Question about Whirlpool LSR5132PQ Top Load Washer
Drain and vent
My in-laws' washing machine starting draining water through the vent pipe,no water is seen any where around the washer though.have ran a small snake(about 25') through the drain box,but nothing came up on the snake.very puzzled right about now,please help
    Sergeant:
    Champion:
  • 324 Answers
Vent pipe in the house?sounds like a plumbing issue in the house. unless your drain hose is to far down the drain pipe.
Posted on Nov 04, 2008
Water is backing up out of the drain pipe. I snaked the pipe and it doesn't appear to be clogged. Is there possibly anything wrong with the washer. Samsung VRT Model WA45H700AW/A2
Sounds like your drain pipe is not vented correctly. If not the water is fighting against the gas, and preventing flow. A lot of people think that a sewer pipe can run directly from the sewer but that's not how it works.
Jan 13, 2018 | Samsung Washing Machines
Trying to find pump.
Hi - I understand you will like to know where to find pump and check for clogs. Try the following steps below and hope it is helpful:
To completely clear any clogs in the washing machine drain you will use a pipe auger (snake). Start at the roof plumbing vent and drop cable to roughly 10 or 15 feet past the actual drain. If there is a clog present, the snake will bring up a chunk of debris. Remove it from the top of the vent and discard.
The drain hose is visible toward the bottom of this washing machine. It is held in place by a clamp or a couple of screws.
Remove the drain hose from the back of the washing machine. This is normally held in place by a clamp or a couple of screws. When a drain backup occurs, pieces of debris can lodge in the hose, causing clogs and odors.
Soak the hose in a bucket of warm bleach water.
Soak the drain hose in a bucket of warm water mixed with 1 cup of bleach. Look to see if the line is free of obstructions. Run a small length of clothes hanger through the hose to clear any hard debris.
Reattach drain hose and connect to drain pipe.
Reattach the drain hose using a screwdriver or pliers. Insert the hose into the washing machine drain. Be sure it is all the way into the drain opening.
Run the washer through a full cycle with 2 cups of bleach added.
Cycle the washer with warm water and 2 cups of bleach. The bleach will help remove any odor-causing particles in the machine and drain hose. Running the washing machine through a cycle will help flush away any remnants of the drain pipe clog.
Oct 12, 2012 | Frigidaire Affinity ATF7000E Front Load...
DOESNT DRAIN ON EVERY LOAD. DRAIN IS CLEAR
If you don't have a sewer vent pipe for your washer you will have a drain problem. I had the same problem, some loads drained fine and others were still soaking wet. The air from the vent allows draining. Since my plumber added the vent pipe, my water drains very fast and no more soaking loads.
Nov 20, 2010 | Maytag Atlantis MAV6000 Top Load Washer
Washer first begins to pump water, it comes out of the drain pipe
Laws of mother nature are the pipe is clogged or the size of the pipe is too small for the volume of water.Sorry I can't be moe helpful.Need help majortom350@yahoo.com
Aug 22, 2009 | Washing Machines
My washer drain pipe overflows when draining. i've tried smaller loads, cleaning drain pipe & vent, and raising the drain pipe. seems like the washer is draining the water too fast.
no you have a drain problem .... i would recommend calling a plumber the only thing it could be is drain problem there is no such thing as draining to fast.
Apr 30, 2009 | Washing Machines
My drain pipe for my washer doesn't drain the water fast enough.
No, but you can try snaking the drain or use something stonger like muratic or sulfuric acid. You may also want to check the venting on this drain.
Mar 15, 2009 | Washing Machines
Water fill, discharge and noise problems
to reset the water level you have to turn the knob all the way over as far as it will go and then come back to large load.
Feb 18, 2009 | Maytag Atlantis MAV6000 Top Load Washer
Washer fills up than starts draining while in wash cycle
Hello , here is the fix-your drain hose is placed to low in the drain line in the wall, it can not be placed in water or it will siphon the water out of your washer into the drain pipe and it wont stop until it hits air. try pulling your drain hose up and out of the drain and get a zip tie or cable and tie it to one of the water valves by the drain pipe placing the end of the drain hose about 5-6 inches inside the drain pipe. Let me know if you have any other questions and good luck it will work.
Phil
Jan 28, 2009 | Frigidaire FLEB8200DS Top Load Stacked...
Whirlpool duet washer leaking from bottom back..
sounds like you need to check your back drain could be the drain is clogged.Fill with water and see if it comes from the drain
Nov 06, 2007 | Whirlpool Duet GHW9150P Front Load Washer
Whirlpool LSR5132PQ Top Load Washer Logo
112 people viewed this question
Dan Webster
Dan Webster
Sal De
