Question about HP PSC 1410 All-In-One InkJet Printer
My HP PSC 1417 wont print from my Toshiba laptop with vista, everything says it is connected properly, and the print job is waiting but never prints, if I plug the printer into an older laptop with XP the print job starts straight away. What can I do to my Toshiba to get it to work with my printer
  • kiwigeezer20 Jun 23, 2010
    Many thanks 'Rider on way' however this has not solved problem, the HP diagnostic tool cannot detect a connection to the printer, not sure where to go from here, silly to have to change computers whenever a print job is required. USB ports are good for every other device I use. Any ideas?
  • HP Master
  • 1,679 Answers
Http://www.fixya.com/support/r5095488-unable_print_hp_printer
Posted on Jun 22, 2010
  • ONE-Touch-Solution
    ONE-Touch-Solution Jun 23, 2010
    Disconnect the USB Cable from laptop
    If you have the Printer software disk, follow these steps,
    Open the disk - Open Util folder - Open CCC folder
    Run the Uninstall_L2 bat file
    Restart the PC
    Run the Disk - Choose Add a device Option and continue with the instructions
    If this does not solve the issue, you need to do Unistall_L2 and UninstallL_L3 and reinstall the software
    If you dont have the Software disk ( Open Control panel and Programs and Features and Uninstall all the HP Software present in the list )
    After uninstalling all the HP Printer related Software, Restart the PC.
    Click on this link to Download the Software from HP website
    http://h10025.www1.hp.com/ewfrf/wc/softw...
SOURCE:
Print jobs don't get into a queue when print server is offline
you must repair sharing to your all network,if not work you must check cable Lan connection try this.good luck
Apr 24, 2010 | Microsoft Windows XP Home Edition
Msg saying unable to start print job. is printer
Uninstall the Adobe PDF viewer and then reinstall it as the printer is respondingto other print commands,so its an issue with the s/w you are using.
Jun 11, 2009 | HP PSC 1410v All-in-One Printer
My wGPS606 wont print on my Windows Vista laptop!
I just found a way to enable the HP P1006 with a different print server (Liveprint on Orange Livebox router). Perhaps this might work with the WGPS606 wireless print server?
I set up the P1006 via the print server as instructed (I'm using Vista 32 Home Premium) but no test page would print.
BUT!! (with thanks to another another forum):
I selected printers, then right-clicked on the wireless printer I'd just installed and selected 'properties'.
Under the 'Ports' tab I deselected 'Enable bidirectional support'.
Problem solved.
Hope this helps.
let me inform you that this printer is not compatible with any wireless print server. The drawback is that it is not possible to network such printers. A printer needs a steady flow of data, which is easily accomplished when it is connected directly to a PC, but cannot be guaranteed when the printer is connected via a LAN. Also, these technologies require intensive handshaking between the driver and the printer.
The host-based software uses the computer's resources to process print commands and rasterizing data, taking advantage of the computer's memory and processing power."
Sorry I can't be more upbeat - but its probably useful to know that someone at HP thinks the job's imposible - unless someone out there has a fix?
May 11, 2009 | NetGear WGPS606 (WGPS606NAR) Print Server
Will print test page but nothing else
i've had the same problem with the same printer. mostly it happens on my vista home premium laptop printing remotely to the printer which is connected to an xp home machine. i found that i need to stop and then start the print spooler. on either of these operating systems you can do this by right clicking on the My Computer (XP) or Computer (Vista) icon and choosing "Manage." Once Computer management is open, go to Services and look for Print spooler. Right Click on Print Spooler in the list. choose stop. wait for the print spooler to stop, then right click again and choose Start. That should clear your stuck deleting document.
Dec 04, 2008 | HP PSC 1315 All-In-One InkJet Printer
HP PSC 2175 All-In-One Will not print anything
Try this HP utility which solved my problem...it works for vista and has a link for XP users too
Print Jobs are Stuck in the Print Queue and Will Not Print with a USB Connected Printer in Windows Vista
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c00843712&lc=en&dlc=en&cc=us&lang=en&rule=23624&product=90809
Oct 24, 2008 | HP PSC 2175 All-In-One InkJet Printer
Printer
i cNNOT FIND THE HPPSC1510DRIVER WHEN I DONLOADED THE C240 IS COMING WHY
Sep 15, 2008 | HP PSC 1510 All-In-One InkJet Printer
Printer HP PSC 1400 to run with Vista program
You will need to go to the HP support site,
http://welcome.hp.com/country/us/en/support.html
Find your specific printer, and download the driver for Vista. Should not be a problem after that.
» HP PSC 1401 All-in-One
» HP PSC 1402 All-in-One
» HP PSC 1406 All-in-One
» HP PSC 1408 All-in-One
» HP PSC 1410 All-in-One
» HP PSC 1410v All-in-One
» HP PSC 1410xi All-in-One
» HP PSC 1417 All-in-One
Feb 23, 2008 | Office Equipment & Supplies
HP psc 1210 will not print
Please check the printer status at control panel printer properties if it is offline or ready. Restart your computer if necessary, you will notice all pending jobs will be printed as long as there is no problem with the connections of cables and drivers. Note: Do not cancel printing jobs in the middle of sending data mode to printer or queing instead you have to remove all papers on tray and wait for the error "paper out or empty" then there click Cancel. Hopes this helps.
Best regards,
Rosener Guyano
Feb 02, 2008 | HP PSC 1210 All-In-One InkJet Printer
HP PSC1210 not printing all items on the document with vista
The issue is occuring due to the Windows Vista . You can get solution by using below web link :
http://support.microsoft.com/kb/934633
Please copy the entire URL and paste it in a new window of Internet Explorer and press Enter.
Follow instructions from above link.
Thanks
Silan
Dec 24, 2007 | HP PSC 1210 All-In-One InkJet Printer
HP PSC 1410 All-In-One InkJet Printer Logo
163 people viewed this question
Clive
Clive
Thomas F. Schneider
