Question about SanDisk Sansa e250 MP3 Player
Sans e250 photo size
When I play my photos they have the top and bottom chopped off the don't fill the screen. What can I do to have them fill the screen?
    Problem Solver:
  • 21 Answers
Do the fit screen option on the mp3 player. you are on the full screen mode, which for larger pictures cut them off.
Posted on Apr 16, 2008
How do I make the picture bigger so it fills the screen and not have black bands at top and bottom
Banding of the screen usually means that the aspect ratio of the broadcast is different than the screen size ratio. Most modern TVs are 16:9 ratio. Most modern TV broadcasts and movies are as well. In those cases, when in HD mode, you will see the picture fill the entire screen. Older broadcasts and many syndicated reruns are in the old 4:3 format and will be banded. Also, some movies are in larger formats than 16:9 and will reduce in size in order to get the entire picture on the screen. That being said, most TVs DO have a stretch and.or zoom feature that will expand all images to full screen size. Be advised that this can result is image distortion, especially of the 4:3 ration broadcasts. Others will have some of the picture cut off and you may see some items such as network logos, etc. partially chopped off in this mode.
Mar 13, 2015 | Televison & Video
Tip
Common Projection TV Problems and Fixes
In this article we will will outline some of the most common projection TV problems, fixes, pros and cons, and average lifespan.
Average Lifespan: 7-20 YearsPros: Large screen size and excellent picture quality. Some model support HD. Very reliable when they are cared for.
Cons: Heavier and bulkier than the newer plasma or LCD sets so if you live in a cardboard box it may take up a bit more room.
Common Problems/Fixes
Common Problem #1 - Convergence: One the most common problems that you will run into eventually is a convergence failure. This is when the TV colors do not align anymore and the TV will look 3D, warped or distorted. This is a very common problem and a fairly simple DIY fix. Parts to repair this can be found over the internet from sites such as www.TvRepairKits.com . Below are a few photos of a typical convergence problem and a link to a video on YouTube with more details.
utube.png You-Tube video "9oI1Nzq7CR8" placeholder (do not delete) utube.png
Notice how the image looks 3D...this is a classic example of a convergence failure...it may also look warped or have a wave look. But the wave will not fluctuate.
Common Problem #2 - Dull or Dark Video
The second most common problem we see on projection TV sets is whats known as the dull video issue. This is commonly caused by discolored cooling fluid in the lenses. Over many years - usually around 5-7 years - the fluid will discolor and cause the video to wash out or look dull. Changing the CRT fluid out every 7-10 years will restore the image clarity back to factory new conditions. You will actually be amazed at how sharp and clear the video looks once a fluid repair has been done.
Here is a before and after photo notice how it looks washed out. In some cases the images will look like they have halos around them or the screen will have a reddish tint. Bottom line - if your projection TV has never had the lens fluid replaced the video is not as sharp as it can be. You can get fluid kits from the same sites mentioned above. Doing this repair yourself or through a shop will make the video look amazing.
After a fluid replacement
Common Problem #3 - Dead set with no videoIn these cases there can be more than one common issue depending on the TV brand and model. But to make things simple if the TV has no audio or video and its making a constant chirping sound the issue is caused by a short in the convergence. The fix is to do a convergence repair. If however its not chirping constantly it can be one of many issue from failed capacitors, diodes, flybacks, etc.
on Apr 25, 2012 | Televison & Video
I have purchased a Samsung Led 50 inches tv in USA, The picture is not displayed full on the screen. Can you please suggest?
These are generic instructions for all TV's and all Remotes:
1. Press 'Menu' key on Remote (or 'Setup' key).
2. Go to Setup, View, or Picture tab (whichever one you've got in your Remote's Menu or Setup)
3. Change your Zoom or View aspect.
NOTE: Depending on the dimensions of your TV, you simply may not be able to view the entire picture using a correct aspect ratio (NOT stretched). On my 42" RCA is use a 4:3 Zoom setting to fill my screen but, it chops a little bit off the top & bottom. It's the best I can do with my current setup.
