Question about Dryers
Need to replace dryer vent-internal and external-on a Kenmore Series 90 electric dryer. What parts do I need, and where can I get them?
    President:
  • Dryers Master
  • 2,651 Answers
Local hardware store will sell, you want to get solid (or rigid)vent if possible its a standard 4inch for dryer venting
Posted on Apr 15, 2008
Kenmore 90 Series electric clothes dryer thermostat fuse had no continuity. Replaced the two fuses the parts place sold us. Turned it on after repairing, did heat up but then blew out the same thermostat...
I would say a venting issue, here is a thread, hope it helps Tim:
http://forum.appliancepartspros.com/dryer-repair/19493-dryer-blowing-thermal-fuses.html
Dec 23, 2010 | Kenmore 659 Electric Dryer
Need help with gas dryer Kenmore 90 series serial
Check the lint caught in the exhaust vents. If it is clear replace the spark ignitor if no click is hear upon starting up
May 14, 2010 | Kenmore 73952 Gas Dryer
Kenmore series 90 electric dryer: exhaust air is
that's normal,obviously you haven't cleaned out your dryer and vent line,nobody ever tells the customer when you buy your dryer that it should be cleaned out at least once a year so you don't have a fire more so if it's a gas dryer with an open flame inside the dryer,you gotta vac out the inside where the motor is,clean out the duct that the lint filter slides into and blow out the vent line,i use a leaf blower to clean out the vent line,take it off the back of the dryer,stick the leaf blower in the line if it's a long run if it runs through the wall and to the outside flapper and blow all the **** out of it,also if you have a shop vac put it on blow and blow off the motor,you won't believe how much lint comes off the motor even though it looks clean,so vac out the inside of dryer,clean out the lint filter duct and blow out the vent line
Dec 18, 2009 | Kenmore Dryers
Kenmore Series 70 Dryer
I'm not familiar with your dryer model but general advice regarding dryers with the problem that you have described would be to ensure that any filter on the outlet is clean, whether it be a condenser or traditional external vent.
Ensure, if it is vented rather than condensing (only connected to a drain) that the vent tube has clear access to expel the damp air circulated during the drying process.
If the wash load is heating to a substantial temperature in the dryer, it isn't the element causing the problem.
May 07, 2009 | Kenmore 60172 Electric Commercial Dryer
Kenmore Electric Dryer Can't replace heating unit
I removed the deflector and duct from outside the house, disconnected the hose, attached the hose to the dryer, passed the hose through the wall as the dryer went back in, then reattached the hose to the duct/deflector and reinstalled the duct/deflector
Feb 09, 2009 | Kenmore 659 Electric Dryer
Kenmore 90 series not drying.
remove the ventin from behind the unit you need to replace and or clean your vent !!!!!
Jan 16, 2009 | Kenmore 62602 Electric Dryer
Kenmore 90 series electric dryer blowing cold air only
1st check the breakers
2nd check wiring in back to see connections are secure.
3rd check element. It would be burned in two.
4th check thermal overload switch which is located underneath top of dryer. Easy to remove top. Probably 4-6 screws.
Jan 15, 2009 | Zanussi TC7102W Electric Dryer
Kenmore 90 Series Gas Dryer that drys for 10 mins & shuts off...
Check the vent pipe going to the outside of the house, including the vent louver, to make sure the pipe is not partially or fully clogged with lint.
Your symptoms are a classic description of reduced or no airflow from the dryer.
Jan 09, 2009 | Kenmore 62802 Electric Dryer
Kenmore 90 Series Dryer will not DRY
first check the vent outside to see if it is blowing air out strong, then check for heat.
Dec 24, 2008 | Kenmore 62602 Electric Dryer
Dryers Logo
213 people viewed this question
Top Dryers Experts
