Question about JVC HD-52G786 52" Rear Projection HDTV
Hd-52g887 lamp will not come on error lights on no sound fan circuit works..bulb is fine have 2..any sugg on what's wrg what board went txs in advance.
  • bluevenge May 15, 2008
    have new bulb , blinking at same time...
  • hotrodholman Dec 25, 2008
    Tv will not power l.e.d. sound or picture.
How do you know the bulb is fine? Are the LEDs blinking together or alternating?
Posted on May 11, 2008
I have toshiba 50hm67 replaced worked, then quit working again, and giving blinking yellow lamp error light when turn on...after a few moments tv tries to turn off and back on
OK. I have this same issue. I replaced my bulb a month or so ago. TV worked fine. Then one morning I turned it on and it was on for a good while, till it went to a black screen w/ sound only. Lights were going through the reboot process as designed for 8 attempts before it went to the solid red light. From the red light, if I unplug and plug back in, the tv will come on for a given amount of time, which varies, and then cut to the black screen. A repairman told me that it sounds like the digital board is bad. He wanted $150 for the board and $100 labor. I cannot find anywhere where the board would be located or where I can purchase a replacement.
Jun 15, 2011 | Toshiba 50HM67 50" HDTV
I just replace the bulb in my JVC HD-52Z575 everything was fine for about 10 days. Now when I turn the TV on it works for about 30 to 45 min before it shuts off, the fan kicks in, and the LED power light...
Ballast Board? it is what Powers Lamp, or CK Lamp Fan if it stops running and is not Keeping Lamp Cool
set is designed to shut off to Protect lamp from being burted up, you could have either Bad Ballast Board or Defective Lamp Fan,there is a few test you can do to see which Part is Bad.
Jan 25, 2010 | JVC HD-52Z575 52" Rear Projection...
Model hd 52g887 tv went blank and power and lamp light or indicators are flasing. Is this indication lamp needs to be replace?
most likely. If you have your owners manual it gives you instructions on how to change it yourself
Aug 07, 2009 | Televison & Video
Hitachi 50V500A cooling fan for LAMP doesn't turn off
After i replace the lamp on my Hitachi50v500a worked everything then i turn it off.After 1h wanted to turn it on again and it shows (TEMP) light is that a lamp fan or something else.Please help how to fix it by my self.Coz no money to call the tech.
Aug 07, 2009 | Hitachi 50V500 50 in. HD-Ready LCD...
Bad Bulb?
the pins that protrude into the lamp compartment have a tendency to get out of alignment where the lamp will only make partial contact. It sounds like what youre describing.
Jun 15, 2009 | Televison & Video
My 52' HD television will not turn on, it is a JVC HD-52G887. The blue light comes on but there is no blinking red light. Please help
unplug the tv, then reinstall the bulb,if that doesnt work youll need a tech to help. (dont buy another jvc tv)
May 19, 2009 | JVC HD-52G886 52" Rear Projection HDTV
Screen went black an hour ago, the sound is ON
Start by replacing the bulb. If thats a no go, check the ballast. Its a small circuit board directly underneath the bulb housing and is replaceable through the bulb panel. If those two don't work, comment back and I'll walk you through more 'in depth' repairs.
Feb 02, 2009 | Samsung DLP HL-P5663W 56" TV
Sound but no picture
there are several things that need to take place for the lamp to turn on. first the color wheel needs to turn on ( if you can hear a whinning noise then this is fine) next the tv will send a signal to the lamp ballast to turn on, and the ballast needs the 130v dc supply from the power board ( simoly remove the lamp and reinstall the lamp door, turn tv on, and if you hear an arcing noise from the ballast you know this is fine too. the board that controls all of this is the dmd board. so if the color wheel works, ballast starts then i would replace the dmd board....
Oct 24, 2007 | Samsung HLP5085W 50" Rear Projection...
Sony kdf-60wf655
There is a lamp driver error in your TV set. Most likely the ballast circuit for the bulb. Depending on who you take the set to, you will pay anywhere from 300 to 500 bucks to have this set repaired. This is why i recommend an extended warranty on all of these types of TV sets. This repair will involve replacing a board, and it could be one out of three of the differant boards that control the lamp. good Luck.
Jul 21, 2007 | Sony Grand WEGA KDF-60WF655 60" Rear...
JVC HD-52G786 52" Rear Projection HDTV Logo
227 people viewed this question
Top JVC Televison & Video Experts
Jaime Hernandez
Are you a JVC Televison and Video Expert? Answer questions, earn points and help others
