Question about KitchenAid KAWS750L Top Load Washer
Kitchenaid washer My washer does not want to turn on, it has power,you can hear it clicking and it sounds like it is calling for water. Kitchenaid model# kaws750jq4 ????
3 Suggested Answers
Lumpy816
  • 246 Answers
SOURCE: how do i open top of kitchenaid washer
To open the top of the washer, you must first open the console. Where the bottom of your console meets the top of your washer, you should find a screw on both the right and left hand sides. After removing these screws, pull the bottom of the console to you then rotate it up. Where the back (dull silver) panel meets the top, you should see two brass colored clips. The trick to getting these off, is sticking either a screw driver or pair of needle nose pliersdown where the clip goes into the top. While simultaniously pushing down, push the top of the tool towards the rear of the machine. Once you have the clips off, the front, sides and top will all come off as one assembly(your cabinet). Slowly start to pull the cabinet towards you grasping it at the top. You will have a couple of the small black hoses at the top still connected. Since it is difficult to describe, as you are pulling the top of the cabinet towards you, look for the hoses that start to get tight. A pair of pliers or channel locks will squeeze the clamps enough to allow you to get the hoses off. After you have these disconnected, slide the cabinet slightly forwar and you'll be able to lift it out of the way. A common source of leakage on these is one of the black hoses that goes down to the tub. If it pops off, you will get water on the floor nearly every cycle. Check your dispensers to make sure they are not plugged and causeing an overflow leak. he remaining clprits are your pump (white plastic on the bottom center, the hoses going to it and possibly the tub itself. Good luck and message me back if you need anything else.
Posted on Jun 30, 2008
  • 1028 Answers
SOURCE: washing machine won't stop filling with water
if it keeps filling when unplugged replace fill valve if shuts off ckd pressure switch and hose to switch from tub
Posted on Nov 19, 2008
Kitchenaid dishwasher imperial 21
Take the kick panel off under the door and see if the technical spec sheet is there. That lists all the diagnostics that you can run
Nov 20, 2013 | Dishwashers
Turn on dishwasher hear noise solenoid clicks water valve works but no force of water to turn tines and no clean.
Sounds like you may have a bad solenoid valve. you can check this by opening line that feeds the valve to see if you have sufficient water flow. GET SOME TOWELS READY THIS MAY GET A LITTLE MESSY!
  1. turn off the water valve that feeds the dishwasher.
  2. remove the line to the dishwasher solenoid valve.
  3. slowly turn water back on that feeds the dishwasher.
  4. verify sufficient water pressure flows onto the towels.
Dec 30, 2010 | KitchenAid 24 in. KUDP02SR Built-in...
Kitchenaid Dish Waher KUDI01ILBS1 won't run from control panel
Sounds like the control is bad. Turn off the power, remove the two screws at the bottom that secure the kick panel. Remove the kick panel and look under the machine for a folder up tech sheet. This will tell you how to get the machine into diagnostic mode. Follow the instructions exactly and it will help confirm whether it is the control.
Jan 15, 2010 | KitchenAid Washing Machines
My KitchenAid washer will agitate, but the upper agitator assembly is not turning and I hear what sounds like marbles moving/slipping. Can I take that top piece off to look at it?
Based on your description, the problem is likely the self-rising tube that comes from the base (bottom) water feed tube. It may not be rising to engage the top assembly....
If it fails to rise all the way, the water will just spray into and on it and cause it to wobble versus rotate.
Pull up on the bottom feed tube - just to confirm that it will move freely...... (food, soap scum and age can prevent it from moving freely.) Clean and retry the washer.....
Nov 07, 2009 | KitchenAid KAWS700L Top Load Washer
Kitchenaid no water, but ice
first thing i would check here is my water resivoir, on these models it has a tendency to freeze,, hit the tank and upper line with a hair dryer for several minutes then give the water a try....
barring that it may be time to change your water filter even if the sensor has not picked it up yet
Oct 26, 2009 | KitchenAid Superba Architect KSCS25INSS...
KHWS01PWH Front Load Washer stops between cycle and will not drain out water.
can you hear the drain pump turn on. it maybe plugged. or failed. try here www.techray.com click on the guru guy and select your model. also there is a repair manual that can assist you in repairing the pump.
Jun 22, 2009 | KitchenAid KHWS01PMT Front Load Washer
Pump Replacement for Washer??
yes it is the pump motor, if you say when you close the door, it clicks but can you hear the motor humming, this is a sign the motor is seized up and the power is actually going to the motor, or test with and electric tester,, it is the pump motor I started typing before reading the whole statement,, good luck
May 30, 2009 | KitchenAid KAWS850L Top Load Washer
Does not woork
Has the water drained by the time the dishwasher powers off?
The clicking sound is probably the (failed) pump motor and will require a service call or replacement of the unit.
Mar 27, 2009 | Maytag MDB9600A Jetclean II Built-in...
KitchenAid KAWS750L Top Load Washer Logo
85 people viewed this question
Top KitchenAid Washing Machines Experts
kj henriksen
kj henriksen
gbob59
Mike
Are you a KitchenAid Washing Machine Expert? Answer questions, earn points and help others
