Question about Apple iMac M6709LL/B Desktop
How to connect to dsl
I'd like to use my old bondi blue iMac as a print server for an HP 3100 photosmart printer by hooking it to my 2wire wireless DSL modem.
  • MNTexan Apr 14, 2008
    forgot to mention the iMac is on OS8.6
    Mentor:
    An expert who has written 3 tips or uploaded 2 video tips.
  • 199 Answers
You need to install either an "airport card" in your system or if you already have one in your computer, you need to download "airport" from the apple website. This is the only way MAC's can receive wireless signal.
Posted on Jul 17, 2008
I have an iMac OS X Yosemite and an HP photosmart 5520 wireless printer. The printer will no longer print and puts all documents in the print queue. I've tried removing/ adding the printer etc.
Try setting up the wireless from USB connection. See http://support.hp.com/us-en/document/c03278373/.
Click on OS X v10.10 Yosemite, OS X v10.9 Mavericks and OS X v10.8 Mountain Lion and follow the steps
When you get to step 3, choose Option two: Wireless setup using a USB connection. (There is a video as well)
Hope this helps.
Jun 13, 2015 | HP Office Equipment & Supplies
Hook up to iPad
You can connect the printer on Wireless to the iPad using third party Apps from Apple store.
For IOS 4, you can use native apple app "Airprint" to print directly through wireless.
Check this link to see compatible printers that support Airprint.
http://support.apple.com/kb/ht4356
Dec 21, 2011 | HP LaserJet 3100 All-In-One Printer
Imacwill not print word
Is there a printer installed on the iMac?
Is your account allowed to Print?
Dec 11, 2011 | Apple Mac/iMac&iPod Speakers-(Bondie-Blue)...
How do I connect my wireless laptop to the hp photosmart 3210?
If the printer doesn't already have network capability, you'll need to use a USB print server. Here's an example. You connect the server to one of the router's wired ports, and then any network computer (wired or wireless) will be able to print to the printer.
Jan 20, 2011 | HP Photosmart 3210 Printer
HP Laptop does not connect to internet unless directly
Hello dstoller,
You description is very confusing to sort exactly what is or isn't happening.Let me try to sort out what you have:
You have a Laptop
You have a Desktop
Desktop has a printer attached
You have a DSL modem with a wireless router
Laptop via ethernet: Good
Laptop via wireless: Not Good?
Desktop via wireless: Good
Not sure exactly what you are needing help with...
- Vincent
Still not sure what
Nov 22, 2008 | 2wire (1000-000005-002) 802.11g/b Wireless...
2WIRE wireless router/DSL from AT&T
unless this is a wireless enabled or lan RJ45 connectable printer you cannot, the pc that the printer is connected to must be on at the time of the printing.
Wireless printers have their own arial and allocated ip address, Lan RJ45 connective printers can be connected to the router.
Sep 15, 2008 | 2wire (1000-000005-002) 802.11g/b Wireless...
How do I set up a home network without internet?
Hi
By default, your wireless connection for your 2wire 1000HW is enabled.Assuming that everything is installed properly in your laptop ie wireless cards etc. than you can view your wireless connection using Dell Wireless connection tool and HP wireless tool. Your know its your network when it says 2wirexxxx {x=combined numbers}. To locate the built-in, 10-digit wireless encryption key for your system, please look at the bottom of the product [2wire] near the bar code label - looks like this : [xxxxxxxxxx].
If you want to access the 2wire Graphic Unit Interface ,you can access it by opening your browser and on your address bar type in homeportal- assuming you are able to connect to your 2wire wirelessly. You can view your network and change you wireless settings. This may also help you :
http://shastademo.2wire.com/rgw3-3/rgw/3-3/homeportal/network/wireless_settings.html
To connect your printer you must have a Print Server [ dep[ends on what model of laserjet you are using } and connected to your printer. Again you will need the encryption key to get it running. You must share your printer on each laptop by going to control panel and share it . In there you willl have the chance to change and modify the settings. You can also use the Windows File and Sharing Wizard. to get it both running.
Hope that would help you a bit. Pls feel free to post your questions in Fixya for further assistance.
Wish you all the best.
Cheers.
Jun 11, 2008 | 2wire HomePortal 1000HW DSL Modem and...
D-Link DP 311U wireless setup
Had same problem. Got it to work!!
I have DLink DP-311U and 2Wire Gateway router/modem 2701HG-B.
Solution: Connect DP-311U to router via network cable.
Then you can see it either with PS Admin or with browser http://192.168.0.10 should be default IP address of DLink Print Server. Set Connection Mode=Infrastructure, ESS-ID=2WIRExxx (xxx is your number of the router) - this is your network name, and wireless channel=1.
And the most important - change your IP Address to 192.168.1.xxx - xxx=choose a number over 64 if it's not taken already.
On your Gateway page: http://gateway.2wire.net/xslt?PAGE=J46&THISPAGE=A02_POST&NEXTPAGE=J46
Set Network Name=2WIRExxx, WIreless Channel=1, enable SSID Broadcast, Disable wireless network Security.
Once you get those numbers in, check connectivity with above programs with cable connected, or typing new print server IP address in browser. Then disable cable and check again. You should be able to see the box. Then connect print server to printer and make sure your printer settings on computer point to new IP address.
Feb 09, 2008 | D-Link DP 311U (DP-311U) Print Server
Wireless G print server Model # WPSM54G
Reset the Wireless print server , and run the setup cd once and check..press the hold the reset button for 60 sec with the power cable connected , that would properly reset your print server and then try to install it..contact linksys support for live assistance over phone 1800-546-5797
Jan 21, 2008 | D-Link DI 514 Wireless Router (DI-514)
Apple iMac M6709LL/B Desktop Logo
88 people viewed this question
Top Apple Computers & Internet Experts
Paul Carew
Martin Buck
Martin Buck
Paul Bade
Are you an Apple Computer and Internet Expert? Answer questions, earn points and help others
