FixYa.com
Tags:
Panasonic DMR-E55 DVD Recorder
Panasonic DMR-E55 menu problem
By M0nica L - usenet poster
I recently purchased the Panasonic DMR-E55 DVD recorder and recorded a
regular 8mm video cam movie on to a DVD-R.  I edited the title for the
chapter, gave the dvd a name, finalized and all appeared to go well.
The dvd video and audio quality are great but the creation of the menu
was trashed. The bottom 80% of the screen is black.  The top portion is
visible with the correct thumbnail and title.  Something obviously went
wrong during the write of the menu image.  I've tried low and high
quality (Verbatim) DVD-R 4x media.  Has anyone else seen or heard of
this?
-dbc
This Problem has been added to the Share Your Expertise Page under "My Work Queue".
Best Solution
posted on Jan 25, 2008
Helpful (85)
Guest
Guest
Rank:Apprentice Apprentice
Rating: 0%, 0 votes
I am currently using HP 16x discs in E55. All of them are finalizing fine except for one. I had time shifted a recording, and then about three/four months later I finalized the disc and I had the same problem you encountered. For me, it was a one time thing.
Was this solution helpful? Show your Appreciation by rating it:
Solution #2
posted on Aug 10, 2005
Not Rated (0)
2Pansy
2Pansy - usenet poster
Rating: 0%, 0 votes
Is anybody using their e55 to record video camera movies?  If so are
you seeing any menu writing problems?  And what media are you using?
Are you using line input 1, 2 or 3?  Is cable hooked up for tv
recording?
Solution #3
Not Rated (0)
Pasty
Pasty - usenet poster
Rating: 0%, 0 votes
It was Datalife Plus.  Check this out - I did a bit of testing and this
is what I found.  I called Panasonic and they had not heard of such a
problem so I took the unit back and exchanged it for a new one.  I
hadn't originally connected the first unit to cable since i was only
creating dvds from a video camera. So I hooked it up to cable, setup
the channels, etc and recorded some tv shows.  After finalizing, the
menus came out fine!?!  (on low and high quality media so we can take
that out of the equation)  I tested again with video camera as source
(on low and high quality media) and the menus came out fine!  Cool, I'm
happy, there's some weird requirement with cable being attached, I'll
deal. I tried with just an antenna hook up and no dice, bad menus.
Fine.  I go to bed, come back the next day, burn another dvd from a
video cam... perfect.  A couple hours later, I burn another from video
cam and whoa - bad f_in menu!!  I run another test because I had
disconnected the camera before finalizing, thought maybe the thing is
flaky that way but again - bad menu.  I'm at a loss.  I found a forum
where several other people had the same problem:
http://www.avforums.com/forums /archive/index.php/t-132230.ht ml
but no solution...
-dbc
Solution #4
Not Rated (0)
lawyer
lawyer - usenet poster
Rating: 0%, 0 votes
On 7 Jan 2005 11:16:55 -0800, "dbc" <dave.b.chand @comcast.net>
wrote:
I haven't had that happen, but one disc I finalized isn't recognized
by my computer, though it will play on the Panasonic (E75) and another
DVD player. I blame it on the media (Memorex) though.
-Jon Purkey - <jonpur @aol.com)
 For a quicker reply by email please use the
 address found here: http://tinyurl.com/o8ka
Solution #5
Not Rated (0)
Powe33
Powe33 - usenet poster
Rating: 0%, 0 votes
wrote:
What Verbatim disc was it. There is a crap disc called verbatim
datalife which are really bad.
The datalife plus ones are the good verbatims.
Can you Help with these DVD Players problems?
Connecting DVD Player to TV...
Hi, From the TV I've connected... Answer This...
Stays in self check mode
Keeps coming up self check and... Answer This...
panasonic DMREX75
Can you tell me how to decode... Answer This...
DVD-ram
When i try a new panasonic... Answer This...
panasonic dmr-e55 - on-disc...
Is there a simple way to turn... Answer This...
Repair Service
Find DVD Player Repairman Near You:
FixYa does not evaluate or guarantee the accuracy of any information provided through its proposed solutions, posts, or Expert Assistance Sessions. By entering this site you declare you read and agreed to its Terms. You may NOT copy or distribute the content that appears on this site without written permission from FixYa Inc.
© 2005-2008, FixYa, Inc. or its affiliates
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
