Question about HP OfficeJet G85 All-In-One InkJet Printer
HOW to print ONLY in Black and White when the original is in color
I have changed the settings to greyscale draft. I still get color.
Have a HP Officejet 4300 All in One series.
User guide and HP website had no solutions.
THANKS!  SJ
  • B Joan Rapier
    B Joan Rapier May 11, 2010
    Hello Jellita
    When you chose Grayscale, did you chose it as your default configuration in the printer preferences? If you didn't, you'll need to select Grayscale each time your print.
    If you selected "draft", that's not necessarily w/out color. It'll just use less ink but it'll still use color inks.
    "Grayscale" is the option to choose if you do not want to use color at all.
    Look in your printer preferences in printer properties and find the option to set it to Grayscale by default.
    Unfortunately, I'm unable to give you the exact steps as I don't have that particular printer.
    Make sure that when you change your printer preferences that you click the OK buttons to get out of the properties windows rather than clicking the [X] in the upper right-hand corner of the window. If you do the latter, the settings won't be saved.
    Please, post back and let us know if this information helped. We'll keep working w/ you until your problem is resolved.
    Thank you
    BJ @:)
    Sergeant:
  • 202 Answers
***IMPORTANT NOTE***
Once you assign ratings to the experts' contributions, the problem will be automatically closed and we'll no longer be able to assist you. So, please, wait until your problem has been resolved before assigning ratings and choosing the "Best Solution". As long as the problem remains open, we will continue to work w/ you until it is resolved.
When you no longer need our assistance, kindly take a moment to rate the experts' contributions ("solutions") and to choose a "Best Solution". It is customary to assign "FixYa" ratings to the expert(s) whose contributions solved your problem(s) or answered your question(s).
Thank you again,
BJ @:)
Posted on Apr 14, 2008
    Genius:
  • 1,447 Answers
If printing from computer windows base
The all-in-one will reproduce many colors exactly; however, it is normal that some colors may be slightly different in shade or hue. If the colors are more than slightly off though, there is a problem. Review the information below to correct the problem:
  1. Verify that the Color settings have not been changed by following the steps below:
    1. In the software program you are printing from, click File and then click Print .
    2. Click the option to change the print properties (usually Properties or Settings ).
    3. Select the Color tab.
      • Print in Grayscale should not be selected unless you want to print in black and white.
      • The Color Attributes sliders should be centered, in the middle of the setting.
      • The Color Space setting should be set to sRGB/sYCC
If printing from Mac
  1. Verify that there is paper loaded in the input tray.
  2. Open a document in the software application in which it was created.
  3. Click File and then choose Page Setup .
  4. Select the HP All-in-One as the printer.
  5. Choose the paper size.
  6. Select the paper orientation.
  7. Enter the scaling percentage.
  8. Click OK .
  9. Click File and then choose Print .
  10. On the Copies & Pages panel in the Print dialog box, change the print settings for each option in the pop-up menu, if necessary. if no option to change color when you click on the bar check if you have color management: then change from color to B and W.
  11. Click Print.
** and chances if you are printng from computer might not have an option to print draft B and W, just check for quality.
Hope this helps, if it does pls dnt 4get to rate solution, thanks!!
Do I have to have a color cartridge in order to print? Can I just use a black ink cartridge?
The HP DeskJet 6122 can print with both or only one ink cartridge installed. The printer driver includes an option to print in gray scale as a substitution for color. If you choose to print a document that has a color other than black and white with only a black cartridge installed, I recommend you select the gray scale print option. To select gray scale, select the printer properties and check the box for gray scale rather than color printing. This selection can be made either at the time a document is ready to print (ie., a one time selection, using the "Properties" box in the print options window), OR as a permenant setting using the Control Panel, Printers, HP DeskJet 6122, "Properties" window. Once changed in the general printer properties, these settings remain active anytime the HP DeskJet 6122 printer is selected to print a document.
