This is the step you will use to repair your ice door seal that is loose.
There are screws under the fold of the
freezer door gasket that holds the brace for the gasket in place. Lift
the rubber gasket to expose the screw head, one section at a time. Just
loosen the screw, and do not take it completely out.
As you loosen the screws, one section at a
time, carefully remove the old gasket. At the same time, fit the new
gasket into the groove. Make sure your new gasket is lined up properly.
Continue around the freezer door, unloosening
the screw, taking out the old gasket and fitting the new one in.
Tighten the screws into place. This may have to be done once the entire
gasket is fitted into place.
Check the seal by closing the door. You should have a nice, tight seal.
Good luck.
Read more: How
to Fix a Freezer Door Seal | eHow.co.uk http://www.ehow.co.uk/how_4855248_fix-freezer-door-seal.html#ixzz0rY7rn3O8
Read more: How
to Fix a Freezer Door Seal | eHow.co.uk http://www.ehow.co.uk/how_4855248_fix-freezer-door-seal.html#ixzz0rY7gYaZ2
Read more: How
to Fix a Freezer Door Seal | eHow.co.uk http://www.ehow.co.uk/how_4855248_fix-freezer-door-seal.html#ixzz0rY7JfY8i
