Magenta won't print have done deep clean and head alignment cartridge new and functioning tested cartridge in blue slot and ink worked
  • 4 more comments
  • gardengloria Jun 27, 2008
    Epson Stylus C86: Magenta won't print. I replaced the cartridge, then when that did't work, installed another one. I cleaned the contact with alcohol. I have done multiple head cleanings through the maintenance program, & checked that the ink was flowing from the bottom of the cartridge. Even unplugged the printer for a while. Nothing makes the magenta ink print, not even a new cartridge. The manual suggested changing the gamma or ICM settings, but it made no difference. The ink is registering as full on the monitoring tool. All the other colors & black print perfectly.
  • Anonymous Jan 18, 2009
    The same problem with magenta.
  • michaelmccoo Jan 24, 2009
    Canon ip4500 won't print magenta - all tests done, new cartridges bought, still nothing.
    On the test print the magenta comes out but in practical application it is completely missing.
    Michael.
  • beardless Apr 09, 2009
    same problem with magenta on the canon ip4500
  • Peter Thompson
    Peter Thompson May 11, 2010
    Is this a brand new cartridge genuine, or a remanufactured cartridge?
It sounds like your print head my be blocked. On some printers they come with the cartridge, my canon has separate print head that can be replaced.
Posted on Jan 24, 2009
My cyan colour won't print : tried aligning page, everything, can you help?
Try to do the Deep Clean Printhead function on your printer to force ink through the nozzles and clean possible clogs and dirt.
Feb 11, 2012 | Lexmark Office Equipment & Supplies
MP530 all in one printer - bought Staples magenta & blue inks but printer won't print those colors but did print older Canon inks not needing replacing; bought new Canon magenta & blue inks but...
What you can do is take the ink cartridges out of the print head and remove the printhead. Hold the print head over a trash can and take some 409 cleaner and spray the little pads inside the print head til you start noticing the colors dripping into the trash can. You will them want to dry off the print head as much as possible and litely wipe off the outside and the bottom of the print head with a paper towel. Then reseat the printhead back into the printer and the inks. You will then want to run a nozzle check from your printer software or from the printer properties. If the inks still are not showing up run one or two cleanings. If the issue still persists then you might have to replace the printhead. If this is the case you can look up part number: QY6-0059-000 online to replace the print head.
Jun 30, 2010 | Canon PIXMA MP530 All-In-One InkJet...
HP Photosmart 3210xi - some colors (magentas) will not print
Remove the magenta cartridge, and try cleaning the head with alcohol, maybe with a small paint brush or an acid brush. It sounds like ink has dried and plugged up that head.
Jun 04, 2017 | HP Photosmart 3210 All-In-One InkJet...
Wrong ink in slot
my brother mfc 6490 has stopped printing yellow, i've done number cleans and changed cartridges with no luck. has anyone out there got a fix for this?
Sep 13, 2009 | Brother MFC 6490CW InkJet Printer
Black and Magenta ink won't print...
Do a deep clean on the printer.
Done from the printer setup.
widows is done from start, printers and faxes, click on your printer.
Should bring up window for setup.
Look for cleaning section.
May 07, 2009 | Epson Stylus C88 InkJet Photo Printer
Only black and blue will print on test page; yellow and magenta does not. Ink was just replaced.
Did yellow and magenta print OK before the previous cartridges ran out? If so, it looks like your new cartridges are not working properly. Try another yellow and magenta cartridge - you can re-use the previous cartridges if they turn out not to be faulty. If new cartridges don't solve the problem, you can try soaking the print head, in case you have nozzles blocked with dried ink for some reason.
Turn the printer on, and as soon as the print head moves out of its parking position, pull the power cord out of the back, or turn the printer off at the mains. You may now carefully move the print head by hand over to the left hand side out of the way. Look inside the print head parking area on the right and you will see a small rubber cup that comes up to cover the print nozzles when the head is parked (to stop it drying out). Use a syringe or dropper to fill this cup with head cleaning fluid or distilled water. DO NOT USE TAP WATER. Carefully push the print head by hand fully into its parking position so that the cup full of fluid comes up over the print head. Do not turn the printer on at any stage in this process. Leave this for at least 24 hours, then turn the printer on and try a head clean/nozzle check again. If you get any magenta/yellow ink on the nozzle check, then there is hope! Repeat the head clean/nozzle check process 2 or 3 times, but not more. Leave for 24 hours for any air bubbles to disperse. If nothing, repeat the soak process once more. If still nothing, post a new comment detailing what you have done and the results.
May 04, 2009 | Epson Stylus C86 InkJet Printer
I have tried to print using my black ink cartridge and it will only print what is my email address.
Issue: Tinted printing / Colors are not exact
Solution: Resolving ink tank and cartridge issues BJC-6000
Printer attempts to print but no ink is on the paper Printer attempts to print but no ink is on the paper If the print quality is poor or no ink is appearing on the page, it may be because of the following problems:
  • The ink in the BJ tanks has run out.
  • The print head nozzles may be clogged
  • The protective cap or tape may have been reattached to the BJ cartridge
  • The BJ cartridge may need to be replaced
  • You may be using the wrong side of the media.
To check the level of ink in the BJ tanks
Open the printer's front cover and visually check the level of the ink in all the BJ tanks. If a BJ tank is low or has run out of ink, replace it. Failure to do so may shorten the life of your BJ Cartridge
To check the status of the print head by printing a Nozzle Check Pattern
  1. The Nozzle Check Pattern confirms whether the inks are being correctly ejected from the print head nozzles and whether the print head is correctly aligned.