Dec 17, 2014 | Samsung UN50H5203 - 50-Inch Full HD 60Hz...
I have a satelite c660-195 I have put recovery disk 1 in and it loads, the system starts to recovery. It stops and the screen says ( see pic ) so I change the cd and it crashes please help
Is the disk scratched or damaged or anything like that? Is part of the top film a little chopped up?
If the bottom of the disk is scratched you're able to bring in the CD to any place that sells video games or CD's and they should be able to fill in the scratches for you since the top film is the important part of the disk.
If the top film is scratched up, you may need to buy a new disk :/
I hope this helps :)
Feb 26, 2013 | Computers & Internet
Cannot get full screen picture. seems like I still have a 36 inch tv. It is a 42 inch LG plasma hdtv
It seems like you're expecting a 16:9 ratio picture. If you're sending a 4:3 ratio signal to the TV, you'll get a 4:3 ratio picture. An option would be to use the remote and set the TV to a 16:9 ratio picture, but that'll stretch the picture and make everything look fat. Another option would be to use the remote and zoom in, but that'll chop off the top/bottom of the picture a bit. Either case would be annoying. Some make matters even more annoying, some programs are broadcasted in a 16:9 ratio signal, but the actual picture is really 4:3 ratio. So...... as long as the pictures don't look skinny, fat, or chopped off, just accept it. If you're really that picky, just watch new Blu Ray movies only.
Jul 22, 2011 | LG Televison & Video
Can you make horizontal pictures fit the frame
I'll assume your picture is already oriented properly (horizontally), i.e. you do not need to rotate it.
There are 2 modes for displaying the photo ... (1) the ORIGINAL mode - displays the photo in actual photo size, which may result in part of the photo not being visible on the screen, or, (2) the OPTIMAL mode - which reduces the size and resolution to best fit the screen.
To set image size mode, select the SETUP on the HOME screen display, then highlight and select the DISPLAY IMAGE SIZE button, and go from there.
The first (ORIGINAL) mode is usually the default mode. When you select the OPTIMAL mode, the picture will be scaled to fit the size of the screen ... but you may see "dark" bars (e.g. on top and bottom of the screen) if your picture does not fit the exact screen size.
Jan 02, 2011 | PANDIGITAL 8.0" Digital Photo Frame...
I put videos and photos in my sansa e250 but they dont play
log off your I pod and start again after few minutes
Mar 16, 2010 | SanDisk Sansa e250 MP3 Player
Hi, my name is Nicole. My KV-36HS510 Sony TV is being broadcast with the picture size reduced quite a bit. Playing DVD's is fine, the pic fills the whole 36". However on cable TV it is chopped on the...
press "menu"
the setup screen should open
scroll through the options to "16:9 enhanced"
you should find 2 options ("on" and "auto")
choose "auto"
that should do it
enjoy.....
Sep 12, 2009 | Sony FD Trinitron WEGA KV-36HS510 36" TV
Portrait photos are chopped top and bottom
Hi there, the screen resolution for that frame is only 800x400 pixels. When you're in your photo editor doing resizing, make sure you don't make the picture any bigger than that. Try it out and let me know how it goes.
Rob
Jan 11, 2009 | PANDIGITAL 8.0" Digital Photo Frame...
Image outside of bounds of television.
There should be a format button on the remote you can hit. This should cycle thru all the "formats" that the set can do. 16x9, 4x3, wide mode, Full mode, stretched mode, etc.. Let me know if that helps you.. Happy holidays... Jay
Dec 08, 2008 | Mitsubishi WS-65311 65" Rear Projection...
SanDisk Sansa e250 MP3 Player Logo
20 people viewed this question
Top SanDisk Audio Players & Recorders Experts
Gyula Lacz
Computer Repairing
Computer Repairing
Are you a SanDisk Audio Player and Recorder Expert? Answer questions, earn points and help others
