Altec Lansing VS 4221 Right Speaker crackle
I have hooked up new speakers (2 and a subwoofer) to my TV using the green headphone jack and its great all except for a cracle noise interference on the right speaker. Any suggestions. I know I could use the RCA lead with an adaptor but it should not be cracling now right?
Hope you can help me.
  • 56 Answers
First of all take a headphones and connect it to the TV and listen the sound.If it is OK the problem is or the cable or the amp.You probably have two RCA connectors on the cable red and white or black for input of the amp.Connect the cable to the tv again and change places of the RCAs (red to white on the amp and white to red).If cracling is now on the left speaker buy a new cable but if its still on the right you have problem with the amp.And you are right if everything is OK it shouldn't be cracling.I hope that this will help you
Posted on Apr 22, 2008
How do Altec Lansing AVS200W 2-Piece Multimedia Speaker System connect to your computer
Using a regular audio cable with 3.5 mm. connectors at both ends, connect your computer to the speaker from the the headphone jack to the 3.5 mm LINE IN jack on the speaker.
Jul 10, 2014 | Altec Lansing Avs200w 2-piece Multimedia...
I just got a used set of altec lansing ADA745 computer speakers and can't get power to them. I have never seen computer speakers w/ two wires for input to the computer. I plugged the usual green colored...
https://support.dell.com/support/edocs/acc/ada745/ada745.pdf
That is the setup guide for the speakers.
The two wires plug into a cable that then that single cable plugs into the computer, this way you have sound coming out of the left and right hand speakers.
Feb 05, 2010 | Altec Lansing Multimedia Computer Speakers
Where can I download a driver for Altec Lansing ADA745 speakers?
HI, maybe theres been a bit of confusion but your Altec Lansing ADA745 speakers shouldn't need any drivers.
Its kind of similar to you plugging in a pair of headphones into your cumputer, they should work just fine.
Are you not getting any sound? Post the details of your PC (is it a dell?)
model number etc... and describe your problem
You probably need audio drivers for your audio device(inside your pc on your motherboard),
Aug 04, 2009 | Dell Audio Players & Recorders
Hooking 5.1 computer speakers to a Samsung Plasma
Computer speakers are powered, they have their own amps inside the speaker cabinet.
To get these to work on a TV you need to plug them into a headphone out jack.
The external speaker terminals produce too hot a signal for powered computer speakers. The amp in the speakers may have already been damaged.
May 04, 2009 | Altec Lansing ADA995 Speaker
Cannot connect my surround sound altec lansing system to my compu
The first thing you can do is go to www.retrevo.com to download the manual. Secondly all you have to do is match the colors of the wires to the imports in the back. You have five speakers. Two have gray wires, two have red and one has blue. If you also notice each speaker has two wires. One a solid color, the other striped with black. For instance, put the solid red wire into the red import and the red wire with the black stripe into the black import. Repeat this with all the other wires. The easiest way to hook it up to your computer or laptop is to take one of the aux wires (the wires with the yellow/green/black tips). It doesn't matter which one. Put into you headphone import on your computer or laptop. Then put the other side into the Aux on the subwoofer. Located on the front. Turn on the power on the back. Then hit the aux button on the remote. That should work....
If you have any other questions or need any more help you can contact me brown.faith@rocketmail.com
Jan 22, 2009 | Altec Lansing VS3251 Speaker
Does these work with laptops?
try the headphone jack, this should work just fine. I used this type of speaker on this laptop that i am running for many months via the headphone jack
May 11, 2008 | Altec Lansing VS3251 Speaker
554 people viewed this question
 Grubhead
Grubhead
