Question about Gateway (4000782) Motherboard
Gateway Intel 850 Motherboard will not boot
Working on Intel 850 motherboard socket 478, received from a friend, would boot with three beeps, when I tried the other memory bank for ram no more beep, but will not show any picture. Have tried to reset cmos and bois, swap out memory with good stuff, tried swaping video with no luck, and finally still nothing, I have even swap out motherboards and cpus. With no luck. Can anyone help. Even tried calling gateway, with no luck there either,
    President:
  • 2,351 Answers
Please download a memory (RAM) testing program for free. Click the link. http://www.memtest.org/
This program will allow you to make either a bootable floppy disk or a bootable CD. Before you can use the above program I will need the correct model No# for the Gateway, found on a sticker somewhere in the PC case along with the serial number.
The information regarding you're board is incorrect. You can find the boards model number written in white lettering somewhere on the board or on the side of a PCI slot.
The link for the Intel 850 is listed here.
http://www.intel.com/design/chipsets/850/
Gatway's link here.
http://support.gateway.com/support/drivers/dlcenter.asp
I'll check back from time to time & check if you have found the correct information.
Good Luck
Mike
Posted on Apr 18, 2008
  • Mike Peluso
    Mike Peluso Apr 18, 2008
    Model number & serial number on the outside if the Gatway Case. (Sorry).
I need the manual for the Abit TH7 raid motherboard to match the 1.4G intel Pentium 4 processor
The old Abit TH7 RAID mobo, ay?
http://www.motherboards.org/reviews/motherboards/925_2.html
The Socket 478 motherboard uses an Intel 82850 Northbridge chip, and Intel 82801BA Southbridge chip, for the motherboard chipset.
(ICH2 is 82801BA)
http://en.wikipedia.org/wiki/List_of_intel_chipsets#Pentium_4_chipsets
(Intel's term for their Northbridge chip is MCH. Memory Controller Hub,
http://en.wikipedia.org/wiki/Northbridge_%28computing%29
The Northbridge chip handles the faster capabilities of the computer.
The Southbridge chip handles the slower capabilities.
The Northbridge chip handles the Processor, Ram Memory, and High-speed graphics.
AGP and PCI-Express are high-speed graphics.
{The Abit TH7 RAID mobo has an Accelerated Graphics Port expansion slot, for a graphics card. AGP)
A graphics (Video) card inserted into a PCI expansion slot, or Integrated Graphics,
is Not high-speed graphics.
(Integrated Graphics is also referred to as OnBoard Graphics.
On the motherBoard )
http://en.wikipedia.org/wiki/File:Motherboard_diagram.svg
As you can see in the chart on Wikipedia the FSB support for the Intel 850 chipset (Intel 82850) is 400MHz.
In conclusion, you know now that you can use an Intel Pentium 4 processor,
A) That fits in a Socket 478 processor socket,
B) Has a maximum Front Side Bus frequency rate ('Speed') of 400MegaHertz. (FSB 400MHz)
Here is a link to the Motherboard Manual (PDF file format),
http://www.motherboards.org/mobot/manuals/Abit/
Scroll about three-quarters down the page, until you come the heading in the left column -
th7.pdf
Left-click on Download to the right.
For additional questions please post in a Comment.
Regards,
joecoolvette
Jul 02, 2011 | Abit TH7-RAID Motherboard
I have just installed a 478 socket MSI MS-6526 ver 3 motherboard to my computer and all it dose is bleeps when i turn it on any help would be apricated
check for the error beep if you hear continues beep it means issue with the memory. check the RAM if it is properly inserted to the slots and if it is compatible to the motherboard. if you hear 2 or 3 beeps it means issue with the video. your video card maybe not compatible or not properly inserted to the slot. your motherboard has a built in VGA/Video card try using that first. try connecting the main components memory/RAM, power supply, KB and mouse, VGA card(optional you have a built-in) then check if there is a display or if it booted. then one by one add your other components you want to add. just to trace the problem.
