Question about GPS
I have set the wrong languge i want engish, but it did not appear on the screen, so i thought if i touch the screen it would show more choices // How can i change it
  • dlittleton31 Apr 20, 2009
    need to change languge
  • 515 Answers
Posted on Apr 15, 2008
Acer All in one multi touch i5 Win7. Start all right, but then screen turn white. Can't see anything.
try reverting to vga mode
http://www.playtool.com/pages/safemode/safemode.html
tap f8 a couple of times after bios shows, then select vga mode in the list
if that works then you can change to a different resolution in display
Dec 31, 2013 | Acer Aspire Z3771-UR20P - P G630 2.7 GHz -...
Unlock dot pattern lock android
Normal way for Android is to power down and then hold the power button and the volume Up button.
Way 2 is to hold power, vol up and vol down.
You have to hold until the recovery console appears, so about 20 seconds.
Only a few have a reset button inside a hole.
However, yours is different to all the rest :>)
Just completed this procedure and repeated to confirm: Klu by Curtis 7035-j
1. Make sure tablet is off.
2. Press and hold the "Volume Down" key and `Power` key
3. When "Klu by Curtis" splash screen shows release the power key 4. A laying down android with cover open and a red triangle with an exclamation point will appear.
5. Rock the `Volume Down` and `Volume Up` and press the `Power` keys to dislplay the BIOS screen.
6. Use the `Volume Up/Down` keys to navigate choices (wipe data/factory reset) and the `Power` key to select the choice.
7. The following screen will ask you to confirm your choice and warn you that this cannot be undone. Repeate step 6 to select your choice.
8. When wiping all data is complete, select `reboot system now` to restart tablet. Done!
Read more: How to perform a factory reset on a Curtis Klu LT7035-J tablet? - How to perform a factory reset on a curtis klu lt7035 j tablet :: Ask Me Fast at http://www.askmefast.com/How_to_perform_a_factory_reset_on_a_Curtis_Klu_LT7035J_tablet-qna6954204.html#q6015781
Curtis Klu 7 inch Touch Screen Google Search
Apr 23, 2017 | Curtis Klu 7-inch Touch Screen Mobile...
Change language in kindle touch
Go to phone settings and select the option display. You can find the the settings for language there you can choose your language.
OR:
you can find in the settings>>phone settings>>language.
hope this helps.
if you need, and you don't have copy of the manual, let me know
Aug 02, 2012 | Computers & Internet
My GPS only shows a "non" English language. How do I fix this?
Hi
You did not mention which gps systems do you have. Anyway giving you details of tom-tom gps language change instructions.
Change the language settings on your TomTom GPS device. If your TomTom GPS receiver is set to the wrong language, change the current language to the language of your choice. Perform a reset on the device as described in Step 1. When your GPS unit turns back on, tap the button in the lower right corner of the screen to continue. Tap the next screen to access the GPS receiver's main menu. Tap on the wrench icon to access the "Change Preferences" setting screen. Scroll through the "Change Preferences" screens until you see the "Change Language" icon, identified by three flags. Tap the "Change Language" icon and choose your desired language from the list. Depending on which language you chose, you may be asked to choose a new voice for turn-by-turn navigation.
For Garmin device:-
Try this below
Touch the Wrench icon which is located on the screen with the Magnifying Glass and Map icon
Touch the down arrow
Touch the Lips/Mouth icon
Touch the top right blue box
Touch the up arrow until you see American English
Touch American English
Touch OK
This should now be in English.
Please get back to us if you have further query or else please accept the solution.
Thanks for contacting fixya.com
Sep 07, 2011 | GPS
Camcorder keeps reading internal memory full and just put new memory stick in camcorder how do I get out of internal memory
Your Sony camcorder has internal hard-disk and records by default to this media. If this is full, you need to offload the recordings and free up some space on the disk. But to select the memory card you can do the following:
Selecting the recording media for movies:
Touch (MENU) [Show others] [MEDIA SETTINGS] (under
[MANAGE MEDIA] category) [MOVIE MEDIA SET].
The [MOVIE MEDIA SET] screen appears.
Touch the desired recording media.
Touch [YES] .OK
The recording medium is now changed.
For still images:
Selecting the recording media for photos
[MANAGE MEDIA] category) [PHOTO MEDIA SET].
The [PHOTO MEDIA SET] screen appears.
Touch [YES] .OK
The recording medium is changed.
Hope this helps, if more help needed, reply back.
Apr 12, 2011 | Sony Handycam HDRXR350E High Definition...
Other than the G1 and Android appearing when my phone powers up, the screen stays blank. any ideas on what may be wrong?
Easy i just figured it out with my g1 with the same problem. The solution is this: Try taking out the battery put it back in. press and hold the power+home butto. a screen will show then press the power and home button agian. It will then give you some choices, choose wipe out your memory to factory settings and it should work after.
Apr 11, 2010 | HTC G1
Changing the Clock
Touch the map area of the screen, touch preferences, touch the right arrow to scroll to the page that shows clock, then click the option to set clock, your choice of set manually or sync to GPS receiver. Click done when you're ready.
Jan 02, 2010 | Tomtom ONE GPS Receiver
My ipod touch wont work
If iPod touch won't turn on, or if the display freezes or doesn't respond
  • iPod touch may need charging. See "Charging the Battery" in the iPod touch Features Guide.
  • Press and hold the Home button for at least six seconds, until the application you were using quits.
  • If that doesn't work, turn off iPod touch and turn it on again. Press and hold the Sleep/Wake button on top of iPod touch for a few seconds until a red slider appears, and then drag the slider. Then press and hold the Sleep/Wake button until the Apple logo appears.
  • If that doesn't work, reset iPod touch. Press and hold both the Sleep/Wake button and the Home button for at least ten seconds, until the Apple logo appears.
If iPod touch continues to freeze or not respond after you reset it
  • Reset iPod touch settings. From the Home screen choose Settings > General > Reset > Reset All Settings. All your preferences are reset, but your data and media are left untouched.
  • If that doesn't work, erase all content on iPod touch. From the Home screen choose Settings > General > Reset > "Erase All Content and Settings." All your preferences are reset, and all your data and media are removed from iPod touch.
To reset the iPhone or iPod Touch, press and hold down the Sleep/Wake button and the Home button simultaneously at the same time for at least ten seconds, then the LCD display will clear and the Apple logo appears on the black background. When Apple logo appears, reset is done.
Sep 22, 2009 | Apple iPod touch
How do you reset the languge back to engish on a cannon mp680??? help please
If unsuccessful in the driver settings, choose english option before reinstalling drive.
Jul 09, 2009 | Office Equipment & Supplies
My tomtom is set up in forgien language
Hi sausg. Turn your 910 on then - 1st screen touch on blue arrow then change pref - tap on blue pointer untill change language appears then the choice is yours. rrprdgt.
Nov 18, 2008 | Tomtom GO 910 GPS Receiver
GPS Logo
Top GPS Experts
Will Halftowaite
Are you a GPS Expert? Answer questions, earn points and help others
