Question about Nikon D50 Digital Camera
Nikon D50 Autofocus
I bought my D50 back in 2006, but took about a year hiatus from it due to my only lens breaking. I bought a new lens this year for it and used it for about 3 days before the autofocus stopped working. I can use the AE-L AF-L button beside the viewfinder and it will autofocus fine, but when I half-press the shutter, it doesn't autofocus at all. What I'm wondering is if someone would know whether that denotes a problem in the lens I just bought, or the camera body itself. I guess I'm hoping its the lens since that's still covered in the warranty, but any answer would be extremely helpful. Thanks for your time.
Well, a friend of mine was able to fix mine fortunately. I am such a beginner with cameras that the only thing that was wrong with mine was a setting in the menu (d'oh!).. Yours sounds really weird though and I wish I knew more about cameras to be able to help you. I'd suggest taking it to a camera store soon and asking if this is a common issue or if they know what part could control such odd behavior. Hopefully someone else on here will read yours and post some better advice, sorry I don't know enough to help, good luck with it though!
Posted on May 22, 2008
MaiaM,
I am having a similar problem with my D50's shutter. My problem seems to be related to the position of the camera. If I rotate the camera vertically to the left - it functions fine. Rotated to the right - it acts as is as if the shutter button is not working at all. Horizontally positioned - the shutter works about 85%of the time. Is your problem positionally influenced as well?
Posted on May 21, 2008
What digital nikon cam works autofocus in a nikkor micro AF 105mm f/2.8D?
This lens lacks the autofocus motor, so it will only autofocus on cameras with the motor. This lens will autofocus on every Nikon digital SLR except for the D40, D40x, D60, D3000, D3100, D5000, and D5100. It will autofocus with the D1 family, D2 family, D3 family, D50, D70, D70s, D80, D90, D100, D200, D300, D300s, and D700 (I hope I haven't left any out).
Jul 03, 2011 | Nikon Cameras
Nikon D50 with Nikon DX 18-55 lens will not focus
Sorry to hear about your lens. If you are able to autofocus and take pictures with any other lens, then it means that your problem lies with the kit lens. If you can take picture in manual mode, but not in autofocus mode, then the AF motor in the lens in not functioning. I had the same thing happen to my 50mm 1.4 lens.
Depending on your location, there are Nikon repair centers in Melville, NY and Torrance, CA.
Hope this helps,
Andrew
Apr 16, 2010 | Nikon Nikkor 18-55mm f/3.5-5.6G ED AF-S DX...
Can I use an old FM2 lens with the D50?
It'll work, though you won't be able to meter through the lens. And of course no autofocus, but I'm sure you already knew that.
Jun 12, 2009 | Nikon D50 Digital Camera with 18-55mm Lens
Nikin D50 autofocus
I figured out that when changing lenses my finger must have hit the little switch and flipped it over to manual focus. I changed it back and it now works. Thanks.
Feb 20, 2009 | Nikon D50 Digital Camera with 18-55mm Lens
Nikon D50 Does Not Autofocus
replace the lithium battery 1.5X2 . then press then ok good, but does not work the drive motor was broken.
Nov 05, 2007 | Nikon D50 Digital Camera with 18-55mm Lens
Camera won't autofocus
Auto-focus technology on this camera is controlled by several contacts on the mount that physically mate with other contacts on your lens. It sounds like your mount may be malfunctioning due to wear and tear (if cleaning does not work). This is between $100 and $300 fix depending on which part(s) need replacement.
Oct 24, 2007 | Nikon D50 Digital Camera
D50 with a new 18 -200 Nikon lens
Is the Auto/Manual Focus switch turned to Manual? This can easily be moved without realising that you have done so.
If not, get it checked out under Warranty. If you try to do anything yourself you will void the Warranty.
Good luck.
Oct 03, 2007 | Nikon D50 Digital Camera with 18-55mm Lens
Won't autofocus
First try another lens on the body and see if the problem is the lens or the body,if its the body the autofocus mirror could be out of adjustment, if its the lens, it sounds like the lens took an impact and needs a pro repair. you should be able to set body to manual focus and focus lens to infinty.
Jun 11, 2007 | Nikon D50 Digital Camera
Nikon D50 autofocus
Same happened to mine ,Its almost as though the motor has dis-engaged.I SOLVED MINE BY FORCING THE FOCUS RING WITH AUTOFOCUS ENGAGED THIS SEEMS TO HAVE RE ENGAGED THE MOTOR .HOWEVER BE CAREFUL I HAD LITTLE TO LOSE MINE WAS STILL UNDER WARRANTY WHEN I DID THIS.Its perfect since.
Jan 12, 2007 | Nikon D50 Digital Camera with 18-55mm Lens
Nikon D50 Digital Camera Logo
95 people viewed this question
Top Nikon Cameras Experts
Steve
Are you a Nikon Camera Expert? Answer questions, earn points and help others
