Question about Dishwashers
GE POTSCRUBBER 1200 DISHWASHER
MY DISHWISHER WILL FULL UP WITH WATER AND THE DETERGENT DISPENSER WILL OPEN THEN IT CLICKS LIKE IT IS GOING TO START AND IT JUST HUMS.
HELP!!!!!!!!!! THANK YOU DONNA
  • 1 more comment
  • df2006 Apr 14, 2008
    THANKING YOU IN ADVANCE FOR YOUR HELP ON THIS NEW PROBLEM ..... YOUR HELP ON MY WASHER PROBLEM WAS UNBELIEVABLE I HAD IT FIXED IN 20 MINUTES AND SAVED AT LEAST $300.00. THANK YOU!!!!!!!!!!
  • df2006 Apr 15, 2008
    jsrock516 hello!!! the model # is GSD1200T03XX and the serial # is ML623301A... THANK YOU!!!!!!!!!!!
  • Jeff Rockwell
    Jeff Rockwell May 11, 2010
    I'm glad you appreciated my efforts before, but I don't know if we're going to have the same luck this time (yet). The problem you are describing sounds like the main wash pump is jammed or the motor has seized up. Could you please post back with a COMPLETE model number (usually found around the door opening), so I can be sure?
I have a Ge Potscrubber 1200. Fairly new I guess as I bought it with the house that I purchased 1 1/2 years ago. Sometimes it drains and sometimes it does not. Today there was two inches of water! About to remove the bottom panel. Sounds like the drain valve it blocked but not sure. Any thoughts?
Posted on May 06, 2009
  • 5,911 Answers
Okay...my experience with this model, and the symptom you are describing, usually means the pump motor has seized up, or something has gotten stuck in the pump impeller. You can remove the spray arm assembly by unscrewing it and checking the wash pump sump and impeller to see if anything has gotten clogged in the pump intake area. An inspection mirror and flashlight may come in handy for this. I would not lean on the door as you may damage the springs. If you cannot see any obstructions from the top, the only other option is to check from the bottom. This usually involves turning off the main power at the breaker and removing the pump. I don't know if this is something you want to attempt. Removing the dishwasher from the cabinet may be required in some circumstance in order to provide better access. It's usually quite involved, even for someone experienced.
Repairclinic.com has an entire pump assembly for about $135 (item #820985). This is an upgraded pump assembly that GE is placing on all their dishwashers of this model. It may not look like the one you have, but this is an authorized substitution. Now...I'm not telling you at this point to replace the entire pump assembly. I'm giving you an option on where to look for parts if it comes to that, and to give you a view of the part without having to disassemble the dishwasher, first. Sometimes it helps to see what may be involved BEFORE you attempt a repair yourself to see if this is something you wish to tackle.
Searspartsdirect.com has another exploded view under the "Pump/Motor Assembly" heading, showing how the pump is assembled (a bit more pricey). Assembly instructions are provided from repairclinic. I'm assuming Sears does the same as many of their parts come form the same source.
I hope this is something simple and you don't have to go the route of replacing parts. Check the pump intake and clear any obstructions. Anything solid (i.e., chicken bones, lemon seeds, popcorn kernels, etc.) can stop the impeller and keep the pump from turning. I hope this is helpful to you. If you need further assistance let me know.
Posted on Apr 16, 2008
Hi. My GE Potscrubber 1200, Model GSD120055, stops mid-cycle and does not drain the water. It stops on Rinse and Hold.
I can nudge the dial and the dishwasher completes its cycle, so the drain and pump are okay. Is the problem with the timer or something else ? Please help, O Wizards of Washing.
Posted on Mar 27, 2010
"You can remove the spray arm assembly by unscrewing it and ..." Watch out - LEFT HANDED threads. I nearly ruined mine by assuming normal right handed threads.
Posted on Feb 21, 2009
Why has water dispenser stopped working?
