Cap replace HP vs19e. what are the value of the caps??
How do you get into the monitor to service it. I see no screws.
The top panel is on plastic clampers. Take a flat thin object and pop it along the perimeter. All the screws are inside on the perimeter of the LCD panel underneath the plastic panel.
Posted on Jul 23, 2008
    Scholar:
  • 176 Answers
All monitor have screw maybe you the screw is cover with the plastic look for the holes usually four side of the monitor.
Posted on Apr 16, 2008
My HP vs19e monitor takes almost 5 minutes to "wake up". Works fine once running. It never took this long before. Any ideas?
most common problem is bad electrolytic capacitors if unit is a few years old. Take it apart and replace any swollen, ie bulging top of the aluminium can... but may be 'off-value' if not swollen. Any electronics from China will fail within 3 years due to bad electrolytic caps..
Sep 07, 2010 | HP w19 19" LCD Monitor
My HP vs19e Monitor went black, when I turn it off...
guest, If monitor vs19e acts same when connected to different "known good" pc then try this site for info: http://www.lesliewong.us/blog/2005/05/02/hp-pavilion-f1703-flat-panel-display-blackout-solution/ How old is this model? When was last time it worked correctly? 12fixlouie
May 19, 2010 | HP Pavilion F1903 19" Flat Panel LCD...
HP vs19e monitor is blank. Power button is slowly
that is not a monitor problem that is a cpus problem disconnect the signsl cable and connect power cable you will see the post (power on self test) open the cpu draw the ram clean the dust and reinstall the problem will solved
Feb 26, 2010 | HP vs19 (Silver) 19" LCD Monitor
My HP vs19e flat panel monitor began taking longer and longer to come on and now it's hours. I'm afraid that one day it's not coming on at all. I have been leaving it on to keep from having to wait but...
Haven't run into this particular problem, but many have been able to fix their monitors that won't come on with my tutorial. See the link below:
http://boredprojects.blogspot.com/2009/09/hpvs19e-monitor-fix.html
Sep 25, 2009 | HP Pavilion F1903 19" Flat Panel LCD...
I want to replace the power switch board on my hp vs19e monitor.
About your only hope for getting a replacement switch is to buy a "Parts Only" monitor off of EBay and carefully remove the switch. This one is tricky it's attached to the front bezel as you've likely found out. When you disassemble the monitor, lay it face down and remove the bac plastic then remove the 4 screws holding the button board on then take the rest apart. That's the safest way.
Mar 28, 2009 | HP Pavilion F1903 19" Flat Panel LCD...
Hp vs19e just died
those capacitors are polarized they have a neg and a pos side were they seated correctly? could also be transistors going bad but my bet is some cap was in backwards.
Mar 22, 2009 | HP w19 19" LCD Monitor
Will not turn on
You can try the following steps:
1. Disconnect all the cables from the monitor
2. Wait for 5 minutes and press the power button in the front once ( donnot connect the cables at this step)
3. Reconnect the power cable only to the monitor
4. Power on the monitor and check if you see a self test running on the screen
If the selftest feature is not running the monitor has gone bad. All dell monitor if purchased on a seprate order ,hold a 3 yr replacement warranty. If you have got the same with your dell computer, call Dell to check if its under warranty.
Thanks
proton
Nov 01, 2008 | Dell E173FP 17" LCD Monitor
Xenon LCD monitor will not turn on..
time for a replacement with the amount of data supllied, also see if the light indicator button comes on, if there is power, then check the video plug and card, do another video card and see if that corrects the problem.
Jun 21, 2008 | Dell E173FP 17" LCD Monitor
15in dell monitor model e151fpb
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} Cause of power going off: There is a bad 1000uF, 16V cap on the power supply board.
Solution: Replace cap. Radio Shack sells a 1000uF, 35V cap for $2. This will work.
Why did the cap go bad? The cap is too close to a heat sink and over heated.
What does this cap do? This cap sends a signal to an IC which keeps the monitor 'on' after the power switch is pushed. When the cap is weak, AC ripple voltage is applied to the IC and it sends a signal to shut the monitor off.
Opening the Monitor: These monitors are difficult to open.
The two plastic pieces snap together and must be pried apart with a flat screw driver.
After removing the stand, you need to insert a flat screw driver at the bottom of the screen where two slots are located. Then work the screw driver around until the two plastic pieces are separated.
Remove the cover plate and unscrew the push button circuit board.
Unplug the monitor cords from the driver board and remove the screen.
Unscrew the mounting screws from the power supply board and remove.
You will need to pinch the plastic support in the middle of the board to remove.
Cap Replacement:
Cap is located near a copper heat sink and the value will be on the side of the cap. It will be bulged up on the top. You will see burn marks on the board surrounding the cap. Unsolder the cap.
Install the new cap and solder. Make sure you connect + of the cap to + marked on the board.
Be careful not to solder across joints.
Keep leads long so you can bend the cap as far away from the heat sink as possible.
Reassemble monitor and turn on.
This should solve the problem.
Dec 07, 2007 | Dell E173FP 17" LCD Monitor
No display
Cap Replacement:
Mar 18, 2006 | Neovo E-19A 19" LCD Monitor
Computers & Internet Logo
415 people viewed this question
David Payne
David Payne
