Net work printing
I have a desktop and HP printer on a network with a laptop. I used to be able to print on the network from my printer, now I can't. The correct printer is check in the control panel on the laptop but when I try to check anything in the drop down menu, I get a message that the print spooler is not started. I have stopped and restarted but still get the same message. This problem also started about the time I upgraded my security software.
  • 1 more comment
  • LongT Apr 15, 2008
    I corrected the problem this morning. It did have to do with the suscription renew resetting some of the parameters. I went into firewall rules and discovered that the network was set at disabled. I changed to "safe" and everythign works fine. Thanks for you help.
  • scooterbuoy Nov 05, 2008
    I have a APSUSB1 AirLink print server; I started having problems printing when I recently upgraded my router to a Belkin Wireless G Mimo. I can print a test page from PS Admin but can't print in normal mode.
  • B Joan Rapier
    B Joan Rapier May 11, 2010
    Hi LongT
    Have you tried (from a command window):
    net spooler stop spooler
    then
    net start spooler
    I suspect you have but I should ask anyway.
    The correlation you made between this issue and when you upgraded your security software is a good one. These observations, most times, are right on the money. Sometimes, though, they're red herrings...
    How are you doing w/ respect to file sharing, etc. on this LAN since your security software upgrade?
    Any other issues at all?
    Can you disable the security software and see if the problem persists? (The security software that will REALLY disable itself when told to do so is rare these days so, even if you have "disabled" it, it could still be interfering w/ your ability to access network resources.)
    Is the network printer on its own node or print server device or is it connected to a print server (running a server OS or client OS)?
    Please, post back w/ your answers and any other questions, observations, comments you have. Also, if you have ANY other direct or peripheral information related to this issue, please, include that as well.
    Thank you
    BJ @:)
    Sergeant:
  • 202 Answers
My apologies on the typo in the net commands
Should be...
net stop spooler
net start spooler
Posted on Apr 14, 2008
  • 4 more comments
  • B Joan Rapier
    B Joan Rapier Apr 14, 2008
    Can you print to a local printer from this computer? If you're truly having spooler issues, I'd expect an issue w/ a locally connected printer as well.
  • B Joan Rapier
    B Joan Rapier Apr 15, 2008
    You're certainly welcome, LongT.
    Thank you for using FixYa. We're here to help.
    BJ @:)
  • B Joan Rapier
    B Joan Rapier Apr 16, 2008
    Hello LongT
    Hopefully you're merrily printing across your network now. :)
    It appears that my solution lead you to the resolution of your problem. Would you, kindly, take a moment to change your rating to a "FixYa". I would be **most humbly** grateful. :)
  • B Joan Rapier
    Hello LongT
  • B Joan Rapier
    Hello LongT
    BJ @:)
  • B Joan Rapier
    Thank you, kindly LongT! You're swell! :)
HP OfficeJet 7310 - My print jobs get stuck in the que and never print. In "devices and printers" it says "printer offline". It is a network printer, to which all ethernet connected...
Solution 1 :
Go to START MENU
Choose RUN
Type the letter "cmd"
Type the word "net stop spooler"
Exit
Go to C drive
Choose to Windows Folder
Click show content
Choose system32 folder
Choose spool folder
Choose printer
And delete all printing jobs pending
Again go back to CMD window and type the word "net start spooler"
Restart your computer also turn off your printer and switch it on.
It will work fine right now
I hope it helps you
Solution 2.
Check the printer driver using device manage and maybe it is corrupted. Try test page if necessary.
Solution 3.
Reinstall the printer software
Solution 4.
Check the network switch hub and maybe some loose connection.
Solution 5.
Solution 6.
Check the configuration of the printer is somethings not correct.
Dec 11, 2010 | HP OfficeJet 7310 All-In-One InkJet...
Tip
Unable to Print on HP Printer
There are 2 simple methods to resolve any print job stuck in queue issue. However, both the methods will not fix printing issue if the HP Printer is in Error mode. Make sure your printer is able to print self test page to prove its functionality,
First method.
This Utility program resolve all the printing issue for HP Printers Only ( Network and USB connection )
This Utility will Resolve :
1. Check Connectivity between the Pc/laptop and HP Printer
2. Check if there any Documents stuck in Queue
3. Check if all the software/Drivers are correctly Installed
4. Check if the HP Printer icon is the default icon to print
5. Will Resolve Printer Spooler Issue and few more issue
Download the file on Desktop and Run the program ( Ex. File name = HPPDU.EXE )
Click ->> HP Print and Scan Doctor to download the Utility and save on Desktop location
Run the HP Print and Scan Doctor file and follow the instruction on screen to fix.