There may be a clogged water line or the dispenser solenoid may have failed. even though it hums.
Feb 15, 2016 | Refrigerators
The detergent dispenser is full but not going down when using the washer
I WOULD SUGGEST MAKING SURE IT IS VERY CLEAN. detergent can clog the hoses easily. if you can remove the who dispenser (by design not by removing screws) then remove and clean. also run the washer with no detergent on hot to clean. also when it is empty pour hot water in the dispenser to clean. make sure you are not using too much or the wrong kind.
Aug 19, 2014 | Washing Machines
Dispenser full of water after wash
check hose come out from dispenser going to the tub , may be closed of detergent .
Feb 16, 2014 | Frigidaire ATF6000ES Front Load Washer
Ge potscrubber 700 dishwasher - the soap dispenser cover is locked and will not open. I have run the dishwasher several times and tried to force it but it will not budge. any suggestions?
Soap dispenser cover will not open until front knob is at 4:30 or 5 o'clock. Turn knob to 5 o'clock and jiggle dispenser cover. If cover still does not open, is detergent caked such that door won't open? If yes, remove caked detergent. If no, disconnect power at breaker. GE repair manual says to remove screws for inner door panel and inspect detergent dispenser mechanism with lever and trip lever for broken or binding parts.
Oct 13, 2013 | GE Dishwashers
Hello. I have a GE Potscrubber 600 dishwasher. The soap dispenser will not close. This seems to be a common problem. Any help would be great, thank you.
Main detergent cup won't close on GE Potscrubber 700 GSD700.A workaround is to add the additional detergent with rinse aid 18 minutes intothe wash cycle. To repair, switch off power through circuit breaker. Set timerknob to 12 o'clock. If the detergent cup lever spring opens the cup after it isclosed, remove screws on panel that holds detergent cup and remove the panel upand out of door. Remove timer cover by moving it right and pulling up to exposetimer, see photo 1. _1909.jpg If a spring is loose, it can be reattached as follows.Remove two screws that hold timer, then remove timer. Do not remove timer knobfrom front of GSD700 because knob is designed for removal from rear of panel,after the timer is out. If spring attachment point broke off, reinforce it withepoxy (JBKwik), see gray cone upper right of center in photo 2. _1910.jpg After epoxy cures, drill and tap a hole for a metric 3 - 0.5mm-8mm screw (4-40 may also work). Install spring between new screw anddispenser linkage and tighten screw, see photo 3. _1911.jpg Install timer, jiggle knob so it engages timer and securetimer with two screws. Pull dispenser lever down to make sure it moves andsprings back. Replace round switch and cover. Install white cover with leverextended through it. Install cover screws, close soap door, and rotate timer,soap door should open after about 90 degrees of rotation followed by rinse aidactuation.
Oct 24, 2010 | GE Dishwashers
GE Nautilius 24" built in about 6 yrs old won't start - it hums and goes through the cycles but doesn't run. Water came in and now won't drain either
Sounds like one of two things 1. The timer unit is gone, that would need replacing. 2. the syphin relay is stuck, this is located below the syphin on the underside of the dishwisher. BE CAREFUL! You will be dealing with electrics.
Aug 11, 2010 | GE Nautilus 24" Built-in Dishwasher
My GE Potscrubber 1200 cuts on perfectly and
probebly you dont have enough water coming in start the dishwasher,when it starts washing dump a bucket of water in the tub.if it starts moving replace the intake valve
Feb 26, 2010 | GE Dishwashers
My dishwasher is not emptying and all three lights are on which includes the one with the tap symbol. help please am desperate, i have emptied by hand and cleaned out filter but it seemed fine and set it...
hi,
Aug 27, 2009 | Dishwashers
Error sign blinking and will flash between different cycles
rate my suggestion
Aug 27, 2009 | Frigidaire 24 in. FDB126RB Built-in...
Dishwashers Logo
3,913 people viewed this question
Top Dishwashers Experts
