills while it is washing you will see a slow build up of water but it will start the wash cycle before all the water is in
Apr 19, 2008 | Whirlpool Duet GHW9150P Front Load Washer
No water on wash cycle
Feb 02, 2008 | Dishwashers
Dishwashers Logo
69 people viewed this question
Top Dishwashers Experts