If this does not fix, try the 2nd Method given below ( this is manual process to clear the print job stuck in queue )
This works for all brands of printers ( HP, Canon, Epson, Brother etc )
Click Start > Programs > Accessories > then select Command prompt, then the black window will open and there type NET STOP SPOOLER and hit enter that will confirm service is stopped , after that on the black window type NET START SPOOLER and hit enter. Repeat this step 3-4 times and end the command with NET START SPOOLER and hit enter. Open the Printers folder and Refresh the Window ( Press F5 on the keyboard )
The service will be started and all print queue should already be remove.
// Above given solutions help in resolving print queue issue, however check the printer functionality if it is working fine ( the printer should be in working condition and should be able to print self test page, this utility cannot fix printer hardware issue //
* Please rate this solution with Thumbs up and comment to help us improve providing support
on Jun 15, 2010 | Office Equipment & Supplies
Wireless Printer Issue.
As I understand your issue, the HP Laserjet 1020 is a USB printer. You have it attached to a desktop PC. If that PC is rebooted, you can print for a short while.
The problem is probably not your network, but your desktop.
I would do the routine maintenance on it. Clear all the temp files, check hard drive free space and defrag the drive.
Then get online and download Malwarebytes.org spyware malware scanner tool. Scan the desktop PC for malware and clear out anything that may be occupying the resources of this PC.
Apr 06, 2010 | Nortel 2332 802.11a/b/g Wireless Access...
Mp250 canon user intervention required problem
Clear pause printing
  1. From the Windows Desktop, select Start , Settings , and Printers .
  2. Right-click the HP LaserJet printer icon that is being used.
  3. Select the Work Offline or Pause Printing option (if enabled) to remove the check.
  4. Print the document again.
Establish parallel connection
  1. Turn off the printer or remove the printer from the network.
  2. Connect the printer to the PC using a parallel cable.
  3. Power on the printer.
  4. Print the document again. NOTE: If the User Intervention Required message reappears, disable or remove any HP LaserJet software utilities loaded on the system (for example, Status Window, HP Toolbox, etc.). Prove printer functionality and troubleshoot communications; try printing again.
Uninstall and reinstall the driver After performing a cold reset on a product installed with USB, a higher DOT4_00x port is created, causing the printer to hang while printing. NOTE: This is required with products installed on a USB port only.
  1. Uninstall the USB printer driver.
  2. Remove the HP folder and AIO folder from the hard drive.
  3. Reinstall the USB printer driver.
CAUSE: This error can occur if when using a network or printing from a laptop. When the print job goes into a pending status, the printer is either in Work Offline or Pause Printing mode. Hope this helps. Please rate my response.
Thanks.
Have a good day.
Mar 17, 2010 | Office Equipment & Supplies
Can't print to HP 2600n over network
The LaserJet 2600N has a built-in print server and can be connected to the local network (normal ethernet cable) directly. While printer sharing via Windows should work, I found it much more convenient to access it without the need of a hosting computer - you do not need to switch on the desktop PC for printing from the Laptop, for example, its also printing faster.
Jan 25, 2010 | HP Color LaserJet 2600n Printer
Error during print 'Remove all paper from bin'
HP Laserjet 4250 Network connected laserjet printer.
Steps to be follwed to set right :
01. Please check in number of desktops or laptops it connected.
02. Give proper IP Address in the Desktop or Laptop where it has to be orignally installed.
03. Being a network printer, lot of desktop or laptop users might have printing job iniated.
04. Right click the printer properties which is available bottom right hand corner ikon and delete or cacel all printing jobs.
05. The original desktop or laptop where the IP Address created will be rebooted. System should be restarted.
06. Try to print now to close this solution.
07. Still the problem persits, kindy contact local HP Authorised printer service engineer to set right this issue.
Have a nice working day.
Jul 17, 2009 | HP 4250 Monochrome LaserJet Printer
My HP 6300 says offline and will not print
same problem no solutio !
delete and re-install printer is the only thing that works and only temporarily ... frustrating !!!
Jun 07, 2009 | HP DeskJet F380 All-In-One Printer
Cannot print from laptop to printer using wireless print server
This is probably the Software Firewall on your laptop
you should probably tell your firewall software that you have an internal network (Laptop-desktop-printer) you should add the IP range of the wireless network as a trusted network.
May 25, 2009 | Lexmark X3550 ALL-IN-ONE InkJet Printer
NETWORKING
yes of course you need a wireless router for that. wireless router are for wireless network (desktop pc also needs WAN)
Feb 18, 2008 | HP Photosmart C3180 All-In-One InkJet...
Wireless laptop not printing
Indeed, you don't need the print server. Since your HP 6310 already has an integrated network port, you may setup and use it on your laptop the same way you do with your desktop. If you can browse the Internet wirelessly with your laptop, you should also be able to print.
Jan 20, 2008 | D-Link Air Plus DP-G310 (dpg-310) Print...
Computers & Internet Logo
552 people viewed this question
David Payne
David Payne
