Question about RCA P52926 52" Rear Projection Television
RCA D52w26 I have an rca d52w26.Its just under 2yrs old.I plugged it in after moving and i seen arching.i unplugged it and tried it again.it came on for about 2 mins and i heard a pop.i took the back off and found the fuse blew.i replaced the fuse and it imeditly blew again i took the board out and seen it was wet under the board.i did my best to dry the plastic chassie and replaced the board and fuse.plugged it in again and got nothing.i belive somthing on the board blew.i cant get the part number because the bar code has peeled off.please help.
  • 1 more comment
  • jetsfan5 Apr 15, 2008
    thanks alot.i payed alot for this tv and it needs to get fixed.what is crt?i think the part #is 264102 but not exactly sure.its the board that the power cord plugs into and had the 2 windings and the only one in the bottom tray with the fuse link.ill get a pic asap if you need to see it.thanks again for the help
  • Anonymous Nov 13, 2008
    my tv is arching
  • rosienoo Dec 06, 2008
    I have just been given a Toshiba Rear Projection TV (42inch), plugged it in today and there was a loud cracking/popping noise. Had the back off it and it's arching on what looks like the tripler and under one of the projectors. Tripler and wires from it are blackened and burnt looking. Any ideas?
  • RCA Master
  • 8,617 Answers
Your CRT leaked on the board. You will need to replace the seal as well as the board which got leaked on. Can you post a picture of the board and I will post the board number as well as post a link where you can get another boards at.
Posted on Apr 14, 2008
RCA D52W26 TV Powers on and has sound. It has no picture.
If this is an LCD TV, show a torch light on the screen from a safe distance. If you can see the picture, the back light is not getting on. You may have to call in a qualified service technician.
Aug 02, 2012 | RCA Televison & Video
RCA D52W26- 52 " rear projectio- 3d
try to inspect the convergerce power supply and the convergence output module for cold solder joints around the mos fets...i had seen many of them on the same condition.
Jan 22, 2010 | RCA D52W20 52" Rear Projection HDTV-Ready...
I have a d52w26 tv and the sound is not working. I can get sound when playing vcr, but no sound when using tv only.
You have two different model #'s in your request. If it is a P52926 try unplugging the set for a minute and plugging back in.
Mar 29, 2009 | RCA P52926 52" Rear Projection Television
RCA D52W26 rear projection. 2 years old. 3 times and powers out.
Try replacing CP150, CP114 and CP120 first cost about 12.00 with free instructions available at the following link under the RCA parts category
http://servicemanuals.vstore.ca/
Feb 10, 2009 | RCA P56923BL 56" Rear Projection...
RCA D52W26
very simple fix there's three micro fuses beside the flyback transformer if the center fuse is open check with meter then theres bad solder connections on flyback simply resolder flyback in board &install new fuse. the 3 fuses are brown or tan about a 1/2" long
Nov 19, 2008 | RCA P52926 52" Rear Projection Television
D52W26 Convergence board
Yes the D52W20 and the D52w26 are both ITC222 chassis they are exactly the same
Jul 17, 2008 | RCA P52926 52" Rear Projection Television
RCA D52W26 that won't power on.
Yes that would be the model number. What item are you needing assistance with, as I have so many people I am helping that I need you to indicate the problem unless you respond by the origional post. Let me know what you need help with and I will be able to help you I have alot of experience with RCA/Thomson models
May 12, 2008 | RCA P52926 52" Rear Projection Television
URGENT: My RCA D52W26 Big-Screen TV won't turn on...AGAIN!
These TVs are RCA biggest mistake ,all most all of these models are shutting down accoding to information you just sneeze and they shut down, Id say try soldering around flyback transformer solder all pins.also they have trouble with ribbon connectors as well as the ribbions.
Apr 22, 2008 | Televison & Video
Rca d52w26 makes a long whistle noise
how long? 3 seconds.. does it sound like chirping? is it comeing from back. smell anthing?
Nov 09, 2007 | RCA D52W20 52" Rear Projection HDTV-Ready...
RCA P52926 52" Rear Projection Television Logo
202 people viewed this question
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
