Trying to set up my wirless card - Computers & Internet
    Scholar:
  • 176 Answers
So what is the problem? you cannot installed it what is the error
Posted on Apr 15, 2008
Need to connect laptop the inyternet
if you have a laptop the drivers should already be installed depending on the internet that you are trying to hook up to you may need a security code if its your own internet service and you dont have security set up on the wireless router it should connect I could be wrong but I think all laptops are wireless capable if not you will need a wireless card instaled in the laptop and the drivers would be installed with the wireless card unless the drivers were uninstalled then you would have to find out what wireless card you have and look for drivers for it
Dec 23, 2012 | Samsung RV515-A01 15.6 Laptop X2 1.6GHz...
I have Del vostro 1014 and i Wifi doen't work
hi
install the latest BIOS and latest wireless drivers for this issue
from the http://support.dell.com
still if the problem persist call dell support and inform the issue they will replace the wireless card
Mar 20, 2010 | Dell Vostro 1400 Notebook
Want to get on internet with my lap top via wireless what card do i need for the inspirion 8100
first of all you need to check with your internet provider to see what modem you can use. a wirless 802.11g card (the farthest range) if your provider has a wirless modem i would get it from them. and a wirless modem/router. i use bellsouth wirless dsl and bought the equipment from them. if you have a wirless modem/ router already then you just need the card and configure it.
Jul 26, 2009 | Dell Computers & Internet
Where is the SSID on my at&t router and what is the WEP Key? I am trying to connect my PS3 wireless up.
ssid is service set identifier usually sniffer software will find them. the wep wirless encription protocall is a key number usually found on a sticker on the bottom of the wirless modem, router .
Jul 09, 2009 | Acer Computers & Internet
I have a dell inspiron laptop. It quit connecting to internet.
You may have to upgrade your Router's Firmware - so will need to know what make & model is your router?
In the meantime here are one or two actions you can take:
1. Disable Windows Firewall
2. In Internet Options Control Panel go to the connection tab and then the LAN Settings where you can uncheck the "Automatically detect settings" button.
3. If you have any third party software, I would get rid of this and ensure that the"Windows Zero Configuration" in the Services menu is set to "Automatic" and the status is started.
Interestingly, Anti Virus programs sometimes interfere with wireless set up - you could see if it helps by disabling it whilst configuring your wireless. It might also be worth trying to connect without any encryption code & see if that will connect - you can then sort out the encryption.
You might find this site of some use
http://www.vista4beginners.com/How-to-setup-a-wireless-connection
Apr 24, 2009 | Dell Computers & Internet
I am trying to set up a wireless connection to our LAN at home. I need help.
Well ther should be a wirless icon on the botom right corner of your screen when trying to acess it form a notbook computer. You will need to right click on it and say view wirless networks. Then find the one that is your and try to conect if it need a WEP password it is on the bottom of router.
Dec 31, 2008 | ASUS WIRELESS ROUTER |WL-520G - RT...
One wirless alltel card two different laptop
well if you only have one wireless card and two laptops, you are going to have to pick one to use. You obviously cant use one card in both at the same time.
If one has a hard wired NIC then you cold plug it directly into a router.
You can still set up the software n both laptops and switch the card between the two if for some reason you want to switch the card between the two.
You would also have to set up the setting on both the be the same such as the wirless netwrok KEY and what not.
Hope this helps.
Nov 23, 2008 | Dell Latitude C600 Notebook
Tiscali wirless connection issue
Sounds like the router may need a firmware update as the DHCP service is failing to run correctly.
You can however just use a static ip address.
First of all find out the network address in use.
eg. 192.168.0.1 - 192.168.1.1 - 192.168.2.1
to find out, - start menu - run - cmd - ok - ipconfig
1. Log on to the client computer as Administrator or as Owner. 2. Click Start, and then click Control Panel. 3. Click Network and Internet Connections. 4. Click Network Connections. 5. Right-click Wireless Network Connection, and then click Properties. 6. Click the General tab, click Internet Protocol (TCP/IP) in the This connection uses the following items list, and then click Properties. 7. In the Internet Protocol (TCP/IP) Properties dialog box, click Obtain an IP address automatically (if it is not already selected), and then click OK.
Note You can also assign a unique static IP address in the range of 192.168.0.2 to 192.168.0.254. For example, you can assign the following static IP address, subnet mask, and default gateway:
IP Address 192.168.0.2
Subnet mask 255.255.255.0
Default gateway 192.168.0.1
Jun 20, 2008 | Linksys WPC54G Wireless-G Notebook Adapter...
Wireless internet is not working my wirless card does not work
remove network connection for wirless,
remove wireless card,
reboot,
then shut it back down,
while off reinstall wireless card then boot back up,
it should ask you to configure it.
May 02, 2008 | Computers & Internet
I am trying to set up second computer I have installed the wireless pci card on second computer and it still is not working. What else can I do to correct this problem.
Check in device manager to see if your wirless card is getting detected.
Also check if your are putting the correct name of your network and putting the correct network key(ie encryption key)
Apr 15, 2008 | Computers & Internet
Computers & Internet Logo
21 people viewed this question
David Payne
David Payne