Sep 03, 2013 | HP DeskJet 6122 InkJet Printer
HP 722C has quit printing black in color draft
WORKAROUND: Select EconoFast or Draft as the print quality setting in the printer properties. This will prevent the color cartridge from being used. - Or - Try another color cartridge. The color cartridge is used to print grayscale images in Normal or Best print modes, so if one color has run out, the printout will have the wrong tint. With a full color cartridge, the colors can be properly combined to create a composite black. CAUSE: When printing with Normal or Best as the print quality setting, the HP Deskjet 710C or 720C or 722C series printer will use the color ink to improve print quality output, even when printing a grayscale image.
Sep 07, 2007 | HP DeskJet 722c InkJet Printer
How to make the HP Deskjet 3054 Print in only black
Select 'Print' from your software package and then 'Preferences'. Select the 'Color' tab, click on the 'Print in Greyscale' box and select the 'Black Cartridge' box..
Jul 13, 2011 | HP Officejet 5610 All-In-One InkJet...
How can I get my HP 6500a plus printer to PERMANENTLY default to black printing? I am needlessly using too much color and the default setting is only for a single document.
Hi
Go to right click at the printer icon on your computer and choose printer properties or printing preferences and from there choose the color setting to print in black alone. Regards
Jun 23, 2011 | HP Officejet 6500 Wireless All-in-One...
My printer will not print in black. It will use the other colors, but not black. When I try to print a black and white document, it prints in blue.
if u want to print selected document in black than open the document select print go to printer properties select grayscale printing
always print in black
go to printer properties than go to maintenance than go to ink cartridge setting select ink cartridge black only for balck and white printing only.
OR
CHANGE CARTRIDGE
Jun 18, 2010 | Brother MFC 240C All-In-One InkJet Printer
I do not want to buy color inks. greyscale printing is all i need
Hello Lisa; Your machine can't satisfy what you want, because this machine make for color purpose, therefor, if they run out any cartridge they don't work, same reason if you don't want color printer why don't buy black and white ?
Nov 22, 2009 | Brother Office Equipment & Supplies
I have it set to print in black only but it uses up the color ink anyway. What gives?
On the printer driver, (after click "print" and the menu for selecting the printer appears and you can select the number of copies etc...go to"properties") . Here go to the "Color" tab.. if you truly only want to use black ink, then select "Print in greyscale" and select "Black only". After that just Click "OK" at the bottom and "Ok" to print your job in truly just black ink. :)
Cheers, Ed
Nov 22, 2009 | HP Photosmart C6180 All-In-One InkJet...
HP Deskjet, Set to Black & White; but still prints with color!
Bronze, hopefully this is a logical issue: Assuming you're on WinXP > Go to Start>Control Panels>Printers (and faxes).
Find the printer in question in the list (maybe there's only one or 2 listed) and 'Right-click' on the icon > go down to "Printing Preferences" (about second/third down the list).
In here you will be able to set the printers default settings. I'm not 100% familiar with HPs printing dialog, but there maybe a setting there for either 'Black & White' and 'Grayscale' (albeit it should be greyscale, anyway...) if you choose black and white your printing will not have any mid-tone, so if there's a choise, choose 'Grayscale'.
You can set other features here which will become the new default each time you go to print something - personally I set to 'Draft' or 'Fast Draft' mode by default, that way when I just print out rubbish, I am saving "lots" of ink and if I want something in good quality, I change it at time of printing.
Now, there are some programs and files that "remember" you last print settings, so if you've used a colour print setting previously, that file may still pring in colour, even though the new defaults are mono (black & white). So, print using the new defaults and save the file when finished. It's unlikely the case with OpenOffice, but, I don't know. We'll tackle that as we get to it.
So, if that has not cured the problem, please let me know.
**.The best way to acknowledge contribution is to rate it's relevance.**
Feb 05, 2009 | HP Deskjet 3845 InkJet Printer
Dell Photo All in One Printer 964
Try printing a windows test page from the driver software, START-SETTINGS_PRINTERS-DELL964- properties,,etc. If the test page prints with color then I believe that your driver is set to print in greyscale. If you can't find that option in the driver you might try to re-install the driver from your original cd.
Aug 28, 2007 | Dell Photo 964 All-In-One InkJet Printer
HP OfficeJet G85 All-In-One InkJet Printer Logo
538 people viewed this question
Ben Johnson
