I have a Whirlpool model LA9580XWW1. The botom part spins but the top part seems to be loose, it doesn't spin.
    Problem Solver:
  • 5 Answers
The top part of the drum? or the center spindle?
Posted on Apr 14, 2008
All the water does not spin out of the clothes & at times it doesn't even seem like it is spinning
Problems with a washing machine not spinning or not draining are often interrelated..
If you are having a problem with your top load washer then check out thistip...
Washing Machine does not Pump or Spin
If you are having problems with your front load washing machine then checkoutthis tip...
Front Load Washing machine not draining and or not spinning
heatman101
Jun 07, 2011 | Whirlpool LSR6334LQ Top Load Washer
Spins on one cycle, but not the other
sounds like timer is loosing contacts and time to replace.
Jul 21, 2010 | Whirlpool LSR7333 Top Load Washer
Problem with washing machine spin cycle.
see if belt is loose if it is a no belt model you will need a repair man to change some parts
Mar 29, 2010 | Whirlpool Ultimate Care II LSQ9549L Top...
Washer will not spin or agitate. Pump works.
This assumes that you have a basic Kenmore / Whirlpool top load, direct drive, neutral drain (it doesn't spin until the pump removes most of the water) machine.
First, see the Sears parts site for your washer:
http://www.searspartsdirect.com/partsdirect/index.action
Enter your model number (###.######) and you'll see a list of major sub-components with diagrams and parts.
First, see the following Whirlpool Kenmore installation and service manual for top load, direct drive washers.
https://secured.whirlpool.com/Service/SrvTechAdm.nsf/2cd44500d572193285256a45004fd9d6/f7e2147fa98b28cf85257122007475cb/$FILE/L-55.pdf
If it drains and you can hear the motor trying to turn the transmission for the agitate mode, the obvious first answer is the Motor coupler. I'd replace it just to be sure.
If it's not the Coupler, the problem points to the transmission itself.
There are only two components of the gearcase that are used for both agitating and spinning.
One is the Agitator shaft which drives the agitator and holds the spin pinion that drives the clutch for spinning.
The other is the main "Bottom and pinion gearcase" itself.
Please see the following Whirlpool parts list for commercial top load direct drive washers although the consumer models use the same transmission parts.
http://shared.whirlpoolcorp.com/assets/pdfs/literature/Repair%20Part%20List%20-%20W10114743.pdf
Oct 24, 2009 | Kenmore Washing Machines
My washer will not spin on its own, if I give it a spin, it seems to take off
need to get the agitator belt replaced, problem is that it is not tight enough to get it spinning almost like a loose fan belt on a car
Jul 04, 2009 | Whirlpool Ultimate Care II LSQ9564J Top...
Spin cycle not working
hi
if it is not draining it won't spin right,if it is empting out ok then it can be the solenoid if that model has one, if it has belts check that they are not loose
cheers grant
Nov 11, 2008 | Whirlpool LSN1000LW Top Load Washer
Whirlpool top loader model 3LS C8255EQ1
if the motor is running during the time its supposd to be agitating and the motor is running during the time its supposed to be spinning. then you need to replace the motor coupling. it connects the motor to the transmission it is broken and the is no connection anymore. the motor coupling is only about 10 bucks.
Feb 16, 2008 | Whirlpool LSB6200KQ Top Load Washer
Washing Machines Logo
26 people viewed this question
Top Washing Machines Experts
