Question about Samsung LN40A530 40 in. LCD TV
Samsung LN40A530P1F LCD TV keeps blowing main power fuse when i turn set on it blows right away i have replaced fuse many times. Also when back was off i noticed a arcing as fuse blows at a component just in back of power cord plugin on main board that is not a cap. anyone know whats up ?
  • Samsung Master
  • 12,061 Answers
Http://www.samsung.com/us/support/detail/supportPrdDetail.do?menu=SP01&prd_ia_cd=&prd_mdl_cd=&prd_mdl_name=LN40A530P1F
If a fuse blows like that there is a major problem, inside. I suspect that what your are seeing is the inrush thermistor, and they exhibit this under great load. I would explect that this fault maybe in the actual PSU. Due to the lack of service manual support, i would get a quote for repair from an authorised service center.
Posted on Jun 22, 2010
    Sergeant:
    Champion:
  • 310 Answers
Good day. your power supply is defective. maybe the regulator is shorted. you need a qualified technician to fix your problem.
SOURCE:
Hello, I have a samsung un55d6400 led tv, where the standby light blinks 5 times, ive replaced the powerboard and main board. The fuse keeps blowing what is my next step
The fuse keeps opening because the problem is more serious. If it did not blow, then more damage could be incurred in the TV. Sounds like you should consult a professional rather than not really knowing what you should be doing next.
Dec 05, 2016 | Samsung Televison & Video
My 39 inch tv fuse blown constantly
Either a short or incorrect fuse being used--fuses have become specialized beyond amperage and voltage ratings--a lot are special fuses and or either a slow blow or even a thermal type fuse.
If not a fuse issue, look for a short in the power supply or wherever that fuse is located.
Dec 19, 2012 | Emerson LC391EM3 39 in. LCD HDTV
Samsung LN55B640 LCD TV blowing fuses
when the fuse always blown, it could be a shorted component at the power supply board or the main board was affected during lightning where in some of the component get burned then cause a shorted line.if you don't have an idea in any electronic repair just leave it to the trained technician to do the works. hope this can help you thanks for using the fixya.
Jul 18, 2012 | Samsung LN55B640 LCD TV
The 3.15A fuse on the power supply board of my Samsung LE40B550A5W LCD TV keeps blowing as soon as I apply mains power to the TV
Some of the parts of the power is shorted try to check the regulator and the diode. But be sure to unplug the unit before checking the regulator and the diode. Feel free to send feed back good day and best regards.
Aug 18, 2011 | Televison & Video
Tv does not turn on , there was a power outage and since then it wont turn on. there is power to the outlet
If the TV is completely DEAD. Check the main fuse in the power supply. Replace the fuse with exact amperage. Make sure you unplug the TV before taking the cover off. If the power supply keeps blowing the fuse, replace the power supply. Be very careful high voltage can kill!
Best of luck
AAA TV SERVICE
Jun 12, 2011 | LG 42LG30 42 in. LCD HDTV
Panasonic ct-32sl13g blowing fuse by power supply
You will need to remove the back of the TV. Don't worry, it's not that bad.
There are 4 screws across the top, one on each side, one right next to where the power cord goes into the back of the case, and the two more by all of the video connections **These are the most important to remove because they attach the main board to the back of the case.
Once you have remove the screws then the entire back of the set will slide off. If you look where the power cord attaches to the board you will see a small fuse. This is a 6.3 Amp 125 volt fuse. You can replace it with a 6.3 Amp 250 volt fuse from your local Radio Shack. A four pack costs between $3 and $5.
Make sure that you check that it works before putting it all back together. Check for any loose connection cables while you're back there. I found a few when I did this.
Apr 15, 2009 | Panasonic CT-32SL13 32" TV
42" LCD HD TV keeps blowing fuses.
A ceramic fuse stands up to heat better than a non-ceramic fuse. I'm no pro, but it sounds like your power inverter board maybe bad. There are replacements out there. Good luck
Jan 18, 2009 | Vizio L32 32 in. LCD HDTV
My sd-533hd5 keeps blowing the 5 amp 125v fuses
Yes! it sounds like a power supply problem! or the flyback in the main board needs replaced ( part is in the $70.00 range
Dec 12, 2008 | Pioneer SD-533HD5 53" Rear Projection HDTV
Fuse keeps blowing out in my maytag washing machine
the power surge probably shorted out something in the main wire harness or fried your motor. remove the screws from the control panel and look for any wires that are discolored, charred or disconnected. in the event you do't find it there trace the wiring thru the cabinet looking for the same thing. if you don't find that, replace the motor
Nov 16, 2007 | Maytag Neptune FAV6800AW Top Load Washer
Samsung LN40A530 40 in. LCD TV Logo
2,667 people viewed this question
Jerry Greenberg
Jerry Greenberg
Demonic-2011
Demonic-2011
