Installed hp psc 1310 will copy great every time printer is turned on it prints test sheet, but will not print anything from computer the message is "user intervention required use printer offline" how do I correct this?
    Scholar:
  • 176 Answers
Click START then PRINTER AND FAXES double click your printer when the printer windows open click PRINTER uncheck USE PRINTER OFFLINE i think that the reason why you cannot print because the printer is offline
Posted on Apr 15, 2008
My HP PSC 1350v prints a test page every time I turn on the printer?
Bet you recently replaced a print cartridge!
That model of printer recalibrates after any cartridge replacement.
Let one of those sheets print out in full. Read what is on the sheet. Place the sheet on the scanner
and press the button that the sheet indicated to be pressed. The printer will go through a alignment
cycle then quit. Once that is finished you should not have to do anything till the next time your change
a print cartridge.
Mar 22, 2011 | HP PSC 1315 All-In-One InkJet Printer
The printer 1310, won't scan after installation
First the printer is hp psc 1315 not 1310, my mistake.
I think the problem arose because of the order in which I was installing the cartridge. Instead of waiting for the printer to print out the test sheet, I was placing a test sheet, of which I have a number of copies, in the printer immediately after installing the colour cartridge and then pressing 'scan'. Nothing seemed to happen. I then tried waiting for the printer to produce a test sheet. This took a surprisingly long time. However after placing the test sheet which the printer had just produced in the printer and then pressing 'scan', the scanning operation was completed successfully. Problem was probably caused by my not reading instructions carefully. Roland Bishop
Dec 31, 2009 | HP PSC 1315 All-in-One Printer...
I have re-installed my printer. It prints, but doesn't print anything what's going on?
I think you mean it sheet-feeds but does not print. If so, power off. If network connected, power off the print server. Power all back on after a minute. Depress power button on printer for 10 seconds.
If auto test page prints, problem is with printer configuration on your computer. Check the configuration carefully. Did you uninstall with the HP Scrubber utility before you did the re-install?
In If the test sheet feeds but does not print, use the HP printer utility, check ink levels, check cartridge "expiration", and clean heads several times. Test again.
Oct 21, 2009 | HP PSC 1610 All-In-One InkJet Printer
Turn off alignment feature
After you install new ink cartridges or attach the printer to a different computer it will go through this exercise. Make sure you also do the next step... a scan of what you printed-out; or you'll get that message every time.
Jul 25, 2009 | HP PSC 1510 All-In-One InkJet Printer
My hp psc 2410 photosmart printer will not print - only copy
Check to make sure your PSC 2410 is in fact the default printer. If it is, make sure your cable is firmly plugged in to your printer and CPU. Clear the print queue. Turn off and restart printer. I have found that your problem is basically a communication problem between the computer and printer. Also check www.hp.com. Good luck.
Feb 04, 2009 | HP PSC 2410 All-In-One InkJet Printer
I have an HP printer scanner 1310 series. Have trouble with printing. It will run about 3 blank pages through before it will print. Then it will run a page part way through so have to open back to get it...
Hi Audrey-
There are many things that will effect how your printer handles paper. The most overlooked being the size of the document or image to be printed. If the image or text bleeds over the edges (left, right, top, bottom) of the document, several sheets can be ejected before the "visible" printing takes place. Often those first few pages look blank, but actually are the outer edges of your picture or text. If you are printing a large picture or large text document, this may be your situation. Try printing a document with just a few words on it (like a small email) as a test.
The second most common culprit is dusty, dirty feed rollers in the printer. Consult your HP 1310 series manual for instructions on cleaning the feed rollers, or consult this general cleaning article on HP.com. HP PSC 1310 All-in-One Printer series cleaning
The type of paper can also effect how many sheets are pulled into the rollers. Is the paper new?, Thick?, Very thin?, or is it the same ol' printer paper you've always used? Either way, remove the stack of paper from the feed tray, "fluff" it by fanning it (like flipping through a book very quickly, or the way Superman counts a stack of money!) and replace. Print a test page.
Let me know if this helps!
Dec 29, 2008 | HP PSC 1315 All-In-One InkJet Printer
Alignment sheet prints---cannot print anything else
u will have to first scan the alignment paper in your scanner this will solve your problem
Nov 14, 2008 | HP PSC 1315 All-In-One InkJet Printer
MY test page always prints
I belive that after replacing the INk cartridges, you are experiancing this problem. The Alignment test sheet always prints everytime you turn on the printer, if u haven't completed the Alignment process.
To complete the Alignment process,
>>Once the printer finished printing the Alignmnet test sheet.
>> Place the Test sheet staright on the scanner glass facing down towards right hand corner.
>>Press the scan button(color), the Power ON light will start flashing, wait until it stops flashing.
>>Alignmnet process completed.
Thank You
Feb 09, 2008 | HP PSC 1315 All-In-One InkJet Printer
Hp printer won't copy
1. turn off / on the printer
2. press setup hold down and press options
3. press start color copy
worked for me on psc 2175
Sue
Jan 17, 2008 | HP PSC 2175 All-In-One InkJet Printer
Installation of PSC 1310
delete driver unplug from pc, download and install driver, connect when prompted
Driver
Nov 27, 2007 | HP PSC 1315 All-In-One InkJet Printer
Computers & Internet Logo
113 people viewed this question
David Payne
David Payne
