Question about IBM ThinkPad T43 Notebook
IBM Thinkpad T43 Memory
The laptop has 512Mb, I added 1 Gb to the easily accessable memory slot, how difficult is it to access the one that has 512 to upgrade it too to 1 Gb?
Is it as easy as just taking the back off?
Thanks in advance
  • 159 Answers
Ok listen listen the answer is this the other memory is right under the keyboard. turn the lappy upside down the screws that hold the keyboard in are the ones mark with two triangle then open the lappy like you would normally for operation use a screw driver flat head is good put it between the bottom left or right corner better yet put it in line withe the down arrow key push the keyboard up as though you are pushing the function key closerto the top then pluck up the keyboard gently as you would a tin of paint gently a cable is there that connect the keyboard to the motherboard disconnect install the memory then work the steps backward
Posted on Apr 16, 2008
IBM T23 wont turn on after adding new RAM
Hi - according to memory suppliers your T23 has the following memory capacity / requirements:
  • IBM ThinkPad T23 maximum RAM capacity: 1GB
  • Your IBM has Two (2) memory slots or sockets
  • Module upgrade PIN count is: 144-PIN
  • The memory speed is: SDRAM 133MHz, PC133
  • The laptop DIMM type for the ThinkPad T23 is: SODIMM, SO-DIMM, Small Outline DIMM
  • Non ECC
If you are meeting these requirements, you may have a defective module.
Also, according to Lenovo's page on the machine:
Memory
The system has 128MB or 256MB of memory standard and can be configured for up to 1GB of addressable memory. Memory options up to 512MB SDRAM SO DIMMs each can be added in the two available slots for memory expansion. The standard 128MB of memory is expandable up to 640MB and the 256MB of memory is expandable up to 768 MB of addressable memory with 64, 128, 256, or 512MB SO DIMMs without removing the 128MB SO DIMM that is standard in one of the internal slots for memory. For customers that need the maximum 1GB to which memory can be expanded, it is necessary to replace the 128MB or 256MB card with a 512MB card plus add another 512MB card in the extra slot. Only 133MHz DIMM memory can be used in this system. The use of 100MHz DIMM memory is not supported in the T23 systems.
This means yo can trouble shoot the 512MB modules individually by installing one of the original 128MB modules and one of the new 512MB modules (for a total system memory of 640MB). If it does not boot, try again with the other 512MB module. This will help you identify a defective module that may be preventing the machine from booting.
I hope this helps & good luck!
Sep 28, 2012 | IBM ThinkPad T23 Notebook
I have 512 mg of memory. Would there be a big difference if I add a 1 gb stick and keep the 512 mb , as oppose to removing the 512 mb and replace with two 1 gb sticks?
The performance of your laptop will improve if similar memory is placed in each of memory slot.If 1gb memory and 512mb memory are placed in available slot you will only get the performance of a single 1gb memory.but two 1gb memory are used performance will be similar to a 2gb ram or more.
May 30, 2010 | Acer Aspire 3003WLCi Notebook
How can I upgrade memory from 256MB?
Check any free memory slots available in the laptop and upgrade the same.
Revert back for assistance.
Jan 20, 2010 | IBM ThinkPad R32 2658 Notebook
I want to upgrade the ram in my IBM thinkpad R52 laptop. Do I have to buy DDR1 or DDR2?
You have to buy DDR2. The compatible memory is DDR2-533 PC2-4200, 200p SODIMM, 1.8v
To install the memory, follow these steps:
  1. Turn off the system; then disconnect the ac adapter and all cables from the system.
  2. Close the system display, and turn it over.
  3. Remove the battery.
  4. Loosen the screw on the memory slot cover; then remove the cover.
    If the SO-DIMM is already in the memory slot, remove it to make roomfor the new one by pressing out on the latches on both edges of thesocket at the same time. Be sure to save it for future use.
  5. Find the notch on the side of the SO-DIMM.
    Note: To avoid damaging the SO-DIMM, do not touch its contact edge.
  6. Withthe notched end of the SO-DIMM toward the right side of the socket,insert the SO-DIMM into the socket at an angle of about 20 degrees (1);then press it firmly (2).
  7. Pivot the SO-DIMM downward until it snaps into place.
  8. Make sure that the card is firmly fixed in the slot and does not move easily.
  9. Replace the memory slot cover by aligning the back side of the cover first and then tightening the screw.
    Note:When you have added or upgraded a memory card, do not use your systemuntil you have closed the cover. Never use the system with the coveropen.
  10. Put the battery back in place, turn the system over again, and reconnect the cables.
To make sure that the SO-DIMM is installed correctly, do as follows:
  1. Turn the system on.
  2. Whilethe "To interrupt normal startup, press the blue Access IBM button"message is displayed at the lower-left of the screen, press Access IBMbutton.
  3. Select Start setup utility.
  4. The BIOS Setup Utility screen appears. The "Installed memory" item shows the total amount of memory installed in your system.
    For example, if your system has 256 MB of memory and you install a256-MB SO-DIMM in it, the quantity shown in "Installed memory" shouldbe 512 MB.
The compatible memory can be purchased here online.
Nov 27, 2009 | IBM ThinkPad R52 Notebook
I would like to nwom how much of memory this laptop support
The Thinkpad is installed with 128 MB SDRAM is standard, and is expandable to 512 MB
There are two memory slots, to expand it to 512 Mb you need two 256 Mb RAM modules and throw away the 128 Mb RAM module, but if you don't throw away this module and you insert a 256 Mb RAM module in the 2nd memory slot then your total memory would be 384 Mb.
Nov 20, 2009 | IBM ThinkPad T20 2647 Notebook
Is it possible to install high desnsity memory RAM on a T42
The T42 can support up to 2 Gb of RAM.
The laptop comes with 512Mb of RAM under the keyboard and a spare memory slot on the bottom of the laptop.
To install 2Gb of RAM put 1Gb in the memory slot under the kerboard - need to remove the old RAM and put the other 1Gb in the memory on the bottom of the laptop
T42 Memory specs.
  • 64-bit Double Data Rate (DDR) non-parity SDRAM memory
  • PC2700 at 333MHz
  • Two 200 pin SO-DIMM memory slots, one slot is pre-populated with 256MB or 512MB, leaving one socket available
  • Supports up to two 1GB SDRAM SO DIMMs
  • Supports maximum memory up to 2GB
Sep 22, 2009 | IBM ThinkPad T42 Notebook
Adding memory, new total not recognized: IBM Thinkpad R51e-1844
Ram should always be paired. Same type, speed and size in each slot. You may have 1 SIMM/DIMM/DDR that has 2 sides of chips and the other with 1 which will do exactly what you state. RAM reads across the chips simultaneously. So if you have a different one in each slot it can go bonkers and do goofy stuff on you.
Jun 14, 2009 | IBM ThinkPad R51 Notebook
IBM ThinkPad T40 2GB Max RAM
The T40 has two ram slots, you can put a 1g chip in each totaling 2g. If the chip will remove, then it is changeable. Vista needs a minimum of 256 to run, so, when you change BOTH chips to equal 2g it will probably read 1.744g, or it may read the full 2g. If it only reads 1g, then the second slot under keyboard may have malfunctioned. It could also be that the 256 chip is bad and your really only running 512 now. With all that said, in order to achieve 2g, you will need to put a 1g chip in each slot.
Jul 08, 2008 | IBM ThinkPad T40 2373 Notebook
IBM ThinkPad T43 Notebook Logo
308 people viewed this question
Top IBM Computers & Internet Experts
Alun Cox
Are you an IBM Computer and Internet Expert? Answer questions, earn points and help others