  2. On your printer, press and hold the Resume button until you hear 2 beeps.
  3. When you release the button, the Nozzle Check Pattern will be printed. You can also print the Nozzle Check Pattern by clicking on the Test Print button in the Maintenance tab of the printer properties dialog box.
  4. After the Nozzle Check Pattern is printed, check the results. Look at the Nozzle Check Pattern for each BJ Ink tank. If any colors are missing or if any horizontal lines are broken or missing, perform the print head cleaning procedure.
To perform the print head cleaning procedure
  1. On your printer, press and hold the Resume button until you hear 1 beep.
  2. When you release the button, all print heads for all colors will be cleaned.
  3. You can also clean the print heads by clicking the left Print Head Cleaning button in the Maintenance tab of the printer properties dialog box.
  4. When the print head cleaning begins, the POWER light starts flashing. This will continue for about 30 seconds. Wait for the light to stop flashing before you resume normal operation.
  5. Perform the Nozzle Check Pattern test again.
  6. If the results are satisfactory, resume normal printing. If the results are not satisfactory, you may need to execute a print head deep cleaning.
To execute a print head deep cleaning
  1. Make sure paper is loaded in the sheet feeder and the printer is turned on.
  2. Display the printer properties dialog box and click the Maintenance tab.
  3. Click the right print head Cleaning button.
  4. When the print head cleaning begins, the POWER light starts flashing. Wait for the light to stop flashing before you resume normal operation.
  6. If the Nozzle Check Pattern is still unsatisfactory, you may need to execute a print head alignment.
To execute a print head alignment
In Windows, display the Maintenance tab of the printer properties dialog box.
  1. Click the right Test Print button.
  2. Follow the instructions on the screens to perform an automatic print head alignment.
  3. A confirmation screen will ask you if you want to perform automatic print head alignment. Read the screen and click OK. Another screen warns you not to start any other operation until the alignment is complete. Again, click OK.
  4. The BJ Printer Status Monitor displays the Printer Status. The driver will align the print heads then will print an alignment pattern.
  6. If the Nozzle Check Pattern is still unsatisfactory, you may need to replace the BJ cartridge.
To replace a BJ Tank in a BJ Cartridge
Leave the BJ cartridge in the printer when replacing a BJ tank. Make sure the printer's power is on. Make sure you insert the BJ tank in the correct slot.
  1. Open the front cover.
  2. The power light blinks while the cartridge holder is positioned to the center of the printer.
  3. Remove the empty BJ tank by pressing in on the release tab and then lifting the BJ tank up and out of its slot.
  4. Dispose of the tank properly, taking care to avoid spilling ink on your hands, floor, furniture, or clothing.
  5. Remove the new BJ tank from its package and pull the orange tape up and against the perforations to open the package film. Be careful not to remove the label from the tank. You will need it to match the tank to the correct slot in the BJ cartridge.
  6. Twist the orange protective cap to remove it. Do not attempt to reattach the protective cap; instead, discard it along with the protective tape.
  7. Insert the BJ tank by holding it at a slight angle, aligning it with the correct slot. Press down gently on the top of the tank until it locks into place.
  8. Lock the ink tank in place by pressing down on the circle mark on the top of the tank.
    Close the printer cover.
  9. The printer will automatically start cleaning the print heads. When the print heads are clean, the POWER light will stay on, indicating that the printer is ready for operation.
  10. Perform another test print to make sure the new ink tanks are performing correctly.
To remove the protective cap and tape from the BJ cartridge
  1. Open the printer's front cover.
  2. Unlock the BJ cartridge by raising the cartridge lock lever. Make sure you raise it all the way up.
  3. Remove the BJ cartridge by holding it by the circles on the left and right sides.
  4. Make sure that the orange protective cap has been removed.
  5. Make sure that the protective tape has also been removed.
  6. Replace the BJ cartridge and move the blue cartridge lock lever until it locks in place.
To check the media
Make sure that you are printing to the correct side of the media that you are using, and that the Media Type setting in the printer driver properties correctly reflects the type of paper you are using.
Be sure to read any instructions that come with your Canon specialty paper. These instructions provide important information regarding how to achieve the highest print quality with these papers.
May 30, 2008 | Canon BJC 6000 InkJet Printer
My magenta will not print well
Here's what you should do. Remove all ink cartridges. Get some rubbing alcohol, preferrably 91% proof (leaves less moisture) Get a couple normal paper towels. Check each cartridge for dried ink and remove it using an alcohol wetted paper towel. (The deep cleaning procedures aren't always effective.) The gold contacts on each cartridge should be gold when you are done. Use the same procedure on the gold contacts of the ink cartridge housing inside the printer. Take your time, do it well. If that does not fix the problem, then do the following. Switch the black and magenta cartridge. Some printers won't print when you do this, other printers don't know the difference. If your printer is the later, then attempt a print job using a page that has a line of both black and magenta text. If you see a black print, then the problem is your magenta cartridge (despite having installed a new one) If the magenta prints, then you know the magenta cartridge is good. If the magenta prints but the black doesn't, then you have a printer failure. Let me know your results. ZT3000 Beta tester of "0"s and "1's"
Aug 18, 2007 | Canon i860 InkJet Photo Printer
Magenta printing as yellow
Well, first off, are the alignment, and nozzle check sheets looking good? If not, then work on that. If so, then we have a problem. Try creating a test sheet in Word. Make red, yellow blue & black text and see if anything else prints wrong. Get back to me!
Jun 19, 2007 | Canon PIXMA IP5200 InkJet Photo Printer
797 people viewed this question
jasbo
jasbo