May 19, 2011 | Intel Motherboard
I am using intel pentium4 2.4GHz processor with intel 845 motherboard, now i would like to upgrade it with intel 865 motherboard, is this possible?
it defend to your processor is for socket 478 motherboard and you going to upgrade *********** to intel 865 it supposed to be socket 478 too also if not your processor is useless because socket 478 mother is already phase out the new mother now using socket lg775 for intel dual core and quadro core processor
Jun 02, 2009 | Intel D845GVSR Motherboard
Gateway performance 1400 motherboard specs
Performance 1400 Memory Specifications Standard Memory 128 MB (removable) Maximum Memory 1.0 GB Memory Expansion 4 sockets (2 banks of 2) Memory Comments PC800 RDRAM RIMMs. RIMMS must be installed in matching pairs. CPU Type 1.4GHz Intel Pentium 4 Model Comments 400MHz FSB, Intel 850 Chipset
Apr 27, 2009 | Gateway (4000811) Motherboard
I put my 3 0 ghz cpu in my Gateway Intel 850 Socket 478 ATX Motherboard no video from agp is new board with 2x 256 rimm pc 800 pc seems to start all the fans as well new power supply 512 ati vid card but...
Remove the BIOS recovery jumper near the battery on the motherboard and attempt to boot. If the system displays a startup screen, replace the jumper on pins 1 and 2 (pin 1 will have an arrow by it) and configure your bios appropriately.
Mar 16, 2009 | Computers & Internet
MSI MS-6754 mother board won't boot and beeps when I swap processors
your motherboard has the chipset of 845GL series
so the specification of your motherboard is as follows read it carefully there may be some error in the manual or it might not be your motherboard model just have a check with that . here are the specifications as per i saw in the net ...
CPU • Support Intel® P4 (Socket 478) processor up to 2.6 GHz. Chipset • Intel® 845GL Chipset - Support FSB 400 MHz. - Integrated 3D/2D graphic core (Core frequency= 200MHz, 350MHz integrated 24-bit RAMDAC). - Support PC266/133 Technology. • Intel® ICH4 Chipset - AC'97 Controller Integrated. - 6 ports Hi-Speed USB 2.0 controller, 480Mb/sec. - Support both ACPI and legacy APM power management. - Legacy free support.
Sep 06, 2008 | Computers & Internet
Wiring off tower into motherboard for gateway intel 850 motherboard scoket 478 mod. # 4000782
thanks for the help. but it ended being a inteldesktop board model D850EMV2. I now have all the paper on it from Intel, agin I say thanks for the help
Jul 21, 2008 | ASUS A7S333 Motherboard
http://support.gateway.com/s/MOTHERBD/INTEL/2515762/8508314.pdf
I found the pdf file(manual) for this motherboard kinda by accident but hopefully this could help someone else out. : )
Jan 31, 2008 | Gateway (4000782) Motherboard
I have a Boot Problem with my INTEL P4 3.0Ghz. 800Mhz FSB,1M L2 Cache, Socket 478 CPU
I have experienced something similar with my new Core2Duo processor and a fairly new Socket 775 processor. Troubleshooting it led me to believe the CPU simply wasn't compatible with the motherboard. Although it's a shot in the dark, I suggest that you try out some of the following: - Did you try pulling out the graphics card to see if you got it to POST then? The graphics card or the monitor may need replacing. - Did you remove the RAM? - Are you sure all cables are attached properly? - Try to take out the CPU, talk to a friend with a socket 478 motherboard and replace his CPU with your CPU. Does it work now? If yes, motherboard needs to be replaced.
Nov 12, 2006 | Intel P4 Prescott CPU 2.8A Ghz W/1MB CACHE...
Gateway (4000782) Motherboard Logo
149 people viewed this question
Top Gateway Computers & Internet Experts
Prashant M
Prashant M
Alun Cox
Are you a Gateway Computer and Internet Expert? Answer questions, earn points and help others
