Question about Canon Office Equipment & Supplies
Cannot fax from my canon mp530 - Canon Office Equipment & Supplies
ohms
  • 1879 Answers
SOURCE: I own a Canon Pixma
for the receiving problem:
since the fax & tam shares one line, whoever answers first, gets the line regardless if it's a fax or voice.
but since you mentioned it is now not working when you switched to VOIP. fax was developed & designed with analog phone lines in mind. VOIP is digital and totally different from analog even though service providers "marketing strategy" says it's 100% compatible.
comcast for example offers a fax service, because they know that normal fax equipments will not 100% work on VOIP. There are some manufacturers that make FOIP (Fax Over IP) products.
Posted on Sep 13, 2008
SOURCE: Pixma MP530 Fax Problems
I am having a similar problem. You do have to connect your phone to the jack in the machine in the "Phone" jack slot, as well as have another line out to the jack in the wall in the "L" slot. That is all I know. I am having problems with my voicemail. Either I can received voicemail, and no faxes, or faxes, and no voicemail (fax picks up at specified number of rings). It is EXTREMELY frustrating. The machine is *supposed* to be able to discern between phone calls and faxes..and that is not happening.
Have you come across a solution? Aghhhhh!
Posted on Sep 20, 2008
rhoncruz
  • 134 Answers
SOURCE: canon pixma mp530 all-in-one printer set up
Receive Mode Setting
On the operation panel, press the following buttons to select the appropriate receive mode.
  1. Press <Fax>.
  2. Press <Menu>.
  3. Press the right or left arrow button to select [Receive mode set], then press <OK>.
  4. Press the right or left arrow button to select the receive mode that best suits your needs, then press <OK>.
    FAX ONLY MODE: When you want to receive only faxes automatically with your machine, or have a dedicated telephone line for FAX use only.
    MANUAL MODE: When you receive mainly voice calls and sometimes faxes, or want to receive faxes manually.
    ANS MACHINE MODE: When you want to receive voice messages on your answering machine and receive faxes automatically.
    FAX/TEL AUTO SW: When you want to receive faxes automatically as well as voice calls.
    DRPD: When you have subscribed to a DRPD service with your telephone company.
  5. Press <Stop/Reset> repeatedly to return to fax standby mode.
Solution: Changing the TX report MP530
Change the TX Report 1. Press the <Menu> button to display [FAX SETTINGS].
2. Use the [ left.gif] or [ right.gif ] to select [TX SETTINGS] then press <OK>.
3. Use the [ left.gif] or [ right.gif ] to select [TX REPORT] then press <OK>.
4. Use the [ left.gif] or [ right.gif ] to select [PRINT ERROR ONLY] or [PRINT FOR EACH RX] then press <OK>.
5. Use the [ left.gif] or [ right.gif ] to select [YES] or [NO] for [ATTACH TX IMAGE:] then press <OK>.
6. Press <Stop/Reset>.
Changing the Paper Size, Type and Source
Changing the Paper Source
Before printing, confirm that the location where you have loaded paper is selected as a paper source. Press <Feed Switch> to change the paper source.
(A) Auto Sheet Feeder Lamp
(B) <Feed Switch>
(C) Cassette Lamp
Note: Press <Feed Switch> so that the Auto Sheet Feeder Lamp lights when loading paper in the
Auto Sheet Feeder and the Cassette Lamp lights when loading paper in the Cassette.
You can also select the paper source with the printer driver when printing from the
computer.
Changing the Page Size and Media Type
Note: The asterisk <* > on the LCD indicates the current setting.
1 . Press <Paper>.
When you do not need to change the page size, press <OK> to proceed to step 4.
2 . Use leftright.gif to select the page size: A4 / B5 / A5 / 4x6 / 5x7 / C-CARD / 8.5x11 / 8.5x14
sizetypelcd.gif 3 . Press <OK>.
