Question about Kenmore 72802 Gas Dryer
Kenmore 80 series, gas dryer, No heat
I have tried all of the settings on the timer. It turns on and runs, there just isn't any heat. I have disconnected the exhaust from the wall and checked for possible clogging. None.
Gas is working, just can't get any heat. Anything would help.
  • 5 more comments
  • tomgriffin Apr 21, 2008
    The dryer appears to operate (turns on, spins, etc) but I do not get any heat. I tried all the troubleshooting tips in the manual but none applied to my situation.
  • Anonymous Apr 23, 2008
    I have the same problem. The dryer will run but will not produce heat.
  • marcel2 May 25, 2008
    Dryer operates but i have no heat .
  • lillee32940 Jun 22, 2008
    There are three questions about this dated in Arp and May... it is now the end of June and no one has answered the questions... what's the deal?
  • miss jessica Aug 10, 2008
    My dryer works but has no heat. It turns and buzzes and does all it is supposed to do without the heat. I run my dryer twice to get one load of clothes dry! God forbid it is a load of jeans!!!! My husband thinks it might be the igniter but I know nothing about dryers except how to use them. Any help or suggestions would be great!
  • peggann Oct 13, 2008
    The dryer works fine in all aspects, except that it does not heat up. Where is the ignitor located?
  • Anonymous Nov 11, 2008
    Dryer won't heat.
Where is the thermal fuse located?
Posted on Sep 16, 2008
Wow... these questions were asked in Apr and May... it is not the end of June... still not answer... what's the deal?/
Posted on Jun 22, 2008
I just fixed mine.  When you take off the back panel, the thermal fuse is a small white plastic piece that has two electrodes plugged into it.  It is only held on by one screw.  It's toward the bottom in the middle.  I didn't know what it was, so I just went and purchased the piece.  It cost me $22.  Once I saw it, it was easier to spot on the dryer.  Quick and easy to install and now my dryer is working again!
Posted on Oct 20, 2008
Check your thermal fuse. We just had the same problem. it would start and run but wouldn't heat or shut off. The fuse is the problem with ours & it costs only $13.00.
Posted on Jun 23, 2008
I would check your thermal fuse. We just had the same issue & decided to bypass the fuse on the back & it started up just fine with heat & timing working perfectly. We checked continuity & it was intermittent. The part is about $13.00.
Kenmor 80 series gas dryer model # 11076822695 dryer is heating up for about 2 min then it gose cooled for the rest of the cycle
Hi, If you are having problems with your gas dryer not heatingthe most common problem is that the ignitor goes bad. Even though it glowssometimes it is still not working properly. if you dryer is gas check out this gas no heat tip.... If you have an electric dryer, you can have many differentthings that can go wrong causing the dryer not to heat. check out this electric no heat tip...
heatman101
Sep 20, 2010 | Kenmore 72802 Gas Dryer
Kenmore 70 Series Dryer not heating and not cutting off
I had an identical problem to yours this weekend with my Kenmore dryer. There were 2 problems.
1. Timer was broken. Does not advance to "OFF" position on timed dry, however it still works for auto-dry.
2. Thermal fuse was blown. Upon replacing, dryer heated up normally.
I believe when the timer broke, the dryer had kept running and blew the thermal fuse. On Sears' website, thermal fuse is $5.30, timer is roughly $80.
Kenmore 70 Series gas dryer, M# 110.76752500
Jan 01, 2010 | Dryers
Kenmore Heavy Duty 80 Series Gas Dryer won't cycle/won't heat.
if you ran this unit awhile without timer advancing,,now you blew the thermal fuse,,,re place thermal fuse and timer..
Nov 27, 2008 | Kenmore 73952 Gas Dryer
Kenmore series 80 Gas Dryer: No heat
ck the thermo fuse then ck the gas valve for power and the igniter to see if its broken probley igniter if you dont see a glow comeing from it
Mar 18, 2008 | Dryers
Kenmore 70 Series
hello,
i have a kenmore series 70's gas dryer that will not heat up when it is turned on and i am now smelling gas when i do try to dry my clothing. it was working yesterday but now this is happening? please help.
thank you,
tina
Jan 05, 2008 | Kenmore 74602 Gas Dryer
Kenmore 72802 Gas Dryer Logo
3,458 people viewed this question
Top Kenmore Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
