Question about Miele 11120301 W1203 Touchtronic Washer Right Hinged- Angled Control
W1203 the buzzer sounds and the fault indicators "intake and Drain" flash, please help
Front lower left corner has an access door.  Pry the access door open.  Inside you will find a yellow tab that will open the machine glass bubble door. Below the yellow tab is a cca. 2.5 inch screw-in plug.  Place a pan in front of the machine and unscrew to plug.  Water will drain out of the machine.  With the plug removed, tilt the machine forward past 45 degrees until all water has drained out.  This will reset the washer.  Insert the screw-in plug.
Posted on Jan 28, 2009
  • Marc Jongerden
    Marc Jongerden Mar 14, 2013
    This was super helpful and fixed the problem immediatley
Check that lens is tight on light inside of door at top
Posted on Dec 30, 2008
Miele w1203 washing machine at end of cycle fault lights intake & Drain and the ---on panel lighted Buzzing & will not operate now. I have cleaned drain at bottom left
There are two impellers, one of which may be stuck. It's easy to wiggle them with some tool to free them up. Search on YouTube for videos on where to find them (both are right in the bottom under the filter screen so easy to get to).
Jul 11, 2017 | Miele Dishwashers
Miele W1203 washer, buzzer sound with no indicator flash. how can i fix it
It sounds as if there is a leak and water in the pan (bottom of the machine) the front of the machine would have to be removed to check and determine the cause of the leak
Aug 02, 2014 | Miele Washing Machines
How do i fix miele w1113: stopped with oversudsing; buzzer sounds; "intake", "drain", "- - -"
the pump is not running when it is in a cycle, just when the machine is forced into a drain and spin. we have a bad drain pump motor and possible a bad board or main control. http://ww2.justanswer.com/uploads/jgrella16/2011-09-22_041351_w1100_w1200_ti_112304.pdf
Jul 28, 2014 | Miele Touchtronic W1113 Washing Machine
Miele Touchtronic w1203 , the intake and drain fault indicator lights are both flashing at the same time
Seems that the inlet valve or water flow is low , check the inlet flow or check for clogged filter.
Also check the lint filter and the cache filter. remove and clean drain pump. This must solve the issue.
Jan 17, 2013 | Miele Washing Machines
Miele Advanta dishwasher beeping
Buzzer
The end of a program and faults can be
announced by a buzzer tone.
The buzzer at the end of a program
sounds five times in intervals with a
brief break in between. The buzzer
sounds up to one hour if the
dishwasher is not turned off.
The buzzer for a fault sounds
continuously. The buzzer sounds for up
to two minutes if the dishwasher is not
turned off or the fault is fixed.
The buzzer is activated by default. It
can be set to off, so it does not sound
at the end of a program. The buzzer for
a fault cannot be set to off.
^ Open the door.
^ Turn the dishwasher off o.
^ Press the program button and at the
same time turn the dishwasher on g.
Hold the program button until the
lower right program indicator comes
on.
If it does not come on, start over.
^ Press the program button briefly four
times.
The "Intake/Drain" indicator flashes 4
times in intervals.
The upper right program indicator
shows if the program end buzzer is
turned on or off.
- Upper right program indicator
flashes: Buzzer is turned on
- Upper right program indicator is off:
Buzzer is turned off
it is not easy to disable the buzzer. you have to hold the buttons down exactly the way it tells you to in the manual. you also have to pay attention to the lights and make sure they are flashing the proper sequences. try it two or three times. you will eventually get the hang of it. not sure where you live, but the miele techs have a computer that allows them to disable the beeper if you are unsuccessful. the proceedure is copied below.
^ To change the setting, press the
"Intake/Drain" indicator lights.
three times.
The setting is saved.
Jun 14, 2012 | Miele Advanta G2170SCSF Dishwasher
Miele W1203 washer drain and intake lights flashed together and now will not change modes. Can I reset it so that it will work again?
The flood protection device has activated. This is caused by a leak in the machine. It can also be caused if you are not careful when checking the drain pump,water may have gone back into appliance and activated flood protection device. If this is the case Tip machine forward,water in base of appliance will run out, and appliance will work. If Fault reoccurs then you have a leak.
May 17, 2010 | Miele W1203
Dishwasher adp 4601 when switched on the pump activates.and after 2 mins start lamp bliks and pump goes off
The number of flashes indicates the fault. Reset machine by holding down the start button for 3 secs, then start a new cycle. If fault reoccurs, the number of flashes indicates fault eg 3 flashes, stop, 3 flashes stop, indicates F3 fault.
Faults listed below- advice on repair depends on which fault your machine is indicating, but may give you an idea of what to look for
1flash=NTC (temperature sensor) break- NTC outside normal range.
2flash=water leakage-float switch in base activated.
3flash=heating fault(check element.NTC,control board).
4flash=drain error-blockage in pump or drain system,or faulty water indicator switch.
6flash=water inlet fault-check inlet valve, check inlet hose not kinked
7flash=flow meter failure (flow meter measures water intake volume-large plastic weir located on left hand side of machine-reomve side panel to access)
These a most common faults, but further advice on repair requires counting flashes when fault occurs.
Aug 09, 2009 | Whirlpool Dishwashers
Miele touchtronic 1113 washer
There is a float switch in a pan under the machine. This pan is probably full and the float switch is causing the Intake & Drain fault signal. You can lean the machine over to towards the front to partially drain the pan. Put a towel down to catch the water. When you put the machine level again the fault lights should be out. The real question is where did the water come from. You can easily remove the top (4 screws, 1 on each side behind the little plastic caps and 1 on each side of the back. Torx heads) and look down inside while you start the cycle. Look for leaks.
Good Luck,
Dan
Aug 09, 2008 | Miele Touchtronic W1113 Washing Machine
Miele w1203 fault
use the small orange tab to tighten down on the light just inside on the top of the door. i had the same symptoms and it fixed them right away.
Oct 03, 2007 | Washing Machines
Open Questions:
Washing Machines Logo
357 people viewed this question
Top Miele Washing Machines Experts
Gerry Harvey
Gerry Harvey
mpservices
Are you a Miele Washing Machine Expert? Answer questions, earn points and help others