4 . Use leftright.gif to select the media type: PLAIN / PHOTO PRO / PHOTO PLUS / MATT PHOTO / GLOSSY
Note: In order to obtain optimal quality print results, when copying photographs, use Canon-recommended Photo Paper Pro or Photo Paper Plus Glossy.
5 . Press <OK>.
Entering the Date and Time Note: When your machine is connected to a computer with the MP driver installed, even if the date and time are entered from the Operation Panel of the machine, the date and time will be read from your computer every time you start the computer, turn the machine on, or disconnect and connect the USB cable. When using your machine connecting to your computer, set the date and time on your computer precisely.
The date and time will be reset when you disconnect the power cord or there is a power failure. In this case, you can set it again on the machine. Alternatively, it can be read from your computer and set on the machine by connecting the machine to your computer with the MP driver installed.
1. Press [FAX], then press [Menu].
2. Use [ left.gif] or [ right.gif] to select <USER SETTINGS>.
3. Press [OK] two times.
datetimeset.gif 4. Use the numeric buttons to enter the date and time (in 24-hour format). Enter only the last two digits of the year.
Note: If you misentered the date and time, use [ left.gif] or [ right.gif] to move the cursor under the number to enter the correct number. Three formats of date are available.
5. Press [OK].
6. Press [Stop/Reset].
I hope it helps!!!
Posted on Dec 01, 2008
SOURCE: Canon MP530 - Fax Memory is Full... How do I clear?
Solutions 3 and 4 are basically correct, they just leave out a few steps:
1. Press FAX button
2. Press buttons in following order:
Menu, + (right arrow), OK, +, +, +.
You should see Delete Document. If not, press + or - (right or left arrows) until you do.
3. It will show a document number, like 5004.
Press OK
4. It will show Yes No. Press - (left arrow) to select Yes.
5. Press OK
Note: Steps 3 and 4 may be reversed on some similar models.
Posted on Feb 08, 2010
drifterK
  • 4924 Answers
SOURCE: How do I retrieve faxes from memory with my Canon
either use the fax function on the windows...and set the printer to see it ..or try to import from device with a photo manager or a pdf..(or word )
Posted on Jun 20, 2010
How do I retrieve faxes from memory with my Canon MP530?
Jun 20, 2010 | Canon PIXMA MP530 All-In-One InkJet...
I own a Canon Pixma MP530 all-in-one fax,copier, printer,scanner. I cannot send or receive faxes since I switched my Comcast voip phone line from my office to my home phone, along with my MP530. The fax...
First try one step. The line which you have connected with the Fax, unplug any other phone from that line.
Call that number and see whether it rings or you get a fax tone.
Sep 13, 2008 | Office Equipment & Supplies
I just received a fax on my mp530 and it said received in memory. How do I print it out?
I have a Canon MP but not your model. Try this.
Click Start/Programs/Accessories/Communications/Fax/Fax Console
Then click Inbox, double click the fax and print it if you wish. There are options to print as soon as the fax is received, or you can send faxes to Desktop, or both options.
Nov 17, 2009 | Canon PIXMA MP530 All-In-One InkJet...
How do I get the Canon MP530 to fax ?
goto the print option and then print the fax
Oct 23, 2009 | Canon PIXMA MP530 All-In-One InkJet...
Will canon mp530 stop fax mode if low on ink?
It will run as long as the ink is just low, when empty it will not let you proceed. It will take an incoming fax and hold it in memory until the inks are replaced. When empty the error will stop you from sending a fax.
Sep 01, 2009 | Canon PIXMA MP530 All-In-One InkJet...
Sep 13, 2008 | Canon PIXMA MP530 All-In-One InkJet...
Canon mp 530 fax
All in one fax MP530
Fax will not work.Memory full.How to empty memory?
Thanks
Nov 26, 2007 | Canon PIXMA MP530 All-In-One InkJet...
147 people viewed this question
old marine
old marine
