I bought a new GE front load washer. I want to install it under a counter. The manual says I should use a "top sheet kit" for this location. The sales person had no idea what that ment and the technical staff was out. Can you tell me what it is and why it is requiered/ Steve
I'm pretty sure that means it has to have the metal top on it that it comes with.....the one you'd remove if stacking the dryer on top.
Posted on Jan 02, 2009
Dimensions for the Frigidaire Front Load Washer FTF530FS3
For a normal install, the washer is 36" H x 24 3/4" D x 26 3/4" W. If you install the washer under a counter with the top sheet, then it needs 34 5/8" to the bottom of the counter. The dimensions are given in the installation guide available from Frigidaire or Sears Parts Direct. See https://secure.searspartsdirect.com/partsdirect/part-model/Frigidaire-Parts/Washer-Parts/user-manuals/manual-downloads/Model-FTF530FS3/1428/0153200?modelNumber=FTF530FS3&diagramPageId=&documentId= . A direct link to the Installation Guide is https://c.searspartsdirect.com/mmh/pd_download/lis_pdf/INSTL/L0709314.pdf . See page 3 with the Rough-In dimensions.
I hope this helps.
Feb 24, 2016 | Frigidaire Washing Machines
Maytag Neptune MAH4000 Motor Conversion Kit Instructions
I do please post your email here and i will send it to you
Feb 11, 2008 | Maytag Neptune MAH5500B Front Load Washer
Zanussi rear counter weight screw mountings broken
If this is a GE top load washer, I have see it a few time's. You can go to your local hardware store and get 2 new 4 inch bolts and nut set. and reattach the counter weight. The old bolts were just screwed to the frame. With today's appliance's they use 1/32 to 1.16 sheet metal... it don't take much to strip that out.
Next time post brand and model number...make's it easier.
Mar 07, 2014 | Washing Machines
Repair manual for a bosch front load washing machine
if it has a bottom panel remove that and the tech sheet should be located one either the right side or the left side of the frame of the washer. If it does not have a bottom panel then remove the two or three screws from the rear of the washer that connect the top cover. This cover then slides backwards off the machine and your tech sheet will under there. If you have proper power going into the machine but have no lights on your display it could be quite a number of different things unfortunately.
Nov 16, 2012 | GE WBSR3140DW Top Load Washer
My G.E. washer locks door turns to the right one time, turns to the left one time,adds water and does nothing else until its time to add water again, it adds more water and eventually pumps it out but no...
Your tech sheet is located under the top. My friend Jones brought one by and I made a crude movie that shows the tech sheet location on top and how the machine basically works. The pump died and was replaced.
GE WASHER MOVIE FROM MY LG PHONE
Jun 18, 2012 | GE Energy Star WCVH6260F Front Load Washer
I having a problem unerstanding the instruction sheet that came with my GE parts for door lock latch kit,I would like to speak using a phone, Thanks
To be able to talk to an expert one way is to access the Browse Experts (found right at the bottom LHS) page then at the top RHS you will find a box containing what you require ;-0)
Thanks and good luck!
John C
Aug 13, 2011 | GE WSXH208A Front Load Washer
Top Loading GE Washer WHDRR418 causing tiny to moderate holes in sheets and tee shirt type...
Those types of washers bring the clothes downtown. That's why Kenmore washers can be called "Shredmore."
Jun 13, 2010 | GE Energy Star WCVH6260F Front Load Washer
Looking for a manuel for a kenmore elite oasis he,stopped washing
If you are looking for a REPAIR manual, each one of these washers come with a technical data sheet located inside the front panel of the appliance. The tech sheet includes all diagnostics procedures, error code definitions, troubleshooting flow charts and wiring diagrams. To access it, you can pop the top panel open by locating the two retaining clips in the seam along the front of the washer where the washer top and front panel meet. About 2 inches in from each side slide a putty knife into the seam and push in to release each clip. Hold the lid shut as you lift the top. The tech sheet is located on the inside of the front of the washer between the wash tub and casing. Or....you can have someone lift the washer and tilt it back and you can try reaching up from the bottom between the wash tub and front casing.
If you need an OWNER'S manual, you can go to managemylife.com and type in the your model number under the "Manuals" link. They have an extensive list of manuals in .pdf (Adobe) format that you can download or print for FREE.
I hope this helps you.
Feb 12, 2010 | Kenmore Washing Machines
Washer manual
If you are looking for an Owner's Manual, go to managemyhome.com and type in your model number in the following format: "110.28032700" under the "Manuals" link. Your owner's manual is available in a .pdf (adobe) format that you can download or print for FREE.
If you need technical data sheet to troubleshoot a problem, the washer comes with a tech sheet inside the cabinet. It is located between the wash tub and cabinet in the front of the washer. The tech sheet includes all diagnostics procedures, fault codes and technical data to troubleshoot any problems you may encounter.
You can access it by lifting the washer top, or by reaching up from the bottom of the washer. If you choose to open the washer top, you need to locate the two retaining clips along the front of the washer in the seam where the top panel meets the front of the washer. Push in on the retaining clips and the top panel will pop free and can be lifted up. Make sure you hold the lid closed while lifting, so that it does not fly open when lifting the top. I recommend taping it closed.
If the tech sheet is missing, you can order a new one. The part number is W10026628.
If you have questions, please let me know. I hope this helps you.
Oct 18, 2009 | Kenmore Elite Oasis 27052 Top Load Washer
Washer will not drain
Remove the front panel. Remove the drain pump and clean the debris from the drain line and the drain pump.
The service sheet is located inside the control console with the procedure to remove the panel.
Mar 02, 2009 | GE WBSR3140DW Top Load Washer
Washing Machines Logo
Top Washing Machines Experts
