D box 2
I cannot connect d box 2 to my laptop. Says either wrong ip or firewall is blocking it. I have checked both and they are correct, all firewalls are off.
Please help.
Kind regards,
Rakesh.
    Problem Solver:
  • 6 Answers
Have you checked your windows firewall.
eiter turn it off or allow the ip of your box
Posted on Apr 24, 2008
Email result EA3227
IP Scanner operations
Error Code Cause Remedy
EAXXXX ImageReceiver was not started.
Start ImageReceiver.
The IP address of the recipient
is not specified correctly in the
dialog box that appears after
clicking “Receive Settings”,
then “Connection Filter”.
Click “Receive Settings”, then “Connection
Filter”, specify the correct IP
address, and then restart ImageReceiver.
ImageReceiver is not operating
correctly.
Restart the computer.
Re-install IP Scanner.
Check the TCP/IP settings on the computer.
The LAN cable is not connected.
Check that the LAN cable is correctly
connected.
The network settings on the
computer are not specified
correctly.
The network load on the recipient’s
computer is too high.
Check that large e-mail messages are
not being received at the recipient’s
computer and that large files are not
being downloaded from the Web.
Too much data is being sent. If a high scanning resolution has been
specified, reduce the resolution or decrease
the number of pages scanned
at one time, and then scan the document
again.
Access is blocked by the setting
specified for the computer’s
firewall (Windows
firewall) for the Internet connection.
Change the setting specified for the
computer’s firewall (Windows firewall)
for the Internet connection according
to the instructions from your network
administrator.
Oct 07, 2009 | Konica Minolta bizhub 250 All-In-One Laser...
Tip
Firewall Configuration
A firewall is a type of security mechanism used for preventing security threat in both incoming and outgoing computer traffic. It protects your computer system and/or the private network from intrusions.
It acts as a barrier, which checks all the incoming and outgoing information to and from your computer or a network based on the firewall settings. Firewalls can be customized according to the level of security required. It filters the messages based on some conditions, such as the IP address, ports, protocols, domain names etc.
These can be implemented in the hardware, software or sometimes both and scan the entire messages passing through it and veriy whether each block or packet of the message meets the specified security criteria.
Some operating systems like Microsoft Windows offers built-in firewalls, which are by default turned on to block incoming threats from the Internet. You can also look for any third-party software or hardware firewall to replace the default Windows firewall.
Types of firewall
There are various types of firewalls like:
1. Packet filtering firewall
2. Application-level gateways
3. Circuit-level gateways
4. Hybrid firewall
The role of packet filtering firewall is to examine the information available in the header of the message packets. The Application-level gateway firewall works on the application layer of the protocol stack. It works in a more intelligent way as compared to the packet filtering firewall.
Mentioned below are some of the conditions, which help in adding or removing the filters from the firewall:
1. IP address: Every machine connected to Internet has a unique IP address. You can customize the firewall to block any IP address, if it seems to show an uneven or unauthorized attempt or nature.
2. Protocols: You can decide which protocols to be included in your firewall’s filters. Some of the commonly used protocols, which can be included in the firewall are: IP, HTTP, TCP, FTP, SMTP etc.
3. Ports: You can configure the firewall to allow or block any port number.
Similarly, there are various other conditions which can be used to configure the firewall.
on Jan 27, 2010 | Computers & Internet
Bizhub 250 error EA3226
Scanner operations
The IP address2.gif of the recipient
correctly.
Check the TCP/IP2.gif settings on the computer.
connected.
The network settings2.gif on the
correctly.
again.
firewall (Windows
administrator.
Jun 24, 2009 | Konica Minolta bizhub 250 All-In-One Laser...
What im i doing wrong
Limited or No Connectivity Error Message
If you are still experiencing this error message even you may be experiencing one of several problems shown below:
1) Your Network or DSL router may have bad or missing information. Powercycle your router and/or rebuild the configuration in your router.
2) Double-check your cabling to the computer. Make sure you have the correct type of cabling, straight-through CAT 5 or possibly a crossover cable and try another cable or test the cable to make sure its working properly.
3) Check your network card to make sure its configured correctly and working properly. Many times setting the network card to 10Mbps/Full Duplex will solve this issue. To do this, open Control Panel, System, Device Manager. Go to the properties of the Network card, click on the Advanced tab and find the Link Speed and Duplex section. Change it from Auto Detect to 10Mbps/Full Duplex.
4) Check and test your firewall. Your firewall, especially if its a software firewall like ZoneAlarm, Black Ice, Norton Firewall or something else could be blocking the connection. Disable your firewall and test the connection. You may have to resolve the problem by even uninstalling and reinstalling the firewall.
5) Check your IP address assignments and workgroup settings in the computer for accuracy. Statically assign IPs to the computers in your network.
6) Reset your TCP/IP stack by downloading and running WinsockXPFix.exe a Visual Basic program designed to fix corrupted TCP/IP issues, host file problems and a variety of other connectivity issues.
Feb 01, 2009 | NetGear WGR614 Wireless Router
Laptop can't connect to internet
Nov 19, 2008 | D-Link DI-604 4-Port Cable/DSL Router...
Need network key, wireless is not working it logs me off all the
7) Also this issue is relate to SP2 update (in that case you should run the Microsoft patch (KB884020) for it.)
Nov 18, 2008 | D-Link AirPlus DI-524 Wireless Router
The device appears on the desktop but has a cross through it
Does mean that is not connected.
Double click on the icon, select your network and click connect.
If you were been connected before, you have some problem connectivity.
you can fin some help here:
Oct 28, 2008 | Gateway Belkin 54g Wireless DSL/Cable...
Wireless router dlink dire-301
1) Check and test your firewall. Your firewall, especially if its a software firewall like ZoneAlarm, Black Ice, Norton Firewall or something else could be blocking the connection. Disable your firewall and test the connection. You may have to resolve the problem by even uninstalling and reinstalling the firewall.
2) Check your IP address - Renew your IP address
3) Reset your TCP/IP stack by downloading and running WinsockXPFix.exe a Visual Basic program designed to fix corrupted TCP/IP issues, host file problems and a variety of other connectivity issues.
Oct 28, 2008 | D-Link Wireless
I have a dlink - dir-301 wireless router and i can connect, i can see my network but i can connect, even though all correct lights are on the router and i have the correct password
Oct 28, 2008 | Computers & Internet
Firewall blocking runescape
Disable all firewalls, as Norton, Zone alarm etc.
Also disable windows firewall from control panel.
If it still does not work check the router settings. Routers have internal firewall, you may need to add your laptop's ip or mac address to the firewall as trusted one.
An alternative is connecting laptop by wires to the router, probably the router firewall will let it go , as wired connections are set to less resticted security.
Sep 17, 2008 | Video Game Consoles & Games
Computers & Internet Logo
David Payne
David Payne
