Question about Lands Phones
Handsets are able to charge, but are frozen. seems that they are locked out of everything. I can receive calls on my speaker on the main base, but I cannot make outgoing calls. cannot deregister handset. I recently got Warner Cable RoadRunner and digital phone and TV. How can I fix this handset?
  • 3,037 Answers
Are the phones new or did they just start having this problem when you switched providers.
Possibly they need an unlock code. Please inform us of the model and maker of the phone so that we can further assist you better.
Thank you for using fixya
Posted on Apr 14, 2008
    Genius:
  • 1,665 Answers
Ensure that is fully charged or check your charger operation.
    Master:
  • 555 Answers
What is the maker and model of this phone?
How do I get intructions for coordinating my new base with the 2 handsets from the old base; are they available on the internet?
Usually you need to charge each handset ONLY on the Main base the first time, you can then use the other bases and the main base should recognize them
Aug 07, 2014 | Panasonic KX-TG9331T - Dect 6.0 Expandable...
Tip
Connecting extra handsets to main base
Call your phone, while it is ringing put your extra handsets on the main base. I did this and they started to ring when on the base and they worked after that. You may not need to call the main line, only put the extra handsets on the main base to get them connected but I didn't try this so I don't know.
on Oct 18, 2008 | Uniden Cordless Phone
Uniden PowerMAX 5.8GHz TRU8880 Series
does the phone do anything? if not charge battery, if you have already did that, then try to change the battery by getting a replacment from your local radio shack.
Apr 14, 2008 | Lands Phones
Hello...The base of my Uniden D1384-2 does not seem to be communicating with the handsets. Handsets are fully charged and all functions work. The base unit lights work and are capable of charging the...
it might be because of interference. i think it takes all the power from your other phones cause it needs all the power from your other things plugged in to try to get rid of the problem. if this helped, good. if it didnt, sorry. the way to solve this is to probably look at the base and figure out how to open it and take a look inside.
Aug 09, 2013 | Uniden Lands Phones
Phone can receive calls but not make them.
hello i have a solution, you need to change you dialing mode on the base option, the deafult is "tone dialling", change to "pulse tone " this fix my problem on my A495 gigaset.
May 16, 2012 | Lands Phones
Phones are powered but do not connect to base so can't receive or make calls. Is there a way to reset?
The manual, which can be found at: http://www.home-electronics.net/ge/pc/IB/25952EE1_IB.pdf, reads:
4. Place the handset in the base cradle. The charge/in use indicator turns on,
verifying the battery is charging. The unit will take 20 seconds to register
and verify its security code. READY shows in the display.
NOTE: In case of a power failure, the handsets may display
UNAVAILABLE when the TALK/CALL BACK button is pressed.
You must then place all handsets on the main base cradle
for 20 seconds to re-register.
That should reset your handsets. Hope this helps :) Thank you very much.
Feb 08, 2010 | GE 25952EE1 Cordless Phone
Handsets display "unavailable"
have you tried to charge all phones then placing them in the base one at a time to reset them? I know when the phone cord or the power is of my base my other units do not work..
Aug 23, 2009 | Uniden Cordless Phone
Extra handsets no longer seem to work. No ring and no line
Please be sure to put the extra handsets in the MAIN base station to register. They will not register in the small remote charger stations.
Let me know if that fixes the problem!
Brian
Jun 15, 2008 | GE 25942GE2 Cordless Phone System
Panasonic KX-TGA101S base not charging.
Here are a couple things you can try.
Clean the charging contacts, this can be done two ways. The manufacture's recommend using a pencil eraser. I recomend using a q-tip and some rubbing alchol. Just rub the alchol soaked q-tip on all the metal contacts on the bases and the bottom of the handset.
Gooo luck.
Hope this helps
Mar 12, 2008 | Panasonic KX-TG5632 Phone
Lands Phones Logo
61 people viewed this question
Top Lands Phones Experts
Are you a Lands Phone Expert? Answer questions, earn points and help others
