Question about Dryers
Dryer does not dry replaced element and it still does not dry
  • whitemoco Apr 14, 2008
    this unit is a maytag peforma dryer
  • 319 Answers
Please check your exhaust vent outlet that carries dryer exhaust (warm moist air) for blockage.
This blockage could be any where in the line from the dryer itself, in the line (s) or the outlet leaving the dwelling.
Please let me know if this is the problem, if not, then we will dig a little deeper!
Brian
Posted on Apr 14, 2008
  • Brian Berndt
    Brian Berndt Apr 14, 2008
    In order to do this task you may need to remove the dryer vent line from behind the dryer. This may be aluminum or plastic. It may be diffucult to access all of the lines leaving your dwelling.
    In one case, I found a line that was full of water from rain, and was not allowing exhaust to vent, which causes the dryer to not be able to dry! This was not the homeowners fault, but due to improper installation by the builder.
Electric dryer tumbles but does not dry clothes on any setting. dryer is only 4 yrs old.
Heating element has gone bad. You need to unplug unit. remove back, then find heating element and remove it. Look for what looks like broken springs, if found replace element. 99% of electric dryers not drying are the heating element. Cost around $50
Sep 28, 2010 | Dryers
Electric Dryer replaced element and thermostat / drying slow
Is your washer spin working. things may be going in to wet. Check and get back to us. thank you
May 19, 2010 | Whirlpool LEQ9858L Electric Dryer
Dryer will not dry - hte heating element has just
check the hi-limit and cycling switches on the element case and the thermal fuse on the vent ductwork
Mar 12, 2010 | Dryers
My dryer does not get hot enough to dry the clothes.It takes about 80 minutes to dry on high heat.
If this is an electric dryer, it would appear that you have a broken dryer element, which would account for the extended drying time.
You can access the elements from the back of the dryer by removing the rear panel. Be sure to unplug the dryer first, to avoid getting an electric shock. You will need a multi-meter to check the continuity of the two (2) dryer elements. Just put the meter into the Ohms setting and check across the two element contact points to see if you have continuity. If you find that one of them isn't giving you a zero "0" reading, that is the bad one.
Go to searsdirectparts.com to enter in your full model number and you can see the exploded line drawing for your dryer and the parts list and prices for the replacement part.
The reason the dryer is taking longer to dry, is because without both elements, the dryer cannot get hot enough to dry the clothes within the normal time, as only one element is having to provide all the heat in an attempt to dry the clothes.
You should replace the element as soon as possible, as having only one heating element working will cause that remaining element to fail sooner as well, since it will be staying one for a much longer time than normal.
Hope you find this Very Helpful and best regards!
Aug 26, 2009 | Dryers
DEIX2 does not dry - cleaned out lint trap, disassembled and removed lint from around lint trap assy., still not drying
Check the following areas thoroughly to address this issue.
1. Venting
Make sure the dryer vent hose, as well as the rest of the vent duct, is not clogged.
Unless regular maintenance is performed, chances are there is a lot of lint accumulated inside the dryer. This might affect the drying time and could be a fire hazard. Make sure to have your dryer cleaned regularly. Because this might involve taking most of the dryer apart, it is recommended to have a qualified appliance repairman perform this task.
2. Thermostat
There are a couple of cycling thermostats inside the dryer. If one of them breaks down, it might affect the dryer's performance. Replace the defective thermostat.
3. Heating element
A heating element might only be partially burned out, in which case it would still work but will take longer time to dry the clothes. Replace the element if found defective.
Jul 22, 2009 | Fisher and Paykel DEGX2 Dryer
Dryer not drying.Possible heating element not
One way to check if the element is working - is take the exost hose off the back & place a mirror behind the dryer so you can see if its glowing red hot or not..
Jul 08, 2009 | Dryers
Dryer not drying due to lack of heat
Check the following text to address this issue.
Note: Normal drying time for a dryer is about 45 minutes (some may take up to an hour).
1. Venting
2. Thermostat
3. Heating element
A burned out heating element will show no continuity when measured with a meter. Replace the element if found defective.
Jun 11, 2009 | Whirlpool GEW9250 Electric Dryer
Dryer won't heat up to dry the clothes the heating element works
Check the following to address this issue--
1. Venting
2. Thermostat
3. Heating element
Jun 03, 2009 | Kenmore Dryers
Clothes won't dry
Check the following to address this issue.
1. Venting
2. Thermostat
3. Heating element
Jun 01, 2009 | Whirlpool ET8CHEXSQ Dryer
Dryer no longer has heat to dry clothes
The element gets brittle and breaks. The element is in the rear of the dryer under the dustcover.
May 06, 2009 | Kenmore Dryers
Dryers Logo
100 people viewed this question
Top Dryers Experts
