Question about Vacuums
I purchased a Pro Heat self propelled Bissell rug cleaner model 7950 from Target wherehouse on 4-26-06. I used it once and all was fine. The next time that I went to use it the smart mix for the cleaning formula would not dispense formula.I called Bissell consumer services and was told to take it to Starks Vaccumn in Sherwood, Or. That was on 10-30-06 They said that it was working so I tried it again and not a drop of formula was or has been used since.I took it back 2-13-07 and the replaced the smart mix dial still didn't work. They said it was working but not so.I have used it a couple of times but only plain hot water. I am at a standstill to what to do. It should work more than one cleaning. Please inform me on what to do.
    President:
  • 1,673 Answers
I assume that it is spraying water? Is the smart mix knob turning freely from one point to the end? If not then there is a problem with the smart mix asm. With liquid in the soap bottle, push the valve in to see if liquid comes out ok, couild be that the valve is bad. Is the seal on the valve at the bottom of the bottle, it has to be on that and not just sitting in the hole. You might try running a mix of water and vinegar thru it, maybe it is clogged up.
Posted on Apr 15, 2008
Bissell pro heat 2x manual
Here is the Instruction or User Manual for the 7910 and the 8910 series machines
Here is the Instruction or User Manual for the 8920, 9200, 9300, 9400, series machines
Sep 30, 2012 | Bissell Carpet Cleaner Powerbrush Deep...
Bissell ProHeat Rug and Floor cleaner. Won't
Here is a tip that will give you all the information you need to fix your BissellProheat Vacuum Problem.
Bissell Proheat Upright Wet/Dry Vacuum Problems
heatman101
sf
Oct 20, 2009 | Bissell 9500 ProHeat 2X CleanShot Upright...
Instruction booklet for bissell pro heat rug cleaner
heatman101
wqert
Jul 09, 2009 | Bissell ProHeat Turbo Deep Cleaner Upright...
I have a Bissell Pro Heat rug cleaner, it runs but no water sprays.
heatman101
578yur
Jun 13, 2009 | Bissell 8910 ProHeat Clear View Upright...
Can't get Bissell carpet cleaner back together
I've purchased 2 of these both are broke again, although I may fix one again and give it away instead of throwing it in the trash. You can tell by all 10 pages on this site that these machines are just **** that is poorly designed. Just ordered a Rug Doctor Mighty Pro from Kohls with 30% off for $503. You won't even find 1 problem on this site on a Rug doctor. Also you can research them as I did and 98% of their owners was very satisfied, alot of whom used bissell prior to Rug Doctor. You will also see that the performance is way, way better and not even close on cleaning.......
Feb 10, 2009 | Bissell 7901-1 ProHeat Scotchgard Upright...
Bissell proheat self propelled series 7950 won't spray water and pump belt isn't broken.
I'm having the same issue and it was the pump. The metal drive gear sheared off of the plastic pump shaft. I JB Welded it back together, now I just need a schematic to reassemble the cleaner.
Sep 02, 2008 | Bissell 7950 ProHeat Upright Wet/Dry...
Bissel pro heat model 8910
Go to http://bissell.com/images/UserGuides/7901.pdf
This is in pdf format so you need adobe reader to get it, which is free on the net.
Aug 29, 2007 | Bissell 7901-1 ProHeat Scotchgard Upright...
Vacuums Logo
129 people viewed this question
Top Vacuums Experts
AskDyson
AskDyson
D. Floyd Kolb
D. Floyd Kolb
Are you a Vacuum Expert? Answer questions, earn points and help others
