Question about Panasonic CT-32SL13 32" TV
Color Problems: No Green
Sometimes the TV color works fine then in a blink colors are muted and the most obvious is there is no green.  Please help!
    Genius:
  • Panasonic Master
  • 1,673 Answers
Because the fault is intermittant this can be a cold solder connection anywhere along the video path of the green drive output at the colour demodulator through the various stages up to the CRT socket. It is also possible that there is a failure occuring in the bias supply that works for the green electron-gun in the CRT in the case of a CRT type set. It is also possible that there is an intermittant component along the green video path. On rare occasions the CRT itself can have an intermittant fault.
This would have to be serviced by an experienced tech. You can take the set in for an estimate to see if it is worth servicing.
Jerry G.
Posted on Apr 14, 2008
Hello, I have a 2005 Sony KP-51WS520 Rear Projection TV. Recently, the green colors all become a yellowish/orangish color. When you are watching a baseball game the grass is a orangish color. ...
DLP tvs have a design weakness,the problems it is call a convergence problems,it is dead.This convergence problems,will have happen many times through out the tv live.The tv have a colors R,G,B lines misalignments,have colors shadow pictures or 3D pictures look alike?Yes,than the tv board,that call the tv convergence board it is dead.The tv convergence board,must require changes 2 STK convergence ICS and some or all of it resistors too.To fixed the tv convergence board to solved the tv colors picture convergencce problems.The tvs shops will cost u like $300-350 for parts and labors.
May 24, 2011 | Sony KP-51WS520 51" Rear Projection...
LG Projection TV Model# RT-49NA11T Green color gun shows bent arc on top & bottom.Red & blue guns are ok.How to adjust the green gun to remove the bent arc. This is causing picture shows mix...
This problems ur tv have can't not be fix by adjustment.The tv have a problems known as convergence problems,it dead.Tv have colors lines R,G,B mis alignments,have colors shadow pictures or 3D pictures look alike?The tv convergence board have dead 2 STK convergence ICS and some or all of it resistors too.These parts on the tv convergence board,must be replaced to repair the tv convergence board to solved the tv convergence picture problems.The shop,will cost u like $300-350 for parts and labors.
Jan 10, 2011 | Panasonic PT-53WX53 53" Rear Projection...
Lost green color, lights blinks
Ur high voltage is dead,FBT,flyback transformer is dead,the big black block of plastice with a red wire with a cap hook to a CRT(tv tube).Resoder for lost green color,by the crt yoke RED GREEN YELLOW connection to the main PCB board.Might also have to resolder crt board connection pins socket.
Mar 29, 2009 | Sony FD Trinitron WEGA KV-36HS420 36" TV
2Wire 473 router problem
Take the modem and plug it into a GFCI outlet. You can find one in the bathroom or the kitchen.
If the power light comes on solid green and the dsl comes on red then the modem is good. Was it plugged into a power strip by the computer? If so, plug it straight into a wall outlet.
If the power light comes on solid red then the modem has hardware failure. I would contact your ISP and have them replace it if it is still underwarranty.
Mar 23, 2009 | 2wire (1000-400108-001) Router
Color problem
Samsung color wheel fix
http://www.jangro.com/a/2006/07/24/samsung-dlp-replace-color-wheel/
Jan 13, 2008 | Samsung DLP HL-P5663W 56" TV
JVC I'Art Pro, Color Fade
sounds like two separate problems. color fade ?
green gun/band = bad convergence ic
Dec 18, 2007 | JVC AV-56WP30 56" Rear Projection...
Green color comes on and off
I need some answers here... Do you have only one video source to test it? Is this happening with an external source or with your tv tuner or both? I need more info....
Aug 10, 2007 | Samsung HCL4715W 47" Rear Projection...
Color Turns Green
HI PLEASE ADJUST THE SCREEN CONTROL OF UR TELEVESION SET IT IS INSIDE THE TV..IF U KNOW THE SCREEN CONTROL IN THE SET THAN MAKE IT LITTLE ANTICLOCKWISE.AND THE SET WILL BE OK..
May 13, 2007 | Sharp 27H-S60 TV
Panasonic CT-32SL13 32" TV Logo
96 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Demonic-2011
Demonic-2011
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
