Can't find part number
I have a Fellowes powershred 380cc. The white nylon gear located on the motor drive shaft is missing a tooth. I can not find the part number for the gear.
Thank you
  • 3 Answers
I would like you to find the bar code on your shredder. Once you find the bar code label look right under the bar code strip and get the numbers. It is a serial number.
Posted on May 02, 2008
The cross cuts are not working
It sounds as if the gears that turn the cutters is either broken or is turning freely on the shaft w/o engaging the cutters. If this is the case you will have to replace the gear(s). The cost of the gears may entice you to buy a new or refurbished shredder. Below is the manual for your machine, it may be of some help-just maybe.
Fellowes Shredder Manuals
Feb 13, 2014 | Fellowes Powershred 99Ci Cross-Cut...
Plastic GEAR 5403 07-1 B1
Here is a link where you can find a replacement: http://www.sportslinkup.com/shop/0-Fellowes-gear-1.html (Part Number 205993 OEM Fellowes Shredder Gear Kit for Model P-55C). They have the whole gear assembly.
I need the same for my P-57Cs shredder (broken stage 2 gear 540307-1. Hope it helps, good luck!
Dec 04, 2010 | Fellowes Powershred P-55C Shredder
Od700c shredder: motor spinds, blades don't move
Inside the motor assembly there are a series of nylon cogs , a large one of which interacts with a metal one.  This is the most likely place you have one or two teeth missing from the large nylon cog that drives the shredder blades.
Sep 22, 2009 | Fellowes OD700C Shredder
Fellowes PowerShred PS 40 with defective switch
Its just seated together with the gear/blades housing ,
make sure you didnt miss one screw, then pry and pull upward its just stuck as the gear housing and blades are pressed in and seat firmly making it seem like its stuck , over time all that paper goo is also binding it up .
Heres a few sites that have gears another that has manuals you may have to call or email as not all parts are listed on website
http://www.compax.com/shredders/parts.html
http://wheelermachines.com/manufacturer.html
http://www.manualsonline.com/ex/thread/view/idThread/1735067
May 16, 2009 | Fellowes 3011001 Shredder
The gear opposit the drive motor broke (driven worm gear)
This is how a got my hard to fine gear!
Contact Michael Business Machines for your local dealer 1-800-223-2508
Good luck, Tom
Dec 19, 2008 | Fellowes P70CM Shredder
Motor runs both forward and reverse, but cutters don't turn
How about a hidden 7th screw? If you look at the sticker on the underside where the bar code is you may see a dimple like there is a hollow space under it. If you can't see it, rub your finger over it to find the hole. Just stick your phillips screw driver through the sticker to get access to this last screw. As for the motor working both directions but the cutter doesn't turn it is most likely a broken nylon cog on the drive gears within the white plastic housing at the end of the shredder. There are 3 or 4 gears - all nylon (plastic), my unit had one tooth completely broken off and the one next to it was worn. I am looking into finding parts but I'm not having any luck so far with local service centres. I have a call into the fellowes main 1-800 number to see if they can help. On reviews I have seen this is a common problem. One reviewer was told they use nylon to reduce noise, but of course it isn't going to last long, especially if you ever jam. Nice metal cutters but the weak link is the drive gears that you can't see.
Oct 16, 2006 | Fellowes P600C-2 Shredder
181 people viewed this question
jasbo
jasbo
