Question about Toshiba Satellite P105-S6104 Notebook
Laptop volume broken
I have just bought a toshiba laptop and the volume was working fine until today. I have tried to click on my speaker icon but it says no volume output device is on the computer. how could this have changed? and how do i get my volume back?
  • 55 Answers
Go to control panel/sound and audio devices/audio and check your sound card also check place an audio icon in the taskbar (you might uncheck it and check it again)
Posted on Apr 15, 2008
My volume buttons are not working when I press the volume to go up or down
Anonymous, depending on your setup and laptop, you may be able to press the FN button and hold it while you press the speaker button up or down. If you have a Speaker icon in the lower right screen near the Time you can click on that to change the volume. If that is not available, you can right click that area and select properties. Then, see that the Speaker icon is set to ON to show up on your screen. Hope this helps.
Sep 10, 2014 | Toshiba Satellite Computers & Internet
Sound card problem toshiba c55a
C55-A Toshiba , Low volume on my ear phones . Click on speaker icon . Click on Speaker icon, at top of speaker Volume . This will take you to Speaker properties . Select drop down menu in the advanced tab. I changed my bit rate until I found one that worked with my ear phones .
Dec 29, 2013 | Toshiba Computers & Internet
Iis there a volume control on toshiba tecra a2
If it's plugged into a external speaker system, doesn't the external speaker system have volume control? In the Tray Notification Area, right click or click on the Sound Icon, adjust volume OR open the Control Panel and select Sounds Icon. Laptop aren't known for great sound, I use this: http://www.bose.com/controller?url=/shop_online/digital_music_systems/sounddock_systems/sounddock_portable/index.jsp
Apr 11, 2013 | Toshiba Tecra A2 Notebook
The sound comes and goes on my Toshiba C655 laptop. It goes out then comes back on its own. All indicators say the sound is working fine, the speakers are fine...the mute is not on...no help with...
if the laptop is less than 6 months old you should still have warranty you could retutn it on a warranty issue before you touch anything but you could attempt some basic troubleshooting
if your computer came with a motherboard disc the sound drivers could be on it
click start control panel administrive tools computer management device manager scroll to sound,video and game controllers you might see a yellow question mark? Right click to reinstall drivers
click start control panel sounds and audio,volume,advanced,speakers make sure you have selected the
(((appropriate speakers))) also audio you will find 3 drop down lists make sure you have the correct settings there
also
click start control panel sounds and audio devices you can adjust the volume there also select speaker volume you can change your settings there you can also tick in the box place icon in taskbar
if his does not fix the problem
have you tried this control panel sounds and audio,volume,advanced,speakers select the appropriate speakers from the drop down list or navigate to the device manager scroll to system devices + to expand,system speaker right click properties then select use this device (enable) also you might check
the speakers plug/outlet is usually at the back of the computer you will have to open up the computer to check the lead attached to the rear of the input plug make sure the connection is good
try cleaning your computer of dust using a fine air blower from a compressor making VERY sure that there is no MOISTURE in the air line specifically around the sound card and the CPU central processing unit dust causes static to build up in a computer
hope this helps
Apr 09, 2011 | Toshiba Computers & Internet
My sound on my acer aspire 5516 works fine until i put in a dvd then the sound will not work how do i turn it on ?
Double click the "speaker icon" on the right bottom bar to open the
volume control menu.
Check be sure that the check box "mute all" on the bottom of volume control
is not checked.
On an "Acer Notebook" try to press following keys combination: FN+F8
FN+ F8 : turn on / of speaker.
FN + > to increase the volume.
Good look
Feb 19, 2011 | Acer Aspire 4520-5582 Notebook
Where is the volume control on a Satelite C650 series laptop?
Select the Speaker icon in the task bar menu
Right click the Speaker icon
Select Open Volume Mixer
and there it is.
Try this link if you get lost
http://eu.computers.toshiba-europe.com/innovation/jsp/supportMyProduct.do?service=EU#tab4;
Regards
Oct 18, 2010 | Toshiba Computers & Internet
My son installed speakers on my Toshiba laptop
Right click on on the speaker icon. Click on adjust audio properties. Under the volume tab, if the mute is selected, deselect it. click advanced under the speaker settings. Select laptop stereo speakers.Click OK. close all windows. Restart.
Jan 25, 2010 | Toshiba Satellite A135-S4527 Notebook
Hi, the camera works really well, but the audio breaks up to the point where it does not work. I did a complete reload of the software, did the audio test on the Echo - all appeared to be working fine....
Sometimes problems can occur when you have a laptop and a webcam and default is not set within your computer.
TEST SPEAKERS
Right click on speaker icon in System Tray
Select "Playback Devices"
The speaker icon ( checked as working) and volume level graph should be visible
Right click on the volume graph and click "Test"
Left hand speakers followed by right hand should be heard
SET DEFAULT & TEST MIC
Click "Recording" tab.
To set required (webcam) mic as default - click on mic font to highlight and click "Properties"
In lower dropbox display "Use this device enable" click OK
Click "Levels" tab and ramp up sliders ( adjust to suit later)
Return to "Recording". Test mic by speaking and make sure volume graph displays
Restart computer
Jan 24, 2010 | Logitech Quickcam Chat Webcam
Toshiba laptop speakers
Okay, without knowing the full model number I think this maybe the page your looking for:
http://www.csd.toshiba.com/cgi-bin/tais/support/jsp/modelContent.jsp?ct=SB&os=&category=&moid=2221250&rpn=PSLB8U&modelFilter=L300-ST3502&selCategory=3&selFamily=1073768663&selModel=2221250|PSLB8U
On this page click on downloads, on the operating system pull-down menu choose Windows Vista, then in the pull-down menu next to it choose Sound.
Click on the Realtek audio driver, click on the download button and download the file to the desktop or any other location that you'll remember and then after the download, double-click on the file and let it run to install the software and then you might have to reboot after that.
See if that works, if not then let me know and I"ll help you further, if it works then rate me when you get the change ok?
Let me know how things turn out.
Feb 28, 2009 | Toshiba (P000377700) Computer Speakers
No Volume at all my Laptop - Lost
Have you tried reinstalling the audio drivers? Check in device manager and see if you see a question mark by the speaker icon. If you double click on it, it will allow you to reinstall your drivers. Good Luck.
Feb 11, 2009 | Toshiba Satellite A100-S8111TD Notebook
Toshiba Satellite P105-S6104 Notebook Logo
158 people viewed this question
Top Toshiba Computers & Internet Experts
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
